| MazdaSpeed 3/6 - Troubleshoot/Diagnostics MazdaSpeed 3/6 - Troubleshoot/Diagnostics - Have a problem with the car? CEL Code? Want to discuss other issues? Come on in! |
![]() Join Date: Dec 2011 Location: Orland Park il
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 99
(Thread Starter) | Not Ranked : 0 score Second opinions ?
__________________ GT3076/ catless dp/ FMIC/ 3.5" CP-E Intake/ 3" Exhaust/autotech internals/ built block/ 3-port/denso itv22/ 6th-port |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
Sent via blown passenger side speakers.
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress | |
(Thread Starter) | Not Ranked : 0 score Alright will post one soon
| Not Ranked : 0 score yes logs or it didn't happen...just lick pics
| The Following User Says Thank You to Dano For This Useful Post: | Rokusek (07-24-2013) |
(Thread Starter) | Not Ranked : 0 score here is a log i just did and i also forgot to mention that i also have a rich idle and part throttle is becomes rich as well. and random over boost. ill post up another one. datalog1.csv
| Not Ranked : 0 score I am assuming this car is tuned from the mod list? 8.8 sounds very rich for any tune even under KR. Post a log.
| Not Ranked : 0 score with that speed I am going to immediately assume you are losing traction and rich AFR would be normal with DSC active. even without DSC active SWAS will detect slight steering wheel movement and richen up afr to cut power. do a 4th gear log. edit: and yes even idle you are at 13AFR which is rich. LTFT is ~zero so I might assume this was a fresh flash on the ECU with STFT maxed at the amount of fuel it can pull. your maf cal is waaaay off.
EDIT: On top of this your HPFP pressure is dropping under boost (due to the excessive boost down low) and it looks like you are getting a cut as well. I would not do any more logs before this is sorted out because on a stock block this is a clear recipe for venting it.
| The Following 4 Users Say Thank You to Lex For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score speed6 bro and ill go do a 4th gear log
| Not Ranked : 0 score ok "bro" see my other post. your maf cal is way off. ecu is pulling 25% fuel at idle. and lex is right you are about to vent your block with 30psi @ 3500RPM
| Not Ranked : 0 score Read what I said before it blows.
| Not Ranked : 0 score in before OPs next post is this. this would explain the uber rich AFR due to bad maf cal.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 07-24-2013 at 10:29 AM. Reason: MSF Database - Automerged Doublepost |
(Thread Starter) | Not Ranked : 0 score alright need to update sig but mods are 3.5in intake, built block, stock turbo, 3 in catless exhaust, grimmspeed 3port boost controller, fmic, denso v24 spark plugs fp internals think thats all
| Not Ranked : 0 score whatever you do, do not go WOT again until your boost is under control...even on a built block. from your logs you need a complete tune and I would get back to spring pressure only until the issues are resolved.
(Thread Starter) | Not Ranked : 0 score alright thanks ill see if i do more maf cal it was the same map as before the built block and no problems and ill see if that will change anything.
| Not Ranked : 0 score Dano's correct, your boost control is probably setup incorrectly. The car needs a tune badly.
| The Following User Says Thank You to Lex For This Useful Post: | Rokusek (07-24-2013) |
IIRC lex has a ton of multipliers posted for various intakes that you could start with or maybe it was just maps with starter maf cals. I think (don't quote me) but for me going from OEM to 3.5 was a 1.65 multiplier for pump gas which got me real close. Edit: you can quote me it was 1.67 with some tweaking at WOT
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
__________________ GT3076/ catless dp/ FMIC/ 3.5" CP-E Intake/ 3" Exhaust/autotech internals/ built block/ 3-port/denso itv22/ 6th-port | |
![]() | | #19 | ![]() |
| Approved MSF Vendor ![]() Join Date: Jan 2012 Location: Maryland, USA
Rep Power: 884 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,286
| Not Ranked : 0 score Did you have the 3-port before the build? Is it currently in 3-port mode? Was it before the build?
__________________ --- 2011 Black Mica MS3 Tech --- ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following User Says Thank You to Mike@Stratified For This Useful Post: | Rokusek (07-24-2013) |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah I did have it before the build and it is set in 2 port and the third as the bleeder
![]() | | #21 | ![]() |
| Not Ranked : 0 score pull the power lead to your EBCS and carefully test by giving it some gas and monitoring boost. if its plumbed correctly you will hit around 10psi max IIRC on a K04 and you will know you are good to start tuning AFR and won't blow the motor up. if boost still skyrockets then you have a line off to the WGA or other plumbing issue. if you are catless it might creep up at WOT as RPMs rise but shouldn't get out of control but its something to watch.
| The Following User Says Thank You to Dano For This Useful Post: | ciezczak1 (07-24-2013) |
| KR Spike/Super rich at WOT | sidekick | MazdaSpeed 3/6 - ECU Computer Tuning | 30 | 07-26-2012 05:43 PM |
| Rich KnocK? | kahunab14 | MazdaSpeed 3/6 - ECU Computer Tuning | 7 | 04-16-2011 08:36 AM |
| rich knock? | Wenis Prinkle | Cobb ATR Support | 41 | 09-01-2009 06:19 PM |
| Super rich may avoid super expensive cars because of bad image | Haltech | Automotive News | 0 | 10-02-2008 06:10 PM |
