 Old 11-18-2013, 12:59 PM   #1
SpecialK's Avatar
Posts: 830   (View Stats)
SpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the world
Default Fuel Rail pressure Sensor
Hello all,
I recently bought a used 2006 Mazdaspeed6, love it and it is such a sleeper. However I pulled the battery to install the right tray in it since it had a aftermarket universal one in it and i got a CEL for the fuel rail pressure sensor. I towed it to my trusted shop and they have identified the culprit to be the fuel rail pressure sensor. I have been looking and searching for about 6 hours now trying to find this damn sensor with out buying the whole damn fuel rail assembly for over 1000. Does anyone know of a resource that i can find just the sensor? Any help would be greatly appreciated.
Thank you,
Colin
SpecialK is offline   Reply With Quote
 Old 11-18-2013, 01:04 PM   #2
dale_gribble's Avatar
Posts: 4,720   (View Stats)
first off, how is the car running? If you reset the ECM, does the CEL come back?
It isn't a common failure.
I checked my references and found 'SENSOR cannot be serviced separately because of structural problem. Please order by Assembly No.' That isn't a common note, so it must not be separable. If you have to replace, you may want to look for a used fuel rail on eBay or wreckers.
MINI H1 6.0 - CAR LED TAILS
 Old 11-18-2013, 01:09 PM   #3
SpecialK's Avatar
Car runs like shit, studders at WOT and is incredibly rich. Reset the ECM and it came right back.
Also, my mechanic put a variable rate resistor inline with the FPS and was able to modulate the resistance and the car ran great so it is the Fuel rail pressure sensor. I was able to pull out the fuel rail pressure sensor and clean it it was pretty easy to do.
This is what i think i need
Last edited by SpecialK; 11-18-2013 at 01:09 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-18-2013, 01:12 PM   #4
Thing is a Bosch unit, doesn't it have a number on it you can reference to order/cross-reference?
 Old 11-18-2013, 01:13 PM   #5
SpecialK's Avatar
Well i found that picture here:
Fuel Rail High Pressure Sensor Upgrade
 Old 11-19-2013, 08:39 PM   #6
GabSev's Avatar
Posts: 5   (View Stats)
GabSev will become famous soon enough
the sensor is a Bosch, High Pressure Sensor # 0261545006 I'm having the same simtoms, the car idles fine ,but it does not have any power at WOT.
My problem began after intake man. replacement for a JMF manifold where the this sensor get relocated from it original fuel rail position.
My question is why the AccPort shows that there is "0" pressure from the HPFP and "0" volts at the sensor?
GabSev is offline   Reply With Quote
 Old 11-20-2013, 06:48 AM   #7
SpecialK's Avatar
Well thankfully one the members here covered my rear end and sold me one of his spares. I'll look into what my reading are with the bad sensor and then the good sensor and let you know GabSev.
Sent from my SCH-I545 using Tapatalk
2006 Mazdaspeed 6 Zoom Zoom Boom Feb/2014 - fixed 3/30/2014
Motor:
2012 Block / V2 AP / Autotech HPFP / HTP 3" intake / AEM dryflow filter / Fidanza Flywheel / NGK 6510 Step Colder Plugs / TurboSmart BPV / Catless M2 DP / JBR SSP / CPE RMM
Suspension:
Poly SwayBar Bushings / CP-e Rear Diff Mount / BC Coilovers / 245/40/18 on 18x8" RX8 Wheels
Visual:
25% Tint On All Windows / 25% Tint Side Markers / Front Grill Plasti-Dipped Black / Stockers Plasti-Dipped Black / Black Mad M on Trunk / De-Badged / Heavy Shift Knob
Fluids:
Motocraft gold in gearbox / Redline in TC and diff / Oil - Rotella T6 /
The Following User Says Thank You to SpecialK For This Useful Post:
GabSev (11-22-2013)
 Old 11-21-2013, 02:55 PM   #8
SpecialK's Avatar
Okay we I still need a sensor, the one I got is bad. Do you know where I can pick up another sensor?
Motor:
Suspension:
Visual:
Fluids:
 Old 11-21-2013, 03:41 PM   #9
SpecialK's Avatar
Will a 07 mazdaspeed3 sensor work for my 06 ms6?
Motor:
Suspension:
Visual:
Fluids:
 Old 11-21-2013, 04:22 PM   #10
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Probably it will, apart from minor tweaks to the ECU software (and eventually some different electronics to deal with the automatic transmissions AND the smaller turbos for the CX7 A/T) these engines are identical. So MS3 and MS6 should have identical parts in the engine.
The reason mazda sells the entire fuel rail if you only need the sensor is that they have a special and very precise procedure of putting and sealing that sensor into the fuel rail. They do not recommend changing only the sensor because if the fitting is imprecise that may lead to various issues (since the pressures attained there are pretty big).
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 11-21-2013, 04:24 PM   #11
SpecialK's Avatar
Probably it will, apart from minor tweaks to the ECu software (and eventually some different electronics to deal with the automatic transmissions AND the smaller turbos for the CX7 A/T) these engines are identical.
That makes sense how ever many people have had good luck just replacing the sensor. Btw how positive are u that the ms3 sensor will work in an ms6?
Motor:
Suspension:
Visual:
Fluids:
 Old 11-21-2013, 05:15 PM   #12
timjs's Avatar
Posts: 908   (View Stats)
timjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the world
They are ALL interchangeable on all DISIs.
I have a couple spares, PM me if interested.
'06 Mazdaspeed 6
timjs is offline   Reply With Quote
 Old 11-22-2013, 06:20 AM   #13
GabSev's Avatar
Thats correct. The fuel rail I got from the junkyard was from a '07 CX-7, I called Mazda before I purchased the rail and confirmed that all DISI parts are in fact interchangeable.
Hey timjs, I sent you a PM regarding the spare sensors.
 Old 11-22-2013, 08:47 AM   #14
timjs's Avatar
@SpecialK; here is a datalog I took this morning on my way to work. This is the sensor I'll be shipping to you.
I'm on my laptop and don't have a way to view .csv files, so disregard any anomalies in that log haha..
Edit: Attached picture per forum rules.
@GabSev; they were spoken for. I'll let you know if I have another, I'm not sure without checking.
'06 Mazdaspeed 6
The Following User Says Thank You to timjs For This Useful Post:
GabSev (11-22-2013)
 Old 01-09-2018, 01:08 PM   #15
dontupp's Avatar
Posts: 2   (View Stats)
dontupp has a little shameless behaviour in the past
DO YOU STILL HAVE A SPARE?
dontupp is offline   Reply With Quote
 Old 11-21-2013, 06:36 PM   #16
GabSev's Avatar
I picked a sensor from a junkyard and no luck I still read “0” actual fuel pressure and “0” volts at the sensor. How is that some of you have spare sensor? I’m having a hard time finding a new one since the used one was bad, they sell them in England for about $280. Does anyone knows were to buy this sensor in the States? I just wan t to make sure that the bad sensor is what is causing the “0”PSI at the HPFP reading on the Cobb’s Access Port.
 Old 12-13-2013, 04:29 PM   #17
Andjo's Avatar
Posts: 937   (View Stats)
Andjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the world
So is there a how to on hooking up one of the diesel fuel pressure gauges?
GT3076 and supporting mods with Kozmic Motorsports Built motor and tune
FUTURE MODS: 6266 with V-Band everything
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
2013 TROLL CHAMPION "DYLANFYHN"
Andjo is offline   Reply With Quote
The Following User Says Thank You to Andjo For This Useful Post:
ccspeed3 (12-13-2013)
 Old 01-09-2018, 01:41 PM   #18
kTaLgsTo's Avatar
Posts: 566   (View Stats)
Threeish years old...
And you come in as captain capslock
Possible Fuel Rail Pressure sensor failure? AFcadet MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 07-06-2012 04:17 PM
fuel rail pressure sensor Skup1993 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 3 02-05-2011 09:14 PM
Page generated in 0.38375 seconds with 28 queries
