  • 1 Post By msantana101
 Old 05-22-2014, 02:44 AM   #1
msantana101's Avatar
Posts: 1,517   (View Stats)
Default P0134
A little background on the situation: Did a BT swap last weekend and when we started it up my AFRs were stuck at 14.85. Previously before the swap, my AFRs were moving around as they should when the k04 was in the car. Fast forward to today: I just swapped the primary o2 sensor with a new one from rockauto (NGK NTK 24393) and it's still having the same issue; AFRs stuck at 14.85. I've reflashed a few different maps and still the same thing. The wires on the new o2 are not twisted and the clips are plugged in. The secondary o2 is currently not in the DP due to messed up threads, so we plugged the bung; this shouldn't be causing my current issue at least I don't think? Not really sure what else there's left to check. I'm hoping it's something super simple, but who knows what it could be. Any ideas on what might be causing the issue? Needless to say I'm very disappointed in this outcome as I can't even enjoy the hard work my friends and I put into the car. This shit is big time lame...
FreekTuned
Little John (06-01-2014)
 Old 05-23-2014, 01:01 PM   #2
gigliotti175's Avatar
Posts: 750   (View Stats)
gigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the world
Groaned at 25 Times in 15 Posts
That's probably your issue. Not having the second o2 sensor in. If I unplug my second o2 sensor it sticks at 14.85. If I unplug the first one it stays at 29.??.
gigliotti175 is offline   Reply With Quote
 Old 05-23-2014, 01:16 PM   #3
DVM17's Avatar
Posts: 1,283   (View Stats)
That's not his issue. I've not had a secondary o2 sensor plugged in for a couple months. got it tuned without it and haven't had any issues.
Unless the ecu's see the secondary o2 differently between gens.
12.07 @ 116 on 205 snow tires
hunting for 11's on 245's
The Following 2 Users Say Thank You to DVM17 For This Useful Post:
btstarcher (07-04-2014), LumberJack (06-01-2014)
 Old 05-23-2014, 01:29 PM   #4
mrtheandrew's Avatar
Posts: 468   (View Stats)
I thought the primary sensor was pn 24357?
2007 True Red MS3
Koni Yellows || H&R Springs || JBR RSB || JBR Dogbone RMM || Centric Blanks || CS Pads || Goodridge SS Brake Lines || CS SSP || Hella Supertones || 55w 5000k HIDs/35w 3000k fogs || eonon D5151 HU/Nav/PS2 || 17x8 RPF1s || 235/45 DW || CS BPV || CS Intake/TIP || CXRacing/Godspeed FMIC || Ultimate Racing TP || Autotech Internals || AP v3
 Old 05-23-2014, 02:14 PM   #5
trf5000's Avatar
Posts: 2,290   (View Stats)
Genpu 2nd o2 sensor has to be plugged in and in the exhaust stream.
Different logic between the gens. We figured this out awhile ago when guys with pus were having massive problems with defoulers on the 2nd 02 sensor.
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
 Old 06-01-2014, 12:30 AM   #6
Default P0134
Lumberjack is running his world record pu without a secondary o2 but his is a 2013 and mines a 2010. Would that make a difference?
EDIT: just realized this was posted in the first gen section. Sorry I wasn't able to see that on tapatalk as it was cutoff.
FreekTuned
 Old 06-01-2014, 12:37 AM   #7
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
@ms3blackmica; @rfinkle2; @Justin@Freektune;
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
The Following 2 Users Say Thank You to Boosted Beluga For This Useful Post:
LumberJack (06-01-2014), msantana101 (06-01-2014)
 Old 06-01-2014, 12:45 AM   #8
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
I was under the impression that the rear O2 sensor was present.
Mike, I would really try and get the rear O2 sensor in first before diagnosing any further to see what happens.
www.tunedbynishan.com
 Old 06-01-2014, 01:26 AM   #9
Nish, I had the secondary o2 connected but not in the stream due to stripped threads on the o2 so it was just basically hanging out in the open. Wouldn't it still read something even outside the stream, or does it absolutely have to be placed into the stream?
FreekTuned
 Old 06-01-2014, 12:49 AM   #10
Fjager's Avatar
Posts: 246   (View Stats)
Fjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the world
I got the same problem with my Dp install, it got fixed with a new sensor, you could have gotten a dead sensor, it does happen.
If anything try and double check all of the wiring harness connections.
2013 White Pearl MS3
JBR SSP/bushings/RMM/EGR delete
Corksport 3ID Intake/Radiator
Cobb APV3/AT Internals
Grimmspeed 3 port EBCS/Matt Damond CC
FMIC W/DIY Sprayer
CPE DP
Fjager is offline   Reply With Quote
 Old 06-01-2014, 01:07 AM   #11
Little John's Avatar
Posts: 494   (View Stats)
Little John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the world
Groans: 55
Its not the senor because i am using the one he bought and it is reading fine on my car! I although have my secondary o2 plugged in!
Little John is offline   Reply With Quote
The Following 2 Users Say Thank You to Little John For This Useful Post:
 Old 06-01-2014, 01:29 AM   #12
Nishan
It needs to be in the exhaust stream.
Having personally seen your car when I was out in Cali and going over the symptoms/issues with Bryce I will say that you definitely need to get that rear O2 in the exhaust stream and see if you get feedback.
 Old 06-02-2014, 06:59 PM   #13
So I had the opportunity to put the rear o2 in today and absolutely nothing changed. AFRs were still stuck at 14.85 and I even did a hard reset on the battery and reflashed my map as well. In all honesty I was kind of expecting this but it's better to know for sure than to wonder. At least this came in the mail today so hopefully this will remedy this issue:
ms3blackmica likes this.
FreekTuned
The Following 3 Users Say Thank You to msantana101 For This Useful Post:
Boosted Beluga (06-02-2014), DVM17 (06-02-2014), ms3blackmica (06-02-2014)
 Old 06-01-2014, 01:31 AM   #14
Alright sounds good. I'll give it a go and post up my results.
FreekTuned
The Following 2 Users Say Thank You to msantana101 For This Useful Post:
Boosted Beluga (06-01-2014), ms3blackmica (06-01-2014)
 Old 06-18-2014, 04:12 PM   #15
So it came down to being a bent ecu pin that was causing my AFRs to stay stuck. Fucking wow. I'm extremely happy and relieved now but still cannot believe that was the issue and that it was overlooked for so long. Amazing...
FreekTuned
Boosted Beluga (07-04-2014), lilred (06-18-2014), ms3blackmica (06-18-2014)
 Old 07-03-2014, 12:39 AM   #16
pdc001's Avatar
Posts: 27   (View Stats)
pdc001 is a glorious beacon of lightpdc001 is a glorious beacon of lightpdc001 is a glorious beacon of lightpdc001 is a glorious beacon of lightpdc001 is a glorious beacon of lightpdc001 is a glorious beacon of light
Do you have to have a pic of the bent ecu pin? I currently have the same problem.
pdc001 is offline   Reply With Quote
The Following 2 Users Say Thank You to pdc001 For This Useful Post:
Axela_EN (07-04-2014), Boosted Beluga (07-04-2014)
 Old 07-04-2014, 11:51 AM   #17
Groans: 50
@msantana101;
08 Mazdaspeed 3
 Old 07-04-2014, 07:55 PM   #18
I don't unfortunately. But it was bent to shit and pushed down.
FreekTuned
 Old 04-21-2019, 07:47 AM   #19
Rileymayo's Avatar
Posts: 5   (View Stats)
Rileymayo is an unknown quantity at this point
Sorry too reactivity this thread, But I seem to be having the exact same issue.. Just did a new catless DP install, And I’m new too the page also.. but my afr was stuck at 14.85, secondary o2 was on & snug and so was the primary but I’m getting a CEL P0134 which is the primary o2 sensor.. it all seems fine but is used and could possibly be dead.. cleaning out all connections & trying again but if this doesn’t work, where would I find a bent ecu pin? Before I go buying a new o2 sensor! Thanks in advance fellas all help is much appreciated
Rileymayo is offline   Reply With Quote
 Old 12-05-2019, 08:24 AM   #20
Witness's Avatar
Posts: 39   (View Stats)
Witness is a jewel in the roughWitness is a jewel in the roughWitness is a jewel in the roughWitness is a jewel in the rough
I'm also having the same issue. I bought a new NTK o2 sensor and installed it but my AFR's are still pegged at 14.85. Any way I can do a continuity test on the connectors for me to diagnose?
2007 MS3
Stock Turbo - Wiseco Pistons - Manley H-Beam connecting rods - Autotech high pressure fuel pump internals - ARP cap bolts - ARP main studs
Balance shaft delete - JBR EGR delete - COBB intake - COBB front mount intercooler - COBB rear motormount - COBB electronic boost controller - COBB access port V3 - COBB blow off valve - Catless downpipe
Witness is offline   Reply With Quote
 Old 12-06-2019, 06:43 AM   #21
MSMS3's Avatar
Posts: 2,825   (View Stats)
Check the part number on that O2 sensor. Gen 1 and Gen 2 are different. OEM is best for the primary O2. I posted a good source on your other thread.
Rock Auto is notorious for getting our parts wrong, often confusing with regular Mazda 3 or confusing 1st and 2nd gen MS3.
The Following 2 Users Say Thank You to MSMS3 For This Useful Post:
Anaphra (12-06-2019), Witness (12-06-2019)
 Old 12-06-2019, 01:09 PM   #22
Witness's Avatar
do you know what the part number for the OEM O2 sensor is?
2007 MS3
The Following User Says NO Thank You to Witness For This Un-useful Post:
Db09ms3 (12-06-2019)
 Old 12-06-2019, 01:47 PM   #23
MSMS3's Avatar
Really? I've been generous with my time and thoughts. Perhaps you might want to take the initiative and do a bit of investigating on your own. You can get the part number from any of the OEM Mazda parts stores. Many Mazda dealers operate on-line parts sales. It is easy to look up.
Also, I believe I recently posted a link to the Edge Auto Sports website with the part number. Its right there on your other thread.
Gee, at least try, please? Ok? We get tired of spoon feeding people who expect to have others do everything for them. That's not how it should work here. It's not unreasonable to ask someone to try to do a bit of their own homework, and then if they really fail, to seek help.
The Following 4 Users Say Thank You to MSMS3 For This Useful Post:
Db09ms3 (12-06-2019), Ranck21 (12-12-2019), Vansquish (12-09-2019), Witness (12-06-2019)
Need help, CEL lights P0134 and P0441 Nogood MazdaSpeed 3 - Engine, Transmission & Driveline 1 05-05-2014 09:12 PM
CEL P0031 and P0134 matto MazdaSpeed 3/6 - Turbo Induction 5 01-19-2012 11:56 AM
CEL P0134 & P0139 f-castrillo 2010 MS3 - Troubleshoot/Diagnostics 6 08-06-2011 02:17 PM
Page generated in 0.43063 seconds with 32 queries
