 Old 07-06-2012, 04:17 PM   #1
AFcadet's Avatar
Posts: 937   (View Stats)
AFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the world
Default Possible Fuel Rail Pressure sensor failure?
So I threw a P0192 CEL this morning and the car is running like shit whenever I put any load/boost on the motor. I beleive once it goes into open loop, the motor hesitates and sputters.
I looked at the fuel pressure...and the HPFP Pressure Act. is 0. The HPFP Volts is 0 also. I know for a fact though that the pressure is not 0...because the motor is idling fine...and I can accelerate slowly without any problem. I had a FP sieze one time and I was running off the 50psi from the low pressure pump, and the car would barely idle and actually driving was almost impossible.
Anyways...I am thinking its possibly the fuel rail pressure sensor that failed...so I unplugged it to see if anything would change (Thinking if nothing changed...then the sensor is bad). Well when I unplugged it...the volts went up to 4.8-4.9. When I plugged the sensor back in, it went back to 0.
Now I know the sensor is a "resistor" type sensor...so is that normal for the volts to jump up like that? Then when I plugged it back in...it went back to 0?
Reason I ask is I'm trying to rule out the possibility of a wiring issue...from a short curcuit etc. Anyone have experience with this?
AFcadet is offline   Reply With Quote
Fuel Rail High Pressure Sensor Upgrade JumpingJackson MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 234 10-25-2014 01:54 AM
fuel rail pressure sensor Skup1993 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 3 02-05-2011 09:14 PM
where can i find a mazdaspeed 3 fuel rail pressure sensor? Skup1993 MazdaSpeed 6 - Engine, Transmission & Driveline 8 02-05-2011 08:29 PM
where can i find a mazdaspeed 3 fuel rail pressure sensor? Skup1993 MazdaSpeed 3 - Engine, Transmission & Driveline 1 02-05-2011 05:59 PM
Page generated in 0.22584 seconds with 20 queries
