| MazdaSpeed 3/6 - Troubleshoot/Diagnostics MazdaSpeed 3/6 - Troubleshoot/Diagnostics - Have a problem with the car? CEL Code? Want to discuss other issues? Come on in! |
| Banned ![]() Join Date: Feb 2009 Location: Inland Empire
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 937
Groans: 701
Groaned at 655 Times in 620 Posts
(Thread Starter) | Not Ranked : 0 score Couple days ago I decided to tighten down all of my clamps , boost tubes, turbo inlet, cp-e cai, bpv ect... Thought everything went well...Next thing you know, I reset the ECU, take the car out to a 40 mile drive to let the ECU re-learn, afterwards the next day, I take the car out and to find out that instead of the "wooosh" sound my intake makes when it's sucking in air, it sounds like a high-pitched "wooosh", didn't think nothing of it, so I look at my dashhawk and find out I'm only hitting max boost of 10psi in all gear.... here is my datalog. |
| The Following User Says NO Thank You to glocK23 For This Un-useful Post: |
![]() Join Date: Mar 2008 Location: abc
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,081
Groans: 147
Groaned at 34 Times in 29 Posts
| Not Ranked : 0 score check again for boost leaks, check inlet!
__________________ "08, I hate to break it to you, but if it gives kevin a boner, its porn" ![]() NATOR PERFORMANCE Nylon washer sponsered |
| rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3168 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score meh it happens, it will come around eventually...search for prior threads talking about this symptom
__________________ '08 CWP MS3 w/ T3 3071r |
![]() Join Date: Dec 2008
Rep Power: 154 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
__________________ 2007 MS3: HKS Hi-Power CBE with muffler cut-out, HKS CAI, TurboXS RP, Forge BPV, PTP Air Straightener, OCC, MBC(not hooked up der), Cobb AP, Denso Iridium ITV22 Spark Plugs, PG Turbo Inlet | |
Groans: 701
(Thread Starter) | Not Ranked : 0 score Wow, I fixed this along time ago. Was a loose clamp on my boost tubes. |
Groans: 147
| Not Ranked : 0 score you can paypal me $10 now
![]() Join Date: Oct 2008 Location: merida yucatan mexico
Rep Power: 139 ![]() Thanks: 4
| Not Ranked : 0 score do you have a mbc ? i have mine , but when i take off my mbc , and re-installed the original boost tubes from solenoid , always it gonna give me only 10 psi , no more you need to go the dealer for a reflash .... that works for me , o put one mbc , and setup yourself to 15 or 16 psi ... i hope it works for you... |
| Brake boosting? | Sloane | Mazdaspeed3/6 General Discussion | 14 | 12-24-2008 01:13 PM |
| Boosting to High AP Log | albone | Cobb Access Port/Maps | 24 | 12-19-2008 02:54 PM |
| took off mbc and only seeing 10psi | b-ron | MazdaSpeed 3/6 - Turbo Induction | 2 | 07-29-2008 11:01 PM |
| Honda boosting Fit production to meet U.S. demand | Haltech | Automotive News | 2 | 06-23-2008 12:10 PM |
