 Old 12-10-2008, 06:53 PM   #1
toprock's Avatar
Posts: 749   (View Stats)
toprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the world
Groans: 40
Groaned at 27 Times in 21 Posts
Angry Is my engine going to blow?
So last night me and a friend went for a run in my car, just doing some pulls, going on this windy road, having fun. So anyways, I let my friend drive, and he drives an Si, and has a different driving style than me. He keeps it in low gears throughout 30/40mph to get strong pulls, while I baby the engine a bit, and only downshift into a lower gear when I'm ready to go for a pull. Anyways, so you have that bit of background...
Today on start-up I noticed the start-up was a little rougher than normal. Then when I shut off the car I noticed that this was also rougher than normal. It sounds like the engine does a little shake under the hood before it completely shuts off. I was worried that the side mount might be giving in, that's why shut down was rough? So on the way home I have the volume on mute listening closely to every sound my car makes...So I rest my foot on the clutch and notice a little vibration. It disappears when I depress the clutch but is there when my foot is resting. I put in my SU MM last week, so I can't tell if the vibration is from the MM, or from the engine.
I am thinking about bringing it to the dealership to get the TSB reflash and fuel pump, and see if that will help anything. But before I go back to stock and do that, IF I do that, I wanted to double check here if it's all in my imagination or if its possible that I could have bent a rod, or that she's close to blowing...HELP PLEASE!!!
toprock is offline   Reply With Quote
 Old 12-10-2008, 08:06 PM   #2
Demi's Avatar
Posts: 1,107   (View Stats)
Demi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the world
Groans: 61
Groaned at 16 Times in 11 Posts
Sounds like its psychological.
Beginners guide to turbos<- New to this? Give it a look!
-And for the rest of you, if it comes from Autozone and doesnt replace something that broke off your car or make your cabin smell like Coco Butter, its fucking rice.
Demi is offline   Reply With Quote
 Old 12-10-2008, 08:08 PM   #3
jhershorin's Avatar
Posts: 2,087   (View Stats)
jhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the world
Groans: 31
Groaned at 86 Times in 65 Posts
Imagine if we could harness the power of our minds into our motors. Basically its like if you know theres mosquitos around so you feel like ones biting you. That kinda thing.
-JEWBERT
jhershorin is offline   Reply With Quote
 Old 12-10-2008, 08:12 PM   #4
clown_car's Avatar
Posts: 56   (View Stats)
clown_car is a splendid one to beholdclown_car is a splendid one to beholdclown_car is a splendid one to beholdclown_car is a splendid one to beholdclown_car is a splendid one to beholdclown_car is a splendid one to beholdclown_car is a splendid one to beholdclown_car is a splendid one to behold
Groaned at 39 Times in 5 Posts
It's like letting your friend test drive your girl.... Once you get her back it's not the same anymore.
That which does not kill us makes us stronger . . . [SIGPIC][/SIGPIC]
clown_car is offline   Reply With Quote
The Following 8 Users Say Thank You to clown_car For This Useful Post:
andre0121 (12-11-2008), ChrisK (12-11-2008), Demi (12-10-2008), Derek88 (12-11-2008), FreeFlyFreak (12-11-2008), phailerider (12-10-2008), Renzokuken (12-10-2008), superskaterxes (12-11-2008)
 Old 12-10-2008, 08:36 PM   #5
Renzokuken's Avatar
Posts: 900   (View Stats)
Renzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the world
When its realy cold out side, my car starts kind of rough
1990 Totoya Corrolla DX TRD limited edition w/ Back to the future Delorian body kit/ K&N snorkel inlet ram-air intake/ Mazdaspeed T3/T4 turbo-supercharged hybrid 5 PSI and many more mods. 11.92 @120 MPH
Renzokuken is offline   Reply With Quote
 Old 12-10-2008, 09:53 PM   #6
phailerider's Avatar
Posts: 4,639   (View Stats)
you need to post more...lol
phailerider is offline   Reply With Quote
 Old 12-10-2008, 09:59 PM   #7
Change the plugs, keep the fluids topped off and drive the piss out of it.
 Old 12-11-2008, 05:17 AM   #8
ms3jake's Avatar
Posts: 695   (View Stats)
ms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the world
Seriously, I never let anyone drive my car!
ms3jake is offline   Reply With Quote
 Old 12-11-2008, 09:00 AM   #9
ChrisK's Avatar
Posts: 1,168   (View Stats)
ChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the world
Groans: 56
omg LOL. I just spit on my monitor!
ChrisK is offline   Reply With Quote
 Old 12-10-2008, 08:12 PM   #10
toprock's Avatar
Groans: 40
Yeah, that thought had crossed my mind too :/
 Old 12-11-2008, 06:50 AM   #11
toprock's Avatar
Groans: 40
Fixed the problem!
This is the solution someone suggested, and since it was such a quick fix I decided to try it...
"lol, sounds like KAM is ****ing with you...
KAM = Keep Alive Memory...
being that you normally only drive roughly when you need/want to, but then went out for a day beatin on the thing, the car is programmed to change it's programming to fit your driving (i.e. more fuel, more timing) so now it's in "performance mode", it should go back to normal just by pulling the battery cable (or at least stock programming)...
if it doesn't return to normal, i'd revert to stock and take it to the dealer and say it's "acting up", they'll charge you with diag time, and find out if anything is broken, BUT they will notice that you had a day of fun (cars have "black boxes") and probably ask you not to do that, then probably tell you that you'll need a re-flash, and that driving that way continuously can void your warranty (they cover normal wear and tear, but if you're peggin' the redline, they'll drop you)"
Disconnected my battery overnight, popped it back in the morning, and WOW what a big difference. Engine turns on and shuts off like the first day I got her. Amazing what a simple ECU reset does...and vibrations in the clutch are extremely minimal now (I think whatever vibration is from the MM breaking in)
 Old 12-11-2008, 07:06 AM   #12
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
I know people say every clutch vibrates some, but i cant feel any vibration in my clutch whether i have a shoe on or not.
 Old 12-11-2008, 07:30 AM   #13
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
it's amazing how paranoid people get on these boards after a few posts
 Old 12-11-2008, 07:33 AM   #14
toprock's Avatar
Groans: 40
Well I'm not surprised people including myself are, considering people new to this board have most likely just gotten their car and started modding, and all of a sudden we read post after post of people blowing their engines just strolling along...
 Old 12-11-2008, 07:36 AM   #15
socks's Avatar
Groans: 125
you have to remember, this is probably the most "aggressive" of the ms3 forums. you get the people who push the limits and get greedy with it, like myself.
if i blow my motor before i get my rods/pistons in, im not gonna blame the platform. im going for the goods, it will be nobodys fault but my own.
 Old 01-19-2009, 10:38 PM   #16
mazdaspeed619sd's Avatar
Posts: 170   (View Stats)
mazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud of
I am just wondering, but how long has the fuel pump and tsb reflash been out? I wonder if this is why i have problems with my car. I have not been to the dealership since summer last year, and now my motor is suffering, i think valve train slap.
06 MS6 Black Mica
AWD BROTHERS SHALL UNITE!
Boys love straight lines.— Men love curves.— =)— Canyon/Circuit FTW!—
mazdaspeed619sd is offline   Reply With Quote
Why does your motor blow thread, look inside. ptperformance Mazdaspeed3/6 General Discussion 207 08-16-2009 12:01 PM
April Foolery: Indy MotoGP organizers blow all the cash on Nazi hookers Haltech Automotive News 0 04-01-2008 04:50 PM
Page generated in 0.35173 seconds with 31 queries
