 Old 03-11-2014, 10:57 PM   #1
ms3steeez's Avatar
Posts: 312   (View Stats)
ms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the world
Default Help would be much appreciated
So up until now i've gotten by with searching and reading, but I can't seem to find anything like what's going on now. Was hoping maybe someone could point me in the right direction.
This just started happening on my way home from work. When I try to take off from a light, all the lights flicker, the radio turns off, the dash lights up like a Christmas tree, and then everything returns to normal. No cels, smooth idle and power. Holding steady - 20 psi at idle. It only does it as I let the clutch out. (I know, it sounds like i'm stalling, but I assure you that I'm not) it even did it as I was gearing down. Its weird though, because it only does it when I'm going slow (just starting, or coming to a stop)
I already checked the battery and the connections are tight, no corrosion either. Checked for bare spots in the writing harness, noticed none.
Sent from my VS980 4G using Tapatalk
FreekTuned GT3076R, M2 catless DP, CS HPFP internals, Custom 3.5" intake, Custom 51R battery box, Grimmspeed 3 port EBCS, CS shifter bushings, RA mudflaps, TurboXS core w/ custom piping, Devils Own 100% meth injection, JBR 88 RMM, Denso ITV22, CPE Safeseals, JBR EGR delete, Forge V1, Hawk HPS pads, VCTS Delete, 3 bar map sensor, kozmic primary EGR delete (391 whp on Vdyno, ZZB 12-17-14)
Build in progress
.020 over block, pinned and keyed, wiseco pistons, manley H beams, SP63 head w/ intake and exhaust ports, and mild bowl work. DM TB spacer, L19 studs, XSpower V1 mani, CNT catback, ACT 6 puck w/ streetlight flywheel, CS injector seals, Clevite main and King rod bearings, redefined performance PCV plate, PTP oil pan baffle w/ JBR BSD, 4 bar map sensor
ms3steeez is offline   Reply With Quote
 Old 03-11-2014, 11:04 PM   #2
ms3steeez's Avatar
Wiring*
Build in progress
 Old 03-11-2014, 11:20 PM   #3
btstarcher's Avatar
Posts: 4,852   (View Stats)
Loose connection somewhere, probably either the battery terminals or a ground.
SnailTune in progress
 Old 03-11-2014, 11:22 PM   #4
ms3steeez's Avatar
I haven't had a chance to check any grounds, the terminals are tight, and corrosion free
Build in progress
 Old 03-11-2014, 11:52 PM   #5
Cirruslydakota's Avatar
Posts: 262   (View Stats)
Cirruslydakota is the leader of the worldCirruslydakota is the leader of the worldCirruslydakota is the leader of the worldCirruslydakota is the leader of the worldCirruslydakota is the leader of the worldCirruslydakota is the leader of the worldCirruslydakota is the leader of the worldCirruslydakota is the leader of the worldCirruslydakota is the leader of the worldCirruslydakota is the leader of the worldCirruslydakota is the leader of the world
Check the output voltage and amperage of the alternator. I just went through this with my wifes 05 Focus ST as the voltage regulator took a shit and was putting out 18-19 volts when revved up. Idle it sat around 14.5. Taking off from a stop light the gauges would go nuts, along with the radio, and interior lights.
Cirruslydakota is offline   Reply With Quote
The Following User Says Thank You to Cirruslydakota For This Useful Post:
btstarcher (03-12-2014)
 Old 03-11-2014, 11:55 PM   #6
ms3steeez's Avatar
I'll definitely check that out, thanks a lot guys
Build in progress
 Old 03-12-2014, 12:22 PM   #7
ms3steeez's Avatar
I just drove it today, and everything was perfect. Had none of the symptoms from last night. Only thing that bothers me is the fact that cars don't fix themselves, and I'm sure it'll be back...when is the question now lol
Build in progress
 Old 03-15-2014, 03:39 PM   #8
Caldazar's Avatar
Posts: 293   (View Stats)
Caldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond repute
sounds like it could be either a wiring harness connector coming partially loose due to the engine torqueing back and forth when letting the clutch out, or a wiring harness rubbing thru its insolation from the same movement.
This sort of diagnostic work can be very time consuming and frustrating. It can also be super easy if you spot it quickly. Best of luck.
06 Speed6, camber balljoints and alignment, HankookV12 Evos, Konigs, Corksport full intake system, PTP pump internals, Cobb Ap, Forge BPV. Daily driver
91 Talon TSi, 5spd AWD, GT3076R, fmic, 3" exhaust, Jackal EMS, methanol injection, JIC C/O and more. Looking at 10's
Caldazar is offline   Reply With Quote
 Old 03-19-2014, 08:27 PM   #9
Westy's Avatar
Posts: 40   (View Stats)
Westy is just really niceWesty is just really niceWesty is just really niceWesty is just really nice
I'd agree with the alternator theory...rpms dip when letting clutch out sometimes, maybe it's enough to drop the output voltage below the needed threshold?
Sent from my Nexus 7 using Tapatalk
'07 Cosmic Blue MS3: APv2, Cobb stage 2 map, HPFPupgrade.com internals, Corksport stage 2 TIP & SRI, Cobb DP, HKS CBE, Synapse Synchronic DV BPV, CorkSport FMIC, Mazdaspeed springs & camber arm kit, JBR RSB, Sure short shifter plate & anchors, SU RMM: haven't dynoed yet.
Westy is offline   Reply With Quote
 Old 03-19-2014, 10:04 PM   #10
ms3steeez's Avatar
Its only done it that one night, has ran great ever since *knock on wood*
Build in progress
4th Log, Input appreciated KayWhy 2010 MS3 - ECU Computer Tuning 3 01-28-2014 03:16 PM
1st log! Any input appreciated NCZ13 MazdaSpeed 3/6 - ECU Computer Tuning 8 09-17-2011 09:20 PM
Any type of help appreciated. popester112 MSP - Turbo Induction 13 08-31-2011 03:41 AM
Much Appreciated Airman3454 Gen2 MS3 General Discussion 23 06-10-2011 03:14 PM
Any help would be appreciated...UR TP miztigerszou52 2010 MS3 - Engine, Transmission & Driveline 4 05-18-2010 08:25 PM
Page generated in 0.29674 seconds with 24 queries
