 Old 12-13-2019, 01:00 AM   #1
deakgegi's Avatar
Posts: 8   (View Stats)
deakgegi will become famous soon enough
Default Engine shuts off during high speed driving
Dear fellow forum members!
Today I was driving around 160 kph, and put the car in neutral.
The RPM dropped to 0, and the battery and cel were lightning up.
After that I put the car in gear and everything was back to normal.
Every electronics in the car still worked no problem, but the engine simply shut off.
Tried to replicate it, but I can't get the car to do it while going slower.
Read the ECU codes, but nothing was found. No CEL lights after that, only while the enginge was shut off during driving.
What should I check for, do you guys have any similiar experiences?
I will do more testing later, but I'd like some ideas what to check first.
deakgegi is offline   Reply With Quote
 Old 12-13-2019, 07:09 AM   #2
Witness's Avatar
Posts: 39   (View Stats)
Witness is a jewel in the roughWitness is a jewel in the roughWitness is a jewel in the roughWitness is a jewel in the rough
Check that there are no leaks or unmetered air coming in from the intake. Check that all clamps on the intake are tight.
If you're able to replicate the problem, log it if you have an AP. If any CEL come on, post what they are as well
What modifications are done to the car?
2007 MS3
Stock Turbo - Wiseco Pistons - Manley H-Beam connecting rods - Autotech high pressure fuel pump internals - ARP cap bolts - ARP main studs
Balance shaft delete - JBR EGR delete - COBB intake - COBB front mount intercooler - COBB rear motormount - COBB electronic boost controller - COBB access port V3 - COBB blow off valve - Catless downpipe
Witness is offline   Reply With Quote
Uber shuts down Arizona self-driving program two months after fatal crash Haltech Automotive News 0 05-23-2018 01:50 PM
MS6 Engine shuts off after WOT Shift to neutral Mazstor MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 07-21-2017 07:18 AM
CX-7 shuts off after idling/driving 30 min black_cx7 CX-7 > Issues & Troubleshooting 0 02-18-2017 02:52 AM
Loud knock at 2500rpm then engine shuts off. SamiChicago MazdaSpeed 3/6 - Troubleshoot/Diagnostics 15 10-05-2015 09:43 AM
Engines shuts down after 8 seconds (new engine) aviator79 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 59 08-26-2014 08:20 PM
Page generated in 0.23096 seconds with 21 queries
