 Old 02-04-2020, 11:44 PM   #1
T Lash's Avatar
Posts: 3   (View Stats)
T Lash is an unknown quantity at this point
Default Speed 6 electrical manual
I am in need of the Speed 6 electrical manual. I am searching for the color codes for the engine harness. I have two connectors that are the same. One is for the VTCS the other one is for the Knock sensor. The O am getting codes for both. The VTCS is shows stuck closed or stuck open depending on which connector I use. I may have screwed both sensors up by switching the connectors.
I am also getting a code for the EGR but I am not worried about it since I removed it and installed a EGR block off.
Thanks for any help.
T Lash is offline   Reply With Quote
 Old 02-05-2020, 07:51 AM   #2
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
you may look at engine harness pictures, unless you removed all the tape, each follow a pattern to be plugged at the right place. I played with that quite few times and if you have to remove tape or squeeze them, it is because there is something wrong...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Speed 6 Workshop Manual 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 26 04-16-2018 10:48 AM
Chevy Camaro to get Corvette's seven-speed manual? Haltech Automotive News 0 01-22-2018 08:20 AM
Report: Next Corvette will sport seven-speed manual, too Haltech Automotive News 0 09-26-2011 09:50 AM
Mazda CX-5 to get 2.2-liter turbodiesel, six-speed manual Haltech Automotive News 0 06-15-2011 03:10 PM
Report: Next-gen Porsche 911 to get seven-speed manual transmission? Haltech Automotive News 2 06-01-2011 07:41 AM
Page generated in 0.23066 seconds with 21 queries
