 Old 09-28-2008, 12:21 PM   #1
spd6rcr08's Avatar
Posts: 5   (View Stats)
spd6rcr08 is an unknown quantity at this point
Default PLEASE HELP! Trouble with engine light and check oil!
I have a speed 6 i got last November, and everything has been good so far, until i recently installed my new HKS SSQV blow off valve! i'm not saying it has to do with that, but since then, I have had everything from my oil light to engine light come on, the code for the engine light is P0012? And also there seems to be no oil at all in my engine left? There is no oil leak from what i can see, but the plastic on the under compartment doesn't help either. Can anyone help me or point me in the right direction please? i am really lost here.
spd6rcr08 is offline   Reply With Quote
 Old 09-28-2008, 12:24 PM   #2
Lymerock's Avatar
Posts: 1,436   (View Stats)
Lymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the world
P0012 triggers when you have low oil among other things.
refill your oil and then look for potential leaks
Lymerock is offline   Reply With Quote
 Old 09-28-2008, 12:24 PM   #3
MPS
MPS's Avatar
Posts: 298   (View Stats)
MPS has much to be proud ofMPS has much to be proud ofMPS has much to be proud ofMPS has much to be proud ofMPS has much to be proud ofMPS has much to be proud ofMPS has much to be proud ofMPS has much to be proud ofMPS has much to be proud ofMPS has much to be proud of
Groaned at 16 Times in 11 Posts
dont drive the car add oil
when was ur last oil change ?
take off ur mods and run to the dealer
Originally Posted by Laloosh
u see, u cant even handle a picture, let alone the real thing
MPS is offline   Reply With Quote
 Old 09-28-2008, 12:28 PM   #4
spd6rcr08's Avatar
I've changed my oil, and the oil light isn't flashing anymore, and the oil seems to be sticking, but it hasn't been that long since i had it changed, it shouldn't be completley dry, should it? Would this have anything to do with the blow off valve?
 Old 10-01-2008, 09:56 AM   #5
dimaxxxl's Avatar
Posts: 397   (View Stats)
dimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the world
Blow off valves have been known to cause cel's but the symptoms you are describing don't seen to be blow off valve related. I have had a blow off cel in the past and it is not the same one you are describing. Mine was about running rich or lean, cant remember. I would definitly take off my mods and take it to the dealership. In order to set off an oil light your engine must be significantly low on oil. As you know driving with low oil is just ruining your car. Take it to the dealer and have them do the leg work. That why you buy a new car with a warranty
dimaxxxl is offline   Reply With Quote
 Old 10-01-2008, 10:00 AM   #6
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
make sure you use 6quarts instead of 4quarts..
am I asking for trouble if I purchase this???? 94jedi Mazdaspeed3/6 General Discussion 22 01-09-2011 05:17 PM
Audi traffic light detection system gets the green-light Haltech Automotive News 1 09-21-2008 01:24 PM
Check engine light??? supergoose MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 07-20-2008 07:42 AM
All-in-One Black Studio Light Kit (includes Light Tent, 2 Lights, and Acrylic Table) $99.99 Haltech Hot Deals Section 0 03-26-2008 01:24 AM
Page generated in 0.25809 seconds with 24 queries
