  • 1 Post By Djohns
 Old 10-29-2017, 10:51 PM   #1
HacksawMatt's Avatar
Posts: 4   (View Stats)
HacksawMatt is an unknown quantity at this point
Default Serpentine belt won't fit back on
Need some help. Mazdaspeed 6. Serpentine belt issue: I can't get enough slack to get the belt over the pulley. I changed the clutch about a month ago and I was able to move the tensioner pulley with one hand while slipping the belt over the power steering pulley with the other. Car drove fine for a month.
Took the serpentine belt off again over the weekend to rebuild the power steering pump. Now, even with help, I can't even get close to enough slack to get the belt back on. Replaced the tensioner pulley and compared old belt to new belt, old belt is a little longer. Old belt was soaked with ATF from power steering pump leak. Am I missing something?
HacksawMatt is offline   Reply With Quote
 Old 10-30-2017, 04:10 AM   #2
DrewGen2's Avatar
Posts: 16   (View Stats)
DrewGen2 has a spectacular aura aboutDrewGen2 has a spectacular aura about
I have ran into this on occasion at work. Either 1. The belt isn't on the ribs all the way. 2. the new belt is a hair too short ( but you said you measured that). 3. I put the belt on every pulley and install it on the smooth water pump pulley last to gain the most slack.
DrewGen2 is offline   Reply With Quote
 Old 10-30-2017, 08:15 AM   #3
ChaunceyM's Avatar
Posts: 948   (View Stats)
ChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the world
When I put a new belt on my MS3 I really had to crank the tensioner all the way loose and then struggle to get it on. Wedged the wrench on the tensioner against my shoulder so I could use 1 hand to turn the crank and the other to muscle the belt over the last pulley.
Corksport: SRI & TIP, Strut Tower Brace, Coilovers
CP-e: RMM
JBR: Rear Sway Bar (with Moog End Links)
TWM: Full Replacement Shifter
Cobb: AP
AutoTech: HPFP Internals
Ebay: Test Pipe
ChaunceyM is offline   Reply With Quote
 Old 10-30-2017, 11:08 PM   #4
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
My tensioner was bottomed out to get the belt slid over the final SMOOTH pulley. As mentioned above, save a smooth pulley for last. It makes a world of difference.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 10-30-2017, 11:31 PM   #5
Djohns's Avatar
Posts: 3,944   (View Stats)
super easy like this.
Fstrnyou likes this.
2010 black mica speed3
Soon:built motor
 Old 10-31-2017, 05:31 AM   #6
Fstrnyou's Avatar
That's a tad easier on a Speed3 but pretty slick move.
Other rides:
History:
 Old 10-31-2017, 06:37 AM   #7
MSMS3's Avatar
Posts: 2,827   (View Stats)
If above does not work, put the belt in an over on very LOW heat. if you can get it up to about 110-120 degrees, no more, it will stretch temporarily, enough to fit over that last pulley without damaging the belt. Work fast while it is warm. You can also soak it in hot water and do the same thing.
This is a tried and true old mechanics trick. If the belt has Kevlar plies in it, some do, some don't, it won't stretch much.
 Old 10-31-2017, 07:46 AM   #8
ChaunceyM's Avatar
Another trick, zip-tie the belt to the pulleys when you're threading it on. Especially if you're working alone. That way it won't fall off other pulleys while you're working to get it on the last one. Then just snip the ties when you're done.
CP-e: RMM
Cobb: AP
Ebay: Test Pipe
The Following User Says Thank You to ChaunceyM For This Useful Post:
MSMS3 (11-02-2019)
 Old 11-02-2019, 07:00 PM   #9
AngryOrchard99's Avatar
Posts: 8   (View Stats)
AngryOrchard99 is an unknown quantity at this point
Im also having trouble getting the belt back on. Im trying to turn the bolt counter clockwise but it wont budge. Any help could be appreciated
AngryOrchard99 is offline   Reply With Quote
 Old 11-02-2019, 08:28 PM   #10
Police - Grammarhead
Vansquish's Avatar
The tensioner pulley has to be rotated clockwise, not counter clockwise, to release tension.
MSMS3 (11-02-2019)
Serpentine Belt Zeya MazdaSpeed 3 - Engine, Transmission & Driveline 8 05-24-2016 12:09 PM
serpentine belt Project_dog CX-7 > Engine, Transmission & Driveline 3 04-24-2014 09:37 AM
Changing serpentine belt HARPER306 MazdaSpeed 3 - Engine, Transmission & Driveline 3 05-29-2011 02:19 PM
Serpentine belt 07Speed3007 MazdaSpeed 3 - How-To's 19 02-12-2011 08:01 PM
Page generated in 0.31418 seconds with 27 queries
