 Old 01-06-2010, 12:31 PM   #1
shpankey's Avatar
Posts: 496   (View Stats)
shpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the world
Default Question about do it yourself oil changes under warranty.
On my 09 MS3, the first time (3k mi.) I let Mazda do my oil change b/c it was free. After I got it back, I checked the oil and it was at the VERY BOTTOM of the fill line. So I added half a quart to get it to the middle of the fill line. But that worried me. So since then, I've done my own.
But with all the blown engines and Mazda saying you have to prove your oil changes, how does one do this exactly? I have kept all my receipts for oil and filter's... but I have bought in mass a couple times. Meaning I bought 10 quarts of oil here. Then a couple 5 quarts jugs there, and a filter for it here and there, sometimes with the oil, once on it's own I think. Anyhow, I just throw all those in my glove department and haven't worried. The thing is, the dates are rather erratic, and for one oil change to the next, I have used oil that I bought all at once back earlier in the year.
Just wondering, am I supposed to like, wait till it's time to change the oil, then go down and only buy 5.5 quarts (err 6) and the filter and that's it? Then wait till the next change?
The reason I ask is b/c I usually wait and catch the good stuff (GC 0w-30, PP 5w-30, or M1 0w-40 and SynPower 5w-30) on sale then buy in bulk for my car, my wifes truck and my daughters car and set it all aside in the garage for later. But it's usually all on one receipt.
So if something ever happens, am I safe? I can produce all the receipts no problem, but it's for a bunch of oil and filters at different times that don't correlate to the dates I changed the oil.
p.s. I've kept my mods light and easy. I can put everything back to stock in a couple hours.
09 Speed 3 GT
shpankey is offline   Reply With Quote
 Old 01-06-2010, 12:33 PM   #2
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
to be honest mazda is gona find every way they can to fuck you over. btu as soon as u bring legal action into it, you should be more then fine. your mods are also light enough that u should be fine
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 01-06-2010, 12:36 PM   #3
shpankey's Avatar
Yeah I think I'm done with modding until the warranty is up. Right now the mods are all simple stuff I can change out with ease. The only thing I'm considering is an AP with a dyno tune at the COBB Plano place, since that should make it safer and it can be "unmarried" and put back to stock in 30 minutes, or so I hear.
09 Speed 3 GT
 Old 01-06-2010, 01:28 PM   #4
KR....i haz it
Blackspeed's Avatar
Posts: 2,845   (View Stats)
Blackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the world
Groans: 166
I do the same thing, buy bulk. I just keep a record of the date and mileage of oil changes. I think if you have the corresonding amount of oil and filters on receipt, you will be fine.
By the way, mazda can still tell the ecu was flashed when you unmarry the AP.
Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts |
CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp
While the other forum is GREAT for technical/mechanical information and how to, that place is filled with single-minded (if you aren't driving fast, you're doing it wrong), arrogant, and professional douchebags.
Blackspeed is offline   Reply With Quote
 Old 01-11-2010, 09:51 PM   #5
meh, no ideas
Jedyboyrokr's Avatar
Posts: 528   (View Stats)
Jedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the world
wow thats gay---my dad works for ford and has stories of stupid little things voiding the warranty
89 toyota supra 1JZ Twin Turbo---Sold
2006 MS6 GT few mods ---Sold
Monaco White '13 Genesis 2.0T R-Spec-- ISIS downpipe/testpipe, Agency Power CBE, Injen SRI, Forge BOV, JBR Heavy Shift knob should be 240ish wheel right now, tune coming April 27th
Jedyboyrokr is offline   Reply With Quote
 Old 01-12-2010, 09:40 AM   #6
clos561's Avatar
Posts: 1,172   (View Stats)
clos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the world
make a log sheet and take down the date and mileage and keep all your reciepts.
7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance
clos561 is offline   Reply With Quote
Took my car in for warranty eumylove 2010 MS3 - Troubleshoot/Diagnostics 57 12-01-2011 01:54 AM
Question about Blown Engines, COBB AP's, and Warranty 6-Speed-6 MazdaSpeed 3 - Engine, Transmission & Driveline 6 10-16-2009 09:14 PM
cpe warranty speeddemon MazdaSpeed 3 - Engine, Transmission & Driveline 12 07-21-2009 10:32 PM
warranty? gtlaw
Cobb Access Port/Maps
8 02-18-2009 07:26 PM
Warranty question dimaxxxl Mazdaspeed3/6 General Discussion 2 10-10-2008 01:10 PM
Page generated in 0.26913 seconds with 24 queries
