  • 1 Post By atvfreek
Closed Thread
 Old 12-31-2013, 02:23 PM   #1
LatinKraze's Avatar
Posts: 804   (View Stats)
Default Lean at WOT
Been working on my tune to accommodate for the colder temps here in Vegas. I dialed back to 16-17 PSI and switched my JBR 3.5" intake for a JBR 3.0" on 12/03/13. Changed MAF curve according to MSF Big Intake thread and went through all the steps.
First Revision: No corrections to MAF, Targeting 11.8 on E25 only
Second Revision: Up boost, dial in CL/OL Maf, BPV set to 50/50, Switched to Full Time CL
Third Revision: Dialed back OL Cal to Rev.1, smoothed out boost curve, BPV back to Full Recirc
NGK Still gapped to .025
No boost leaks
No vacuum Leaks
Still targeting 11.8
No exhaust leaks
LTFT are at +-3
Clean MAF
Fuel from same place E25
Primary O2 and MAF were replaced new in September
I have a new map ready to go with a new OL MAF curve and transitioning CL->OL again
Does anyone have a suggestion on what else to try before a flash the new map? Could this be mechanical or tune issue?
Thanks, Ivan
2016 CX-5 GT AWD
LatinKraze is offline
 Old 12-31-2013, 03:48 PM   #2
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
A boost leak will make you run rich, not lean. Look for leaks pre-turbo, re-circ tube, TIP fully seated and tight etc.
Vdyno sheets do next to nothing for troubleshooting. Post logs.
Agent_Orange is offline
 Old 12-31-2013, 04:16 PM   #3
LatinKraze's Avatar
Uploaded logs to OP.
I checked for leaks originally from hot pipe. I checked again just now, from intake, and found a very small leak here:
Took it apart, reassembled and no more leaks. That's post turbo though (Running Rich)
2016 CX-5 GT AWD
 Old 12-31-2013, 06:45 PM   #4
LatinKraze's Avatar
Would it have something to do with load? Looks like it didn't start until I reached 2.08-2.1.
I'm going to cut a new map from scratch and keep researching what seems to be a load cap
Calling out some top dogs
@atvfreek @Dano @phate @rfinkle2 @djuosnteisn @ms3blackmica @superskaterxes @
2016 CX-5 GT AWD
 Old 12-31-2013, 07:17 PM   #5
LatinKraze's Avatar
I used a v231 map as my base and worked in my current values and most of my load tables were off. None below 2.4 load so I don't know how the new map with a target of 3.0 load and max load of 5.0 will help. Pure boost tune so I made sure my speed will not try to achieve targets.
Looks like everyone is busy with New Years, so I'm just thinking out loud. lol
HAPPY NEW YEARS
2016 CX-5 GT AWD
 Old 12-31-2013, 08:22 PM   #6
Looks like this is related to you switching to CL full time. Revert back and test doing an A-B-A test. Make sure your AFR targets match in all tables.
Lex is offline
atvfreek (12-31-2013), LatinKraze (12-31-2013)
 Old 12-31-2013, 08:22 PM   #7
atvfreek's Avatar
Posts: 7,787   (View Stats)
What is your fuel scalar and specific gravity set to?
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
atvfreek is offline
 Old 12-31-2013, 09:11 PM   #8
LatinKraze's Avatar
Thanks, I'm not familiar with an A-B-A test but I'm assuming you mean reverting to OL transition and comparing to full time CL. I've already reverted back and triple checked my fuel tables.
Thanks, 1.08 and .7490 respectively. Same it's always been on E25.
2016 CX-5 GT AWD
 Old 12-31-2013, 09:17 PM   #9
atvfreek's Avatar
Set your specific gravity table to OTS which is .74 I've been seeing some cars act in a similar way when that table is changed.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
atvfreek is offline
 Old 12-31-2013, 09:41 PM   #10
LatinKraze's Avatar
I'll give it a shot.
I ran .7490 in June without issues too. Here's a log of that. Don't mind the KR, my TMM failed and I tore the WGA hose in that run.
I have done many revisions since then. The biggest was an attempt at a hybrid tune according to this guide.
2016 CX-5 GT AWD
 Old 01-01-2014, 11:30 PM   #11
LatinKraze's Avatar
It may take about a week for my trims to settle so I can take a log. I appreciate the help guys, especially being New Years Eve yesterday
2016 CX-5 GT AWD
 Old 01-08-2014, 09:05 PM   #12
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
@LatinKraze; any updates? Been following your thread, I've been having a similar issue.
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
ms6mil is offline
 Old 01-09-2014, 07:13 AM   #13
LatinKraze's Avatar
I'll find out today and report back
2016 CX-5 GT AWD
 Old 01-09-2014, 07:22 AM   #14
The car stopped trimming @ around 1.2 load.
I have zero experience running FTCL, but if it was in fact FTCL, I'd expect to see some stft activity and the ecu adding fuel...
rfinkle2 is offline
LatinKraze (01-10-2014)
 Old 01-10-2014, 02:36 PM   #15
LatinKraze's Avatar
Resetting the load tables to OTS in ATR worked.
2016 CX-5 GT AWD
The Following 2 Users Say Thank You to LatinKraze For This Useful Post:
ms6mil (01-10-2014), rfinkle2 (01-12-2014)
Closed Thread
why am i so lean. massiespeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 13 06-26-2010 02:53 PM
Dealers got lean; many plan to stay lean Haltech Automotive News 0 05-30-2010 10:10 PM
Still lean at WOT... AFcadet
Cobb ATR Support
32 11-25-2009 02:11 PM
Lean at tip in... Jarods7920
Cobb ATR Support
11 09-01-2009 01:19 PM
to lean?? wisniaPl MazdaSpeed 3/6 - ECU Computer Tuning 12 04-04-2009 07:27 PM
Page generated in 0.35948 seconds with 26 queries
