 Old 02-04-2020, 11:56 PM   #1
T Lash's Avatar
Posts: 3   (View Stats)
T Lash is an unknown quantity at this point
Default Popping noise from intake on start up
I bought this car from my girlfriend. Long story. When I bought it the engine had been pulled due to a blown engine. The mechanic that tore it down left the state due to a family emergency. It took me a while to find a mechanic that would put the puzzle back together. I bought a engine an turbo from Mazda. From day one the engine makes a popping noise for a few seconds then stops. I could smell exhaust fumes. It took me a while to find where it was coming from. I took the intake off and had it resurfaced. I put it back together and I still have the same issue. I screwed up and did not check the head with a strait edge before I re assembled it.
On disassembly I found the blow by on cylinder 4.
Has anyone had this issue? What was the fix?
T Lash is offline   Reply With Quote
 Old 02-05-2020, 07:03 AM   #2
MSMS3's Avatar
Posts: 2,826   (View Stats)
If the head is warped, get it resurfaced. But you could have some other issue. Why do you say you have “blow by” on cylinder 4?
If it’s a loss of compression, it could be a valve not seating or burned, an injector seal, for instance. Is the engine properly timed?
 Old 02-05-2020, 08:37 AM   #3
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
please define poping noise ?
the intake isn't likely to warp much as head and intake is aluminium. But head to bloc is another story. rebuilding an engine without surfacing the head to bloc surface is likely to make problems unless is carefully checked....But none of those issue would create a noise at start that disappear later...
you can do a air path leak test, there is plenty of threads about it. IT is likely to shift your fuel trim and create a cell if it goes above or below 25% correction
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Right rear popping noise Izapyou MazdaSpeed 6 - Engine, Transmission & Driveline 19 03-12-2019 03:25 PM
Suspension problem popping noise Yao06ms6 Mazdaspeed3/6 General Discussion 2 11-16-2017 03:44 PM
CX7 Popping Noise between 2000-3000rpm DeeOrzz340 CX-7 > Issues & Troubleshooting 6 03-07-2017 09:20 PM
start up popping jhise MazdaSpeed 6 - Engine, Transmission & Driveline 0 09-24-2015 12:07 PM
Popping noise from Speaker on startup rastlun 2010 MS3 - Troubleshoot/Diagnostics 13 05-30-2013 05:54 PM
Page generated in 0.24070 seconds with 22 queries
