 Old 03-22-2016, 10:26 AM   #1
mazdamx3freak's Avatar
Posts: 219   (View Stats)
mazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond repute
Default Need help deciding to replace turbo or not
I have an 08 with 45k on it. It has always smoked from time to time. Of course I did banjo bolt. 5w40 oil, upping idle, oil catch can ect. And the issue did get a little better. But the other day it started smoking really bad as soon as the car is a normal temps and not just at idle, all the time. Large white clouds of smoke with a strong burnt oil smell. Checked compression and all cylinders are between 150-160. Changed plugs and oil again to be sure and still the same. Runs and drives great just loads of smoke. I don't have a ton of money to fix the issue but starting to think my turbo is completely shot?
2008.5 CPW
JBR:3.5 intake, fmic, r51 Battery Box, Ancors, EGR Delete, Thermal Spacers, 5mm Wheel spacers, Shift plate.
Matt Dimond OCC, Autotech Internals, CNT catted downpipe, itv-22, Threadstone T8L FMIC,SU Turbosmart Bpv, SUv2 Rmm
mazdamx3freak is offline   Reply With Quote
 Old 03-22-2016, 11:35 AM   #2
Design's Avatar
Posts: 1,887   (View Stats)
Groaned at 9 Times in 5 Posts
Any external oil leaks? Cylinders/plugs wet? Need more info.
09 CWP MS3 GT
Ownership & Build Thread
 Old 03-22-2016, 12:03 PM   #3
No oil leaks and old plugs looked good, not wet Or full of carbon.
2008.5 CPW
 Old 03-22-2016, 02:37 PM   #4
Design's Avatar
If the intake tract is clean, probably the turbo. Doesn't sound like ringlands, OCRs or PCV. Might check the PCV valve for one way flow, just in case.
09 CWP MS3 GT
 Old 03-24-2016, 04:23 PM   #5
well found out why it smokes so bad.....
also too add pvc is working fine, and no oil in any part of the intake or intercooler piping. so you think my turbo seals are nonexistent at this point and just leaking right in to the exhaust?
2008.5 CPW
 Old 03-24-2016, 04:30 PM   #6
GEE1989's Avatar
Posts: 182   (View Stats)
GEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant future
When my turbo went it was actually pushing oil into the top mount. You could pull your top mount and look inside the turbo. There was a very noticeable amount of oil there
Sent from my SM-G920P using Tapatalk
08 MS3
Corksport turbo, built motor, meth injection, and FREEKTUNED
GEE1989 is offline   Reply With Quote
 Old 03-24-2016, 04:55 PM   #7
I have a fmic and did pull the turbo inlet piping. no oil
2008.5 CPW
 Old 03-24-2016, 06:02 PM   #8
GEE1989's Avatar
Hmm. Maybe yours just blew on the exhaust side vs mine was both
08 MS3
 Old 03-24-2016, 06:24 PM   #9
sheston's Avatar
Posts: 1,847   (View Stats)
Shouldn't oil be gray / black? Does water leak into the turbo and exhaust when the seals go?
Big Turbo choice to replace a big turbo mituc MazdaSpeed 3/6 - Turbo Induction 15 02-19-2016 02:10 PM
Replace Vvt and turbo Jorge.angel CX-7 > Issues & Troubleshooting 3 10-12-2015 04:35 AM
To replace or not to replace the throwout bearing that is the question? stockms3 MazdaSpeed 3 - Engine, Transmission & Driveline 4 06-30-2014 07:29 AM
Report: VW to replace unloved five-cylinder base engine with turbo four Haltech Automotive News 0 11-18-2011 03:50 PM
REPORT: Twin-turbo 5.5-liter V8 to replace Mercedes-Benz' 6.2-liter V8 Haltech Automotive News 0 12-15-2009 05:30 PM
Page generated in 0.29632 seconds with 23 queries
