 Old 09-19-2019, 12:02 AM   #1
BR1JZL's Avatar
Posts: 40   (View Stats)
BR1JZL is a splendid one to beholdBR1JZL is a splendid one to beholdBR1JZL is a splendid one to beholdBR1JZL is a splendid one to beholdBR1JZL is a splendid one to beholdBR1JZL is a splendid one to beholdBR1JZL is a splendid one to behold
Default Leak down Test
Hi all,
So after my epic journey with this car, I have another issue. So the lack of power and running rich (-25% STFT) has led my to do another compression test and leak down test. My compression test came back good, Cyl 1 - 170PSI, Cyl 2 - 180PSI, Cyl 3 - 170PSI, Cyl 4 -175PSI.
I did a leak down test (used the one with 2 gauges - SPTools Leak Down Tester - https://transquip.com.au/products/sp...k-stopper.html. and for cyl 1, 3 and 4 got 25% (which is normal/good), but cylinder 2 I got 40%. I checked dipstick for air leak, exhaust for air leak and the intake manifold butterfly, all had no air. So I am stuck as to where the leak could be coming from.
Any thoughts are appreciated.
Mods slowly coming along!!!! Autotech HPFP, CircuitWerks Down/Testpipe, Cobb Accessport V2 and a CPE Turbo Inlet Pipe (Waiting to put it on)
BR1JZL is offline   Reply With Quote
 Old 12-28-2019, 08:43 PM   #2
blackdonkey's Avatar
Posts: 4   (View Stats)
blackdonkey is an unknown quantity at this point
Before you panic, do your tests again, make sure you are on TDC. Rotate crank again to the next TDC and do the test.
blackdonkey is offline   Reply With Quote
 Old 12-28-2019, 11:23 PM   #3
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
i'm sure he appreciates the relief you gave him, he's prolly been in a panic for 16 straight weeks
94 M
MS6
IS350
The Following 2 Users Say Thank You to Pu Manchu For This Useful Post:
Db09ms3 (12-30-2019), monkey.bones.007 (12-30-2019)
Boost leak test caused an oil to leak from dipstick shazy MazdaSpeed 3/6 - Turbo Induction 14 08-22-2019 06:53 PM
How to do a leak down test? SharkDiver MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 11-23-2015 10:48 PM
OEM BPV How to Test for Leak? zer010gic MazdaSpeed 3/6 - Turbo Induction 1 02-22-2011 12:13 PM
Boost leak test Laloosh Mazdaspeed3/6 General Discussion 17 07-06-2008 08:48 AM
Page generated in 0.23972 seconds with 22 queries
