 Old 11-28-2015, 01:33 AM   #1
andrew1501's Avatar
Posts: 18   (View Stats)
andrew1501 has a spectacular aura aboutandrew1501 has a spectacular aura aboutandrew1501 has a spectacular aura about
Default High pressure fuel pump issues
Hey guys,
diagnosing a pressure issue for another local speed owner. Hoping someone can help me out a bit.
His Car: speed 6
HPFP: Gen 1 speed 3 used pump, autotech internals.
Story: guy claims car is running weird, he sends me a 4th gear WOT log. All parameters look within target except the HPFP act. pressure only hits around 1500psi or so at 2.9k RPM,then drops incrementally down to 1100psi through the power band towards 6k RPM. He had already replaced his pump (with the used one listed above) saying it would only hit 400psi max.
He has cleaned the pump very thoroughly, checked all seals, and checked the spill valve.
Now, this is all via messenger as I'm short on time to help in person. Was hoping maybe some of this would sound familiar to some of you, or may trigger a direction I can tell him to check next. Because at this point, he's wanting to send the injectors off, put new injector seals on, replace the in tank pump, all at once, and Obviously all of that isn't necessary.
Any thoughts guys? Remember he has new autotech internals that he's cleaned twice now. Lubrication issue? Sound like a hindered seal maybe? Just trying to gather some opinions before I waste a day tearing through this thing.
Thanks guys
andrew1501 is offline   Reply With Quote
 Old 11-28-2015, 01:38 AM   #2
btstarcher's Avatar
Posts: 4,852   (View Stats)
Has he tested the relief valve? Can't remember the exact steps except that it involves monitoring (logging) while idling and shutting the car off to see what happens to pressure.
SnailTune in progress
MD1032 (11-28-2015)
 Old 11-28-2015, 11:38 AM   #3
andrew1501's Avatar
so he says.. if there's a specific method in testing it you guys know and i don't i'm all ears. Forgot to mention i'm forced to believe everything he says since i'm not there to verify in person..
 Old 11-28-2015, 11:55 AM   #4
robbspeed's Avatar
Posts: 1,074   (View Stats)
robbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the world
Groans: 50
If this guy wants his problem solved so badly why doesn't he create an MSF profile and work us directly? Why go through a friend? Unless he's been banned or did some other dumb shit.
2011 Mazdaspeed3 w/ tech package
Totaled/ R.I.P.
robbspeed is offline   Reply With Quote
 Old 11-28-2015, 02:17 PM   #5
andrew1501's Avatar
He asked me first that's why. Never mind I'll figure it out.
The Following User Says Thank You to andrew1501 For This Useful Post:
btstarcher (11-28-2015)
Fuel pump pressure (high) Illusion Gen2 MS3 General Discussion 9 05-25-2012 11:40 AM
Opinion On High RPM High Pressure Fuel Pump Spring ms3brendan MazdaSpeed 3 - Engine, Transmission & Driveline 1 07-13-2010 01:04 PM
Page generated in 0.25439 seconds with 22 queries
