  • 2 Post By phate
Closed Thread
 Old 11-02-2012, 06:51 AM   #1
rednofive's Avatar
Posts: 250   (View Stats)
rednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the world
Default Knocking sound from engine
I was driving in to work today and I got on it.
after I slowed down at a light almost at my work locatin, I started hearing a faint knocking sound, like a diesel tractor.
it got louder.
It modulated with my pedal.
FUCK, that sound is me.
I drove into work about a 1/4 mile while staying out of boost
Now I'm at work and I don't know what to do. I'm 18 miles from home.
It's about 40F, I'm running exactly what my signature says (but my last fill-up was with BP 93 octane) and my monthly pull logs from just a week or so ago show 1600-1700 PSI on the stock pump.
I've never had a car that did this, but it sounds like a dead cylinder.
I've attached a wav-file recorded from my phone while my coworker stood over the open engine while it idled.
I moved the R's to about 2K RPM so the knocking is more noticeable (you can hear that around 15 seconds in the recording).
the car starts OK (I stopped and restarted), though very slightly slower than usual.
I don't know that to think yet and I don't know what to do?
current thoughts are:
best-case, maybe a plug wire came lose or a plug went bad somehow and I'm not firing on one cylinder?
worst-case, I blew a gasket or something interfered or got destroyed by detonation. maybe the cause was a stock HPFP that failed in the past 2 weeks since my last log or maybe the 40F temp just wasn't well characterized in the Cobb 93octane maps or maybe just some fucker at BP decided to pump me some shitty gas.
well, I'm probably only going to be able to blaime myself for not dialing the car back to 91octane, but I've been logging a lot all summer and fall and haven't seen any KR above 0.35 to 0.7, so oh well.
I'm afraid to run it more.
should I tow it home?
should I tow it to the dealership? I've got 53K miles and the mods shown in my sig, so if I show up at the dealership, should I first unmod the intake and return the maps to stock with the AP?
I think they saw the intake the last time I was in for oil/rotation, but they've always been pretty cool and even told me the mod was fine (before I did it) and safe.
should I start it up and try to get some kind of useful log data from my AP?
advice would be appreciated.
Forget coffee...I get my morning boost in 4th at 5K!
2008 Black Mica MS3
Mazda RX-8 50mm ET 18"x8" Dupli-color Graphite/Clear with 245/40/18 Continental DWS No-season Tires
CS SRI | CS TIP | TMIC | HPFP
CP-E RMM
JBR SSP (30%) | JBR SSB | JBR RSB
Koni Yellows on stock springs
rednofive is offline
 Old 11-02-2012, 07:13 AM   #2
kish89's Avatar
Posts: 292   (View Stats)
kish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the world
Clutch pedal vibrating?
Sorry man but it sounds like a bent rod...
06 MS6, Versatuner, Stratified Tuned
BNR Stage 3 turbo, Eagle con. rods, HTP Full 3" intake + AEM DryFlow filter
Autotech HPFP internals, Forge V1 BPV
Custom 3" cat-back with stock mufflers, M2 3" catless Downpipe
Grimmspeed EBCS + Stratified Boost Dial, 3BAR BOSCH MAP
NGK Iridium IX one step colder plugs, CPE SafeSeals & studs
Custom FMIC with 2.5" piping and Treadstone TR8 IC
SnowPerfomance WMI, Stratified Guardian Angel
Eibach pro kit lowering springs
kish89 is offline
The Following User Says Thank You to kish89 For This Useful Post:
rednofive (11-02-2012)
 Old 11-02-2012, 07:18 AM   #3
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
You really just take a gamble with these motors
Sent from my balls via my penis
G26 is offline
The Following User Says NO Thank You to G26 For This Un-useful Post:
tddvrrn (11-02-2012)
 Old 11-02-2012, 07:20 AM   #4
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Uggggh
Modding ANY engine is a gamble.
helmetface is offline
 Old 11-02-2012, 07:26 AM   #5
vtekken's Avatar
Posts: 737   (View Stats)
vtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the world
Damn, that's rough... I would not run it, that just sounds like trouble. Demod, flash the stock tune, and tow it.
@phate @kabobulate @dbrier do you guys have any better suggestions?
2011 MazdaSpeed 3
RichTuned | Cobb SRI | Cobb TIH | SU TMIC | CS Racepipe | CS Downpipe | CS TMM Insert | KMD 2.1 | CPE Stage 2 RMM | ITV 22's |
Sent using VTEC
vtekken is offline
The Following User Says Thank You to vtekken For This Useful Post:
 Old 11-02-2012, 07:23 AM   #6
G26
G26's Avatar
Groans: 39
Originally Posted by helmetface View Post
Uggggh
Lol, I'd say it being turbo increases the odds of something happening.
G26 is offline
 Old 11-02-2012, 07:38 AM   #7
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
That doesn't sound healthy, sounds like something in the bottom end :/
Does it run roughly, and can you feel any vibration in the clutch pedal?
-06 MS6
-Corn fed 07 MS3 - Sold
phate is offline
 Old 11-02-2012, 07:49 AM   #8
rednofive's Avatar
Nothing weird in clutch pedal (feels the same as always).
No codes of any kind from the ECU (I just checked).
Runs smoothly. I mean that it starts great and idles fine, but I think I recall from my short limp to work that it doesn't accelerate very well (I was keeping the car between 10-20" vacuum, so no boost at all).
sounds exactly like this video, but not quite as loud:
https://www.youtube.com/watch?v=_0CBQcccLDM
2008 Black Mica MS3
CP-E RMM
 Old 11-02-2012, 07:44 AM   #9
I see in your sig that you are running an ots map with 25% e85. Have you noticed your afr's when running that mix?
rfinkle2 is offline
 Old 11-02-2012, 07:52 AM   #10
rednofive's Avatar
This tank is pure 93octane from BP.
Last night I was watching AFR's and boost for fun.
I was hitting 11.3-11.4 under WOT or at least very high WOT.
boost was 15 to 17PSI, exactly like Cobb says it should be for my car/mods/map.
I think I got too close to red-line in third gear and cold-air + and stock fuel-pump bit me.
un-believable.
2008 Black Mica MS3
CP-E RMM
 Old 11-02-2012, 07:49 AM   #11
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
+1 about feeling vibes in the clutch pedal
bent rod will (usually) translate to the crank & through the clutch. It's a pretty distinct feeling.
340hp / 371tq
TiGraySpeed6 is offline
 Old 11-02-2012, 07:49 AM   #12
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
That's a bent rod amigo.
Ive driven over an hour on two different engines with bent rods. I won't say you can make the trip because it's running on borrowed time
NATOR PA
MS3-a(sore)ASS-rex is offline
The Following 2 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
leon78 (11-02-2012), rednofive (11-02-2012)
 Old 11-02-2012, 07:50 AM   #13
Eth Fiend
phate's Avatar
Pete, if you decide to tow it home and do some diag, I'll drive over to help out.
My first thought was spun bearing
TiGraySpeed6 and helmetface like this.
-06 MS6
phate is offline
rednofive (11-02-2012), rfinkle2 (11-02-2012)
 Old 11-02-2012, 07:57 AM   #14
rednofive's Avatar
wow, you are truly a generous soul.
I don't want you to have to do that, but I appreciate any coaching you can give.
I will likely tow it home and swap out the intake, just in case, then restore the ECU to full-stock.
I believe this car has a 60K mile warranty on the drivetrain and I've done almost nothing to it and Mike at Tom roush is pretty cool.
I'm at 53K miles.
Think my odds are decent it'll be covered?
I can imagine no reason it wouldn't be.
2008 Black Mica MS3
CP-E RMM
 Old 11-02-2012, 08:07 AM   #15
Eth Fiend
phate's Avatar
There's no harm in trying to get it covered.
-06 MS6
phate is offline
 Old 11-02-2012, 08:24 AM   #16
dead-zone's Avatar
Posts: 442   (View Stats)
dead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the world
Groaned at 53 Times in 17 Posts
https://www.youtube.com/watch?v=NsCb...eature=related
Most likely that is your issue. If that car feels to be running ok but have the knock, sounds like a rod knock.
Edit: It looks like @phate is right, as usual
dead-zone is offline
The Following User Says Thank You to dead-zone For This Useful Post:
 Old 11-02-2012, 08:25 AM   #17
kabobulate's Avatar
Posts: 1,146   (View Stats)
kabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the world
My weekend is somewhat open. I'll PM you my number and come out to help with whatever you need. I would tow it and demod since you are under 60k. Don't give them an excuse to screw you. Not even a motor mount.
2012 CWP MS3: Tuned by Phate - 50/50 E85 | Cobb AP | SURE Intake, TIP | Corksport Racepipe, TMM Inserts | ITV22's | AT Intl's | ACT Sprung 6Puck & Prolite Flywheel | CP-E Stg2 RMM | JBR SSB, EGR Plate
2008 Silver MS3: Sold
kabobulate is offline
The Following User Says Thank You to kabobulate For This Useful Post:
 Old 11-02-2012, 08:25 AM   #18
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
If the only engine mods you have are intake/TIP and AP, stock out and take it to a dealer. I wouldn't run that engine any more personally; have it towed.
I agree with Clint, a noise that loud and muffled sounds like something deep down in the engine, and something big.
silvapain is offline
 Old 11-02-2012, 09:27 AM   #19
bwagers's Avatar
Posts: 184   (View Stats)
bwagers is the leader of the worldbwagers is the leader of the worldbwagers is the leader of the worldbwagers is the leader of the worldbwagers is the leader of the worldbwagers is the leader of the worldbwagers is the leader of the worldbwagers is the leader of the worldbwagers is the leader of the worldbwagers is the leader of the worldbwagers is the leader of the world
If you need another set of hands this weekend I'm free to come up.
2012 Black Mica - AP, JBR SRI, JBR TIP, JBR RMM, JBR EGR Delete, Res Delete, AutoTechs, UR TP
- Red Rally Armors, CS CF Hood Scoop
bwagers is offline
The Following User Says Thank You to bwagers For This Useful Post:
 Old 11-02-2012, 10:42 AM   #20
BBartley's Avatar
Posts: 166   (View Stats)
BBartley has a reputation beyond reputeBBartley has a reputation beyond reputeBBartley has a reputation beyond reputeBBartley has a reputation beyond reputeBBartley has a reputation beyond reputeBBartley has a reputation beyond reputeBBartley has a reputation beyond reputeBBartley has a reputation beyond reputeBBartley has a reputation beyond reputeBBartley has a reputation beyond reputeBBartley has a reputation beyond repute
I am not good at diagnosing issues but I have the garage open if you need some shelter.
2008 Silver MS3: Cobb AP - Corksport SRI & TIP - AT Internals -JBR 88 RMM -JBR SSP & Solid Bushings-JBR Rear Sway Bay -TurboXS Downpipe & Racepipe -ITV22's
BBartley is offline
The Following 4 Users Say Thank You to BBartley For This Useful Post:
bwagers (11-02-2012), phate (11-02-2012), rednofive (11-02-2012), TiGraySpeed6 (11-02-2012)
 Old 11-02-2012, 09:34 PM   #21
Z-Indy's Avatar
Posts: 1,815   (View Stats)
Z-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the world
Groans: 35
That sucks man. I don't have any additional input, these other guys are all way more knowledgable than me, but stocking out and towing it in sounds like the best plan.
2008.5 Black Mica MS3
Cobb AP and 30% E85 Dizzy Tune - Cobb SRI - CP-e RMM - JBR SSP & Solid Shifter Bushings - E4 heavy shift knob - Denso ITV22 plugs - 6000K HID lows - 3500k HID fogs - Ford XT-M5-QS Tranny fluid - RX8's (PC'd Anthracite) - Rubber hatch tray
It's not my fault I'm this way, I was homeschooled.
Z-Indy is offline
Closed Thread
Knocking sound on driver's side DylanFYHN MazdaSpeed 3/6 - Troubleshoot/Diagnostics 40 10-03-2012 11:48 AM
Knocking/ clicking sound from under car/ driver side Zbrit00x Gen2 MS3 General Discussion 8 08-23-2012 09:16 AM
full motor mount install.... now have knocking sound peter_parker8740 2010 MS3 - Engine, Transmission & Driveline 2 06-20-2012 06:21 PM
Knocking sound w/ video... RiceBurn2.3T CX-7 > Issues & Troubleshooting 54 08-03-2011 07:27 PM
knocking sound on acceleration, not ABS bzwyatt CX-7 > Issues & Troubleshooting 5 12-15-2010 07:05 AM
Page generated in 0.43125 seconds with 35 queries
