 Old 06-19-2018, 06:52 PM   #1
Fulkrum's Avatar
Posts: 9   (View Stats)
Fulkrum is an unknown quantity at this point
Default Heavy Stumble Only After Prolonged Deceleration
I purchased my second speed3 last weekend. 2008 Gen1 CAI, Catless Pipes. When I drove the car a week before it ran really well. The dealer put new lower control arms in the rear last week and i picked it up in Tamps Sunday. I drove the car from Tampa to Savannah (300 miles) and it stumbled horribly most of the way. Strangely it only stumbled after a hard deceleration or braking. It would stumble for 3-8 seconds and clear out fine. Its running on 2-3 cylinders during this time. I initially thought it was some condensation built up in the tank sloshing around and getting picked up by the LPFP. I have since run 2 tanks through her with a can of heat water remover. I investigated the car once i got it home and found that the dealer neglected to plug in the EVAP tube on the canister when they removed the lower control arm pivot bolt. This was loose for about a 300 mile drive. Its the line that goes to the purge valve and into the intake. This may be unrelated to the stumble. I've driven the car about 50 miles with the tube connected and it hasn't changed anything. It is throwing (2177 System too lean off idle) (p2187 system too lean at idle bank 1) (P2097 Post catalyst fuel trim system too rich bank 1) (P0401 Exhaust gas re circulation flow insufficient detected)
I think a few of those were likely from the EVAP being disconnected. Like i mentioned its a new car to me so i'm unsure if those codes were there due to the catless downpipe (which has both 02 sensors in their bungs).
Any help or pointers would be greatly appreciated. I have a perfect running 2009 I wrecked 3 weeks ago so I have parts I can swap from it easily. Thanks
Fulkrum is offline   Reply With Quote
 Old 06-19-2018, 07:59 PM   #2
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
Catless, and no tune?
 Old 06-19-2018, 08:27 PM   #3
Fulkrum's Avatar
It has the CNT Catless. I'm not sure of the tune. Looks like the pipe was just put on, it looks new. Too loud for me though. The torque curves feel a lot different than my mostly stock 2009. This one has the stock plastic intake and a big catess pipe. Factory TMIC. Need to investigate HPFP Internals as described in a million threads. Ive got the original owners name yesterday, ill reach out and see about the tune and HPFP internals. I'm working on getting Torque Pro Setup tomorrow so i can check FP pressures.
 Old 06-20-2018, 07:18 PM   #4
Fulkrum's Avatar
Update. HPFP pressure at idle cold 500. 3-7k rpm pull wot ranged from 1650-1780 through the pull. I’m thinking the fuel pump system is working properly. Swapped the maf sensor for shits and giggles. No change. On to the next possibility.
 Old 06-20-2018, 07:36 PM   #5
JSmith's Avatar
Groans: 106
Do you have any way to datalog?
 Old 06-21-2018, 05:26 AM   #6
Fulkrum's Avatar
JSMITH, I’m capable to graph up to 7 sensors. Which sensors would be most valuable?
 Old 06-21-2018, 10:24 AM   #7
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Did you clear the codes and see if they come back? System lean code might be resolved with a new purge valve. You can get one cheap on Rock Auto.
A word of caution: do not install any aftermarket MAF sensors. They just don't work in our cars. You must use OEM.
Check plugs and gap.
 Old 06-21-2018, 12:12 PM   #8
Carskick's Avatar
Posts: 315   (View Stats)
Carskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond repute
Make sure intake & Boost tubes are all tight. Unmetered air getting in or boost leak can cause some of the problems you describe.
Clean or replace MAF with OEM as suggested. A datalog may help determine if it's reading correctly or not.
I'm confused as to how you are getting some of the data, do you have an AP or something? If so, post logs. Otherwise, how do you know HPFP pressure and the like? Can you check for knock, boost cuts, etc?
If you plan on going pro tune, get an AP now, which will help you diag these problems.
I encountered the EGR issue at around 60k, and I thought that was causing power issues, but it turned out to be a leaky intake. I found this out after replacing the EGR, which was expensive. Probably just needed to be cleaned.
Too lean and too rich errors sounds like a sensor is off somewhere. Or there are a bunch of mods and no tune. Or both!
2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting
Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings
Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub
Other Mods: FIAMM 72112 Low Note Horn alongside stock
Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot
Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB
Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks
Carskick is offline   Reply With Quote
The Following User Says Thank You to Carskick For This Useful Post:
Fulkrum (06-21-2018)
 Old 06-21-2018, 01:49 PM   #9
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
It is really looks like a modded car that the previous owner removed the AP with the tune and left the parts he wasn't able to remove or stock out easily...
Check maf and map part #. Check the maf hosing internal size.
For sure a leak will affect the fuel trims so a boost leak test is a good place to begin with.
Leaking injectors could also give troubles but it would usually settle back under boost after being worst at cold start.
It isn't bad to install new plugs, a speed need them to be replaced often
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 06-21-2018, 04:31 PM   #10
Fulkrum's Avatar
Thor, yes I’ve cleared them a few times.
I’ve swapped the following from my wrecked perfectly running 2009.
Maf sensor -factory mazda-
Swapped Coil packs, -changed plugs while I was in there.
Swapped evap Purge valve
Confirmed fuel pressure is normal during the “stumble event”
Any other ideas? Thanks for your help.
Checked for vacuum leaks
I will be swapping the catless pipe for a stock one , 02 sensors, and egr valve this weekend.
Jeff, that has crossed my mind. I have a unmolested 2009 ecu I can swap into it. Do you think that would work or be worth a try?
Last edited by Fulkrum; 06-21-2018 at 04:31 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-21-2018, 04:45 PM   #11
Fulkrum's Avatar
Carsick- I’m using OBD auto doctor. I can map up to 7 sensors graphically. The attachments -60 mark is second gear shifting into 3r then wot at the -57 mark (3-6krpm). Then a full deceleration off of an off ramp. What sensors would make this data more valuable? Thanks for your help~
File Type: jpeg CB54D9A1-8A30-4F1E-9EE6-70AB2FC67DF8.jpeg (701.9 KB, 4 views)
 Old 06-21-2018, 05:49 PM   #12
Fulkrum's Avatar
Here are some fresh graphs from tonight. Descriptions are in them.
4th gear pull map,rpm,go, afr
4th gear pull with fuel trim and afr
2k rpm cruise
Idle
 Old 06-21-2018, 08:51 PM   #13
Jeff23spl's Avatar
the ecu work with cluster and keys so you would need to try all at once or reprog but i would instead just look at your map part # and compare with the 2009
Wife drive 2010 CX7
 Old 06-22-2018, 03:19 PM   #14
Fulkrum's Avatar
Jeff- both cars have the same map sensor l3k9 18211a made in Germany.
 Old 06-23-2018, 03:36 PM   #15
Fulkrum's Avatar
Jeff- I’ve coamfirmed that it was put back to almost stock after modding. The Ecu harness Mount was hacked off to make room for a non stock cold air intake.
I found the issue while installing my CP-E turbo inlet pipe. The last owner didn’t orient the clamps correctly on the cold air intake. The clamp head had literally carved out an wore the insulation off of about 5 wires in the main ecu harness. Rookie fail. This explains why the car only stumbled after deceleration. The engine would move and the clamp would ground out the multiple wires
exposed. Unreal. Car runs great at the moment going to take her out for a cruise and confirm root cause. See pics attached~
Thanks for everyone’s help.
File Type: jpeg 1FE4DE02-0BE3-498D-A6E5-DF11047E6EC9.jpeg (1.98 MB, 3 views)
File Type: jpeg C69CB4DD-8FF6-4A2D-BF24-5CE9780DD24F.jpeg (1.68 MB, 3 views)
 Old 06-26-2018, 06:19 AM   #16
Jeff23spl's Avatar
Glad that you figured out.
It would be hard to imagine this could happen without seeing it.
Wife drive 2010 CX7
Clunking upon deceleration Stingray69 Gen2 MS3 General Discussion 4 08-11-2016 12:44 AM
popping out of 2nd and 3rd on deceleration mustrick MazdaSpeed 3/6 - Troubleshoot/Diagnostics 1 07-29-2014 11:37 AM
Noise - Acceleration and Deceleration SPEED3 Atomic41 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 18 05-26-2014 04:54 PM
Fiat forecasts prolonged European slump as regional quarterly losses grow Haltech Automotive News 0 10-30-2012 09:40 AM
Saab Auto unions may push bankruptcy in prolonged delay of wages Haltech Automotive News 0 08-24-2011 10:00 PM
Page generated in 0.35150 seconds with 25 queries
