 Old 12-10-2013, 09:08 AM   #1
cocoleveo7686's Avatar
Posts: 238   (View Stats)
cocoleveo7686 is a name known to allcocoleveo7686 is a name known to allcocoleveo7686 is a name known to allcocoleveo7686 is a name known to allcocoleveo7686 is a name known to allcocoleveo7686 is a name known to all
Groaned at 34 Times in 21 Posts
Default p0401 and p0245
The check engine light just came on. Im running stage 1 map. The car still runs normal but what's wrong? What do I need to fix? Sorry for the dumb questions
cocoleveo7686 is offline   Reply With Quote
 Old 12-10-2013, 09:43 AM   #2
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I don't believe the codes are related, but you likely need to clean your egr, and check the ebcs connection.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 12-10-2013, 09:46 AM   #3
Any pictures of where the ebcs is? Same with the egr? What do I clean the egr valve with?
 Old 12-10-2013, 09:48 AM   #4
Tokay444's Avatar
Groans: 793
Egr is back of the head, driver's side.
Ebcs connector is bracketed to the turbo.
Demodded.
The Seals
 Old 12-10-2013, 09:49 AM   #5
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
Both of those are eaaaaaasily googlable.
How-To clean your 1st Gen Mazdaspeed 3 EGR
Follow the small hose coming off your TIP to the other end. That's your EBCS.
2012 Velocity Red Mica
 Old 12-10-2013, 09:52 AM   #6
Can I drive the car still? I looked and didnt see pictures. Ill keep looking. Is it hard to clean the egr valve or should I take it to someone?
 Old 12-10-2013, 09:53 AM   #7
Dimenus's Avatar
Groans: 33
Did you look at the guide I posted? Stop being lazy. Dude, plenty of people with no previous automotive experience (myself included) can do these things if you just search and read carefully.
The Following User Says Thank You to Dimenus For This Useful Post:
Vansquish (12-10-2013)
 Old 12-10-2013, 10:00 AM   #8
[quote =D imenus;2373235]Did you look at the guide I posted? Stop being lazy. Dude, plenty of people with no previous automotive experience (myself included) can do these things if you just search and read carefully.[/quote]
Sorry my phone didnt refresh. I think im going to order a ebcs from you guys and run it in port 2 mode? One end will be going to the tip where Does the other line go to? When I take off the stock ebcs is it basically just swapping it out? Sorry again for the dumb questions
 Old 12-10-2013, 10:12 AM   #9
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
If you do end up getting an EBCS from a vendor like Stratified follow the instructions that come with it.
A simple search....
How to route your BCS lines 2 and 3 port, iwg and ewg
Start reading & searching more!
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
The Following User Says Thank You to ms6mil For This Useful Post:
Agent_Orange (12-10-2013)
 Old 12-10-2013, 11:00 AM   #10
Is it safe to drive for a week until I get a ebcs? Im going to clean the egr thursday. Do I use brake cleaner/carb cleaner?
 Old 12-10-2013, 11:15 AM   #11
btstarcher's Avatar
Posts: 4,852   (View Stats)
Just look to see if the hoses are on tight. The electronic boost control solenoid is part of the system that regulates boost; if something is wrong you may overboost and have serious issues. If you look at your turbo inlet pipe, there's a very small hose (like 3/16" or so) that connects to a nipple close to the base where it attaches to the turbo. Follow that hose and the other end is the EBCS.
SnailTune in progress
 Old 12-10-2013, 11:41 AM   #12
I just checked and both the egr and ebcs were unplugged. I just had my clutch done at the dealer I am suprised they disconnected those. Maybe I should call them
The Following 2 Users Say Thank You to cocoleveo7686 For This Useful Post:
btstarcher (12-10-2013), chaser27 (12-10-2013)
 Old 12-10-2013, 11:48 AM   #13
ms6mil's Avatar
Groans: 307
That sux, at least you caught it.. good tips from @Tokay444; & @btstarcher; Dealer fail once again. your call might fall on deaf ears, but I would be interested to hear their excuse.
PTE5862 - TBD
 Old 12-10-2013, 12:04 PM   #14
Tokay444's Avatar
Groans: 793
What about tips from tokay?
Demodded.
The Seals
btstarcher (12-10-2013), ms6mil (12-10-2013)
 Old 12-10-2013, 12:20 PM   #15
ms6mil's Avatar
Groans: 307
haha, fixed...
PTE5862 - TBD
 Old 12-10-2013, 01:55 PM   #16
Tokay444's Avatar
Groans: 793
I've never been a just the tip kinda guy anyway. I prefer to give the whole thing.
Demodded.
The Seals
ms6mil (12-10-2013)
cel p0401 amggilly305 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 10-14-2015 06:56 AM
P0245 CEL Zbrit00x Gen2 MS3 General Discussion 2 08-09-2012 09:46 PM
CLE P0245 ms6ms6 MazdaSpeed 6 - Engine, Transmission & Driveline 1 09-20-2011 11:26 PM
P0245, with MBC? 11cruzito11 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 12-20-2009 08:29 PM
p0401 clos561 MazdaSpeed 3/6 - ECU Computer Tuning 3 07-20-2008 10:40 AM
Page generated in 0.35311 seconds with 24 queries
