 Old 08-03-2012, 08:18 PM   #1
MS6Blaze's Avatar
Posts: 30   (View Stats)
MS6Blaze will become famous soon enough
Default oil consumption??
i changed my oil about 2000 miles ago and put in 6 qts and i checked my oil today and it showed almost just above the min line i waited a good couple hrs after i drove it so the oil could fall down to the oil pan.. i have about 155psi in all cylinder for compression
MS6Blaze is offline   Reply With Quote
 Old 08-03-2012, 08:52 PM   #2
GODspeed7's Avatar
Posts: 3,456   (View Stats)
Yeah it might help if you told us what oil you are using chief...
2012 Mazdaspeed3 Black Mica
 Old 08-03-2012, 09:19 PM   #3
meicalnissyen's Avatar
Posts: 1,158   (View Stats)
pull, wipe, reinsert, pull, read
magic
 Old 08-03-2012, 09:24 PM   #4
MS6Blaze's Avatar
Same thing when I rewipe and reinsert and I'm using penz ultra 5w 30
 Old 08-04-2012, 05:34 AM   #5
GODspeed7's Avatar
How many miles on your car? Smoking turbo? Excessive smoke on acceleration?
 Old 08-04-2012, 02:18 PM   #6
MS6Blaze's Avatar
82xxx and yest i do get some dark smioke when i go wot but i think its fuel more then oil but i dont really know i have 5% tint all the way around
 Old 02-13-2014, 07:19 PM   #7
Aza
Aza's Avatar
Posts: 2   (View Stats)
Aza is an unknown quantity at this point
Good evening all,
Any update on this thread, other causes of exsessive oil comsumption, I have the same issue, no varience in compression, no smoke on idle, smoke on WOT but its dark, I have used about 5 litres of oil over the last 10,000km.
I am looking for suggestions on things to start checking/replacing.
Thanks in advance!
Aza is offline   Reply With Quote
High Oil Consumption RichieRichness MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 11-09-2016 11:01 AM
huge increase in fuel consumption d_crew_man 2010 MS3 - Troubleshoot/Diagnostics 17 07-24-2011 09:16 PM
A glass of water a day can help keep your fuel consumption at bay Haltech Automotive News 2 07-24-2010 08:06 PM
Fuel Consumption corbs Mazdaspeed3/6 General Discussion 12 04-13-2009 03:22 PM
Mazda to cut fuel consumption 30 percent by 2015 Haltech Automotive News 0 06-23-2008 06:50 AM
Page generated in 0.27336 seconds with 23 queries
