 Old 08-04-2013, 01:48 PM   #1
curlyface's Avatar
Posts: 232   (View Stats)
curlyface has a reputation beyond reputecurlyface has a reputation beyond reputecurlyface has a reputation beyond reputecurlyface has a reputation beyond reputecurlyface has a reputation beyond reputecurlyface has a reputation beyond reputecurlyface has a reputation beyond reputecurlyface has a reputation beyond reputecurlyface has a reputation beyond reputecurlyface has a reputation beyond reputecurlyface has a reputation beyond repute
Default Parted out, stock tune -- constant knock?
Hi,
This past week I've started parting out my car but have the following still on:
JBR 80 duro TMM
COBB Intake + TIH
Denso IVT 22
PTP HPFP
COBB XLE
Couldn't change any of the parts above because I don't have the stock parts and am waiting for them to arrive.
I put the stock tune on and took it for a test drive monitoring knock. I get a constant knock of 7 without fail. Every time I press the gas it reads 7 knock and when I let off I get 0. Did a solid 10 minute test with the same outcome every time.
I also had a catted CPE DP which smelt slightly of gas when running, when I put the OEM DP in it smells 10x worse. Did some research and there seems to be no posts with the same issue.
Could it be the plugs? Stock tune? It seems to be idling fine but smells too strong of gas. During the day there is also what I think to be more than usual smoke coming from the exhaust (as in if I can see it during the day there's too much smoke -- usually I wouldn't be able to), the smoke is light gray so doesn't seem to be burning oil or coolant.
Any idea? I'm worried about running logs or even running the car too long..
2007 Mazdaspeed 3
-CP-e CATTED DP-PTP HPFP-COBB SRI-COBB TIP-COBB XLE-COBB AP FREEKTUNE-DENSO ITV24-JBR CHROME MOLLY-JBR PMM-JBR TMM-JBR OCC-JBR RSB-RALLY ARMOR-DASHHAWK-E4P STS-DEFI GAUGES-RL COILOVERS-
curlyface is offline   Reply With Quote
 Old 08-04-2013, 01:50 PM   #2
ABloodBrother's Avatar
Posts: 2,009   (View Stats)
ABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the world
7 could be a false reading. Were you in wot when those points came up? And maybe post a log. I would think false reading, cause 7 is a little outrageous.
ABloodBrother is offline   Reply With Quote
The Following User Says Thank You to ABloodBrother For This Useful Post:
curlyface (08-04-2013)
 Old 08-04-2013, 01:53 PM   #3
curlyface's Avatar
I wasn't in WOT, the reading scared the shit out of me so I decided against it until I posted here. It's literally like clockwork, press the gas knock goes to 7, off the gas knock goes to 0.
I was thinking it might be because my PMM is super weak, my TMM is the only remaining MM with any balls and my engine is seemingly shaking like a bitch.
2007 Mazdaspeed 3
 Old 08-04-2013, 02:08 PM   #4
We had some people in our krew hitting numbers like 8.2 and what not. It was definitely false reads. Didnt look to see if you had gen one. I guess the update on ap made the knock sensor extremely sensitive.
Not saying that's exactly what it is but IMO it is most likely just that. I had a legit reading of 4.0 once and the number scared me but not nearly as much as the actual feeling! Car felt like it hickupped and was bout to smack the ground haha.
The Following 2 Users Say Thank You to ABloodBrother For This Useful Post:
curlyface (08-04-2013), Raymond (08-04-2013)
 Old 08-04-2013, 02:10 PM   #5
curlyface's Avatar
My car is a Gen1, the other thing throwing me off is the smell of gas in the cabin. I was supposed to take the car for a 4 hour road trip today (although I have another I prefer not to use) but I guess that won't be happening now and I'll take the other to be on the safer side.
Any other tests I could run to see if maybe taking it today is still an option?
2007 Mazdaspeed 3
 Old 08-04-2013, 02:17 PM   #6
I mean you said you were running Catless? My car runs excellent, is Catless and stinks of gas and "bad emission" haha. Riding dirty. If you are nervous of car I wouldn't take it. But it sounds alright and if anything just. "Daily drive" it don't put the foot down.
I would definitely log tho. That could answer more of your worries and you could post em here. Definitely would get some answers from that. If when wot car does anything odd just immediately let off. Throw in neutral if needed.
 Old 08-04-2013, 02:23 PM   #7
curlyface's Avatar
Well I was running a catted DP and it smelled less of gas than my stock DP does now which is why I think it's weird.
2007 Mazdaspeed 3
 Old 08-04-2013, 02:23 PM   #8
sidekick's Avatar
Posts: 3,093   (View Stats)
The smell of gas and the engine shaking sounds like it could be misfiring. Have you checked the plugs? You should be running OEM plugs now, not the step colder plugs. They could be fouled and causing a misfire.
curlyface (08-04-2013), smoogs12 (08-05-2013)
 Old 08-04-2013, 02:24 PM   #9
curlyface's Avatar
How can I check? I have no CEL although the car has ran a grand total of 10 minutes since we started the part out
2007 Mazdaspeed 3
 Old 08-04-2013, 02:25 PM   #10
sidekick's Avatar
I added a bit more to my post. Try pulling the plugs to see if they are fouled.
 Old 08-04-2013, 03:08 PM   #11
Didnt even realize op says itv22. If your stock listen to @sidekick; you want oem plugs.
sidekick (08-04-2013)
 Old 08-04-2013, 03:17 PM   #12
jm211's Avatar
Posts: 943   (View Stats)
Had same issue just recently. Like clockwork, on part throttle - up to 5-6kr.
I pulled plugs and retigtened, plus switched toon, and went away. I think one plug backed out.
Aside, you can feel real kr. And to make sure rods are ok, go find a big hill and low gear it up the hill and compression down it.
The Following User Says Thank You to jm211 For This Useful Post:
curlyface (08-06-2013)
 Old 08-05-2013, 03:39 PM   #13
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
OP what you are experiencing is very normal. My own car and countless others do exactly what yours is doing.
The most popular theory is that the ecu is advancing low load timing in order to increase fuel efficiency.
This should ease your fears. Part throttle knock question???
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
curlyface (08-05-2013)
 Old 08-05-2013, 03:43 PM   #14
m4tic's Avatar
Posts: 4,928   (View Stats)
coil unplugged?
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 08-05-2013, 03:50 PM   #15
curlyface's Avatar
Thanks for the link, that eased my fears a little bit. I didn't drive the car yesterday and washed it today hoping the knock goes away but no such luck, heh.
The cars my DD, until I change the plugs (and maybe that won't even help judging by the above link) do you guys think it's safe to drive ~30KM a day? All my stock parts will be here on Wednesday.
Is there any surefire way to check that at least my engine wont explode? If I cruise at a constant speed and it keeps constantly knocking should I assume something is wrong? I'm worried about a WOT test otherwise I would have posted logs already. Any logs I can provide you guys with?
Weirdest thing is it never ever did this before. I've seen knock > 0 like twice in the 2 years I've owned the car. I checked the clamps and bolts and everything is tight. Maybe I'm not as good a backyard mechanic as I once believed, heh.
/paranoid
2007 Mazdaspeed 3
 Old 08-05-2013, 03:58 PM   #16
smoogs12's Avatar
Groans: 423
/paranoid
I feel like this pretty much sums it up.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 08-05-2013, 04:58 PM   #17
curlyface's Avatar
Just got in the car to test it out, went for afr reading and get 0.00 on AP no matter what I do. Also have 147 constant psi apparently, even when I'm not giving gas
Sent from my SGH-I337M using Tapatalk 4
2007 Mazdaspeed 3
 Old 08-05-2013, 06:33 PM   #18
sidekick's Avatar
@curlyface; try reflashing your map.
 Old 08-05-2013, 06:50 PM   #19
curlyface's Avatar
Updated the AP, put a different map on and she runs like a dream. Thank you all for your time.
2007 Mazdaspeed 3
The Following User Says Thank You to curlyface For This Useful Post:
sidekick (08-05-2013)
~3 gal e85 tune knock Speed3eak 2010 MS3 - ECU Computer Tuning 8 10-13-2012 02:30 PM
How do I tune out this knock? Qtip MazdaSpeed 3/6 - ECU Computer Tuning 0 06-26-2010 01:48 PM
Can I use ATR to tune out this knock? Speedn3
Cobb ATR Support
12 05-25-2009 07:09 PM
Persistent Knock Retard on stock tune Ploppity Drown MazdaSpeed 3/6 - ECU Computer Tuning 26 04-23-2009 01:37 PM
Tune day. knock retard after 5000rpm johnac08 MazdaSpeed 3/6 - ECU Computer Tuning 11 12-23-2008 10:57 AM
Page generated in 0.39538 seconds with 25 queries
