 Old 09-26-2019, 08:36 AM   #1
broncomitch's Avatar
Posts: 14   (View Stats)
broncomitch will become famous soon enough
Default *****Finally got to drive my car after the rebuild!!!! but issues. :**
So I bought my 07 speed 3 with a rod knock so I couldn't drive it.
Just finished rebuilding the engine and put it all back together and drove it for the first time and everything is good apart from getting some codes.
I'm not finding much info in the search or google so was hoping someone can help point me in the right direction so I can fix the issue's.
INSTRUMENT CLUSTER MODULE-ICM MEMORY
U2516 CAN WIRING HARNESS OPEN OR SHORT.
U2064 WARNING INDICATOR REQUESTED BY ANOTHER CONTROL MODULE
I have read this might be caused by my accessport?
PASSENGER JUNCTION BOX-PJB MEMORY:
U1900 ABS CAN COMMUNICATION BUS FAULT
B2212 PANEL DIM SWITCH OUT OF RANGE
ANTILOCK BRAKES-ABS MEMORY
C1234 RIGHT FRONT WHEEL SPEED SENSOR INPUT MISSING
(I replaced the sensor but the light came right back on when driving)
AIRBAG-AIRBAG MEMORY
B2232 AIRBAG CIRCUIT OPEN-LOOP 2: DRIVER SIDE
Think this is from the steering wheel clock?
Cleared it but it comes right back on.
As far as I know the car has never been in a accident and I cleared all the codes with my snap-on scanner but these come back or wont go away.
any help is greatly appreciated.
07 ms3: cobb full exhaust, cobb TIP, ms intake, cobb v3 accessport, all 3 solid mounts, autotech pump internals,absolute BSD with pan baffle, egan racing coilovers with adjustable rear arms, rear strut brace, 13'' EBC slotted front rotors,
66 mustang nasa/uscca road course/autox race car.
68 mustang optima scc car.
68 mustang stocker.
broncomitch is offline   Reply With Quote
 Old 09-26-2019, 10:09 AM   #2
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
do you see the air bag light coming on separately and turning off while you put the key to on? I saw that some peoples mess with the cluster to by-pass alarm lights to sell a car or pass inspection and this would be a way to notice it unless they are very skilled to add electronic delay...
Usually the Uxxxx comes on with the connection of the AP
for the abs, you also need a magnetic wheel bearing to be installed on the right side to have the signal to work. you could have a gx bearing without abs or installed reverse. i would check continuity from the ecm harness to check if you have same resistance as the sensor to make sure prior to put money into a new bearing.
the steering bag is just held by some screw on the back, you may have a look there and see if you have a yellow connector too. even if there was no accidents, someone may have mess with an aftermarket sterring or just repair the car himself to pass under the carfax radar. (a good practice is to disconnect the battery first but if you have a snap on scaner i expect you would know that...)
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 09-27-2019, 07:42 AM   #3
the steering bag is just held by some screw on the back, you may have a look there and see if you have a yellow connector too. even if there was no accidents, someone may have mess with an aftermarket steering or just repair the car himself to pass under the carfax radar. (a good practice is to disconnect the battery first but if you have a snap on scaner i expect you would know that...)
Thanks for the reply,
The air bag light comes on when I turn the ignition to on then the light turns off for a second and comes back on.
I'll pull the airbag and see if I can find anything,a buddy of mine had the same code with his explorer and he just cleaned the contact points in the plug and that fixed it.
I will check out the wheel bearing tonight,it would be nice if that was my issue so I don't need to rip into the harness.
I checked all my fuses and the PJB last night but no issue stood out to me, checked all the contacts/connections also.
Wondering if my U1900 code is related to my C1234 code with the ABS sensor not reading.
68 mustang stocker.
 Old 09-27-2019, 01:18 PM   #4
Jeff23spl's Avatar
i'm not sure how you can easily test the bearing without removing it or not destroy it when removing it..... i never tried but even with the bearing in hands, the magnetic side isn't very strong...you barely feel it with a large screwdriver
Wife drive 2010 CX7
 Old 09-27-2019, 01:23 PM   #5
Sorry, I was meaning checking continuity from the ecm harness.
but I will look the hub over and see if it has been replaced recently.
68 mustang stocker.
 Old 10-14-2019, 08:38 AM   #6
finally had some time to dig into the mazda.
I checked the wires running from the sensor to the ABS ECM and everything was good there.
suspecting its the wheel bearing
I tried to clean it off but no go, I did find that a small screw driver will stick to it.
as for my U code's,
I found a mess of splices from one of those used car dealer security systems, removed all of that and they all went away apart from the (U2064 WARNING INDICATOR REQUESTED BY ANOTHER CONTROL MODULE)
witch should be related to the accessport.
and I removed the air bag and didn't find anything out of the norm.
I tested all the controls and everything works except the curse control (set) button and obviously sense it won't set the speed I couldn't test any other function but it dose turn on (light on the dash).
68 mustang stocker.
 Old 10-14-2019, 09:01 AM   #7
The mess
68 mustang stocker.
 Old 10-15-2019, 06:09 AM   #8
Jeff23spl's Avatar
The cruise don't work if abs light is on.
Buying used is one of my fear to get a wiring harness tempered with, some peoples want to install anything and even if it is done properly, there is no plans of the work done...
Wife drive 2010 CX7
 Old 11-21-2019, 07:51 AM   #9
OKAY!
I finally have everything fixed so figured I would post up the problems.
"INSTRUMENT CLUSTER MODULE-ICM MEMORY
U2516 CAN WIRING HARNESS OPEN OR SHORT."
FIX (found a wire that was spliced into to run sub woofer/amp junk)
"U2064 WARNING INDICATOR REQUESTED BY ANOTHER CONTROL MODULE"
FIX (this is from the AP)
"PASSENGER JUNCTION BOX-PJB MEMORY:
U1900 ABS CAN COMMUNICATION BUS FAULT."
FIX (Fixing the splice from U2516 fixed this also)
"B2212 PANEL DIM SWITCH OUT OF RANGE."
FIX (the LED on the dim switch was burnt out.)
"ANTILOCK BRAKES-ABS MEMORY
C1234 RIGHT FRONT WHEEL SPEED SENSOR INPUT MISSING"
FIX (I tested everything so replaced the wheel bearing and that fixed it)
"AIRBAG-AIRBAG MEMORY
B2232 AIRBAG CIRCUIT OPEN-LOOP 2: DRIVER SIDE"
FIX (I tested the clock spring and found a open loop, so replaced it and the air bag light turned off)
I now have all the lights on the dash off and no bad codes!!
68 mustang stocker.
The Following User Says Thank You to broncomitch For This Useful Post:
Jeff23spl (11-21-2019)
Saudi Arabia finally allows women to drive Haltech Automotive News 0 09-26-2017 02:00 PM
BMW M5 finally getting all-wheel drive, can be switched off Haltech Automotive News 0 05-17-2017 11:00 AM
Ford finally issues recall for 230K minivans over rust problems Haltech Automotive News 0 03-10-2013 09:20 AM
Head Rebuild and Valve clearance issues tkephart MazdaSpeed 6 - Engine, Transmission & Driveline 14 10-05-2012 12:46 PM
Finally!! Addressing issues with Heatsoak! Race Roots MazdaSpeed 3 - Engine, Transmission & Driveline 78 09-10-2009 09:48 AM
Page generated in 0.30119 seconds with 22 queries
