 Old 04-22-2014, 06:58 PM   #1
mgramata's Avatar
Posts: 39   (View Stats)
mgramata is a jewel in the roughmgramata is a jewel in the roughmgramata is a jewel in the rough
Unhappy Not hitting target Boost. PLZ HELP
alright so ive been having an on-going problem for 5 months now. for some reason, im not hitting my boost target anymore. i have done a boost leak test several times and only found my bov to be leaking a little bit. i fixed that issue but still no difference in my PSI. i started noticing it right after i installed my xspower turbo manifold, not sure if it has to do with the problem. i have a log from november of 2013, right before i installed the manifold. and another log i just took today. i am new to the whole Access race tuner and im not sure what im really looking for. can any of you vetrans help me out? or do you know of any thing that could be causing this problem? I have tried changing the tune on the car from the Stage 2 OTS map, back to stock. tried another tune with 93 oct, and no change what so ever. Any help will be greatly appreciated!
MODS:
-cobb SRI
-cobb TIH
-cobb FMIC
-corksport Downpipe
-highflow cat
-ptp Fuel pump internals
-3" stright pipe exhaust
-hks ssqv
-xs power manifold
-devils own meth injection
-Cobb AP Stage 2 OTS map with slight modifications from previous owner
i know i am new, but ive looked this up and people say it might be the OTS map? but ive changed the maps to different ones with no change. Anything helps guys. thanks in advance
SIDENOTE: Both data logs are from 2nd-4th gear pulls. First one was november 2013, the second was today, 4-22-2014
mgramata is offline   Reply With Quote
 Old 04-22-2014, 07:09 PM   #2
kamwill's Avatar
Posts: 16   (View Stats)
kamwill will become famous soon enough
Im having this same problem after installing bnr s3.. After install was running fine for about a week while trying to tune it was making 20psi. Then yesterday it just felt like it wasnt making any power, checked for leaks havent found any. Replaced line from turbo to wastegate and no difference. Dont know what to do
kamwill is offline   Reply With Quote
 Old 04-22-2014, 07:15 PM   #3
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
MODS:
-cobb SRI
-cobb TIH
-cobb FMIC
-corksport Downpipe
-highflow cat
-hks ssqv
-xs power manifold
your WGDC looks pegged...
reference this http://www.mazdaspeedforum.org/forum/foru...ml#post2553770
might be relevant
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
 Old 04-22-2014, 07:15 PM   #4
mgramata's Avatar
i had an appointment to get protuned the weekend after my install, but had to cancel because of this PITA problem. im stumped. hopefully we both get our problems squared away
 Old 04-22-2014, 07:15 PM   #5
Hargarbl's Avatar
Posts: 642   (View Stats)
Groans: 51
Most people are honestly going to want you to get a straight 4th gear pull. Start at around 3000rpm and put your foot to the floor till redline.
Edit: Did not see the WGDC, damn.
The Following User Says Thank You to Hargarbl For This Useful Post:
mgramata (04-22-2014)
 Old 04-22-2014, 07:17 PM   #6
ms6mil's Avatar
Groans: 307
IMO, you might want to look into getting one of the tuners on MSF to hook you up. They will do a far better job than any "protuner" at a shop. just my 2 cents
PTE5862 - TBD
The Following User Says Thank You to ms6mil For This Useful Post:
 Old 04-22-2014, 07:32 PM   #7
mgramata's Avatar
What could be causing the duty cycle to be so high? Is it something that just needs to be tuned or an actual problem with the engine?
I'm trying to find a few local guys to help me out with it. Can you recommend anyone on the forums who can create/ tune a map? Thanks for the input guys
Thanks I'll get on that ASAP
Last edited by mgramata; 04-22-2014 at 07:32 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-22-2014, 07:43 PM   #8
ms6mil's Avatar
Groans: 307
from what I am hearing the WG might require more preload than what it's coming with.
this is coming from Nishan:
I am seeing extremely low spring pressure on the new S3 housings and this is likely due to the fact the WG Hole is much larger than the previous design.
More pre-load is definitely needed and I am having a guy that I am tuning now spend some time to add more preload to see where that gets us.
I would just keep your ear to the ground in regards to the BNR S3,
subscribe to this thread if you haven't already... I will tag ya when we are install ours on Sat. for progress.
PTE5862 - TBD
Agent_Orange (04-22-2014)
 Old 04-22-2014, 08:54 PM   #9
kamwill's Avatar
I had just started getting ready to work on my tune and it just started lagging on me. Cant really see it having anything to do with the tune or the different turbo because it was running fine.. Checked the stock bpv and it was fine also. So I dont know what to do
 Old 04-22-2014, 09:01 PM   #10
ms6mil's Avatar
Groans: 307
others are having issues with caps blowin off the ports on the turbo, or lines not secured well enough. retrace everything ensure that clamps are tight.
post logs when able
PTE5862 - TBD
Not hitting target boost btrend MazdaSpeed 3/6 - Troubleshoot/Diagnostics 34 04-14-2013 09:28 PM
boost tuning, not hitting easy boost targets? Caldazar MazdaSpeed 3/6 - ECU Computer Tuning 11 05-18-2012 06:09 PM
Not hitting Stage 2 boost targets (boost leak?) Bubba Ho-Tep 2010 MS3 - ECU Computer Tuning 15 04-26-2012 08:25 PM
Not Hitting Boost? KrishyC Gen2 MS3 General Discussion 8 03-28-2012 09:06 PM
AP stage 2 not hitting target psi and stuttering in 4th balkanbase MazdaSpeed 3/6 - ECU Computer Tuning 7 12-06-2010 01:50 PM
Page generated in 0.32454 seconds with 24 queries
