 Old 01-30-2016, 01:45 PM   #1
angiehbrown's Avatar
Posts: 3   (View Stats)
angiehbrown is an unknown quantity at this point
Default P2004 P2009 codes
I have the 2006 Mazdaspeed 6 and i am getting the same cel codes..I cant get this car inspected until I can fix it. I really dont want to do the vtcs delete. Is there any other way to fix this? Thanks
angiehbrown is offline   Reply With Quote
 Old 01-30-2016, 02:01 PM   #2
wes3id's Avatar
Posts: 611   (View Stats)
wes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the world
uncheck codes in ATR
07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS
K04 93 FREEKTUNED 271 AWHP/296TQ
K04 E85 FREEKTUNED 309 AWHP/360TQ
BNR S3 93 FREEKTUNED 336 AWHP/360TQ
BNR S3 E85 FREEKTUNED 375 AWHP/376TQ
wes3id is offline   Reply With Quote
 Old 01-31-2016, 01:45 PM   #3
I know I sound dumb but what the he!! is a ATR..
 Old 01-31-2016, 02:12 PM   #4
wes3id's Avatar
accesstuner race...tune program for your accessport. guessing since you don't know what it was, you don't have it. do you have an access port?
 Old 01-31-2016, 08:27 PM   #5
Is it the same as the obd ll port? The port where they read my check engine light? If it is something that I can get to erase engine codes I'm definitely interested! This car has literally set in my yard for over a year because I couldn't get it inspected due to the CEL. thanks for your patience with me I am new to the forum
P2004 Fixed djuosnteisn MazdaSpeed 3/6 - ECU Computer Tuning 5 07-24-2017 07:23 PM
DTC P2004, P2009 f-castrillo 2010 MS3 - Troubleshoot/Diagnostics 24 07-14-2015 07:27 PM
P2004 P2009 codes Sphinx1983 Mazdaspeed3/6 General Discussion 1 05-20-2015 08:44 AM
Started getting a P2004 MS3Shadow 2010 MS3 - ECU Computer Tuning 2 04-27-2015 09:05 PM
MS6 Throwing Codes P0123 P0222 and P2009 Speedn253 MazdaSpeed 6 - Engine, Transmission & Driveline 4 01-19-2012 11:17 AM
Page generated in 0.25145 seconds with 21 queries
