Like Tree3Likes
  • 1 Post By gt5
  • 1 Post By Bantug
 Old 02-26-2010, 06:34 AM   #1
gt5
gt5's Avatar
Posts: 273   (View Stats)
gt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the world
Default These are all the trouble codes for mazdaspeed 3 check engine light
Here are all the codes just in case someone needs them.
P0011 CMP timing over-advanced ON 2 CCM
P0012 CMP timing over-retarded ON 2 CCM
P0031 Front HO2S heater circuit low input ON 2 O2 sensor heater
P0032 Front HO2S heater circuit high input ON 2 O2 sensor heater
P0037 Rear HO2S heater circuit low input ON 2 O2 sensor heater
P0038 Rear HO2S heater circuit high input ON 2 O2 sensor heater
P0101 MAF sensor inconsistent with TP sensor or engine speed ON 2 CCM
P0102 MAF circuit low input ON 1 CCM
P0103 MAF circuit high input ON 1 CCM
P0106 MAP sensor performance problem ON 2 CCM
P0107 MAP sensor circuit low input ON 1 CCM
P0108 MAP sensor circuit high input ON 1 CCM
P0111 IAT circuit performance problem ON 2 CCM
P0112 IAT circuit low input ON 1 CCM
P0113 IAT circuit high input ON 1 CCM
P0117 ECT circuit low input ON 1 CCM
P0118 ECT circuit high input ON 1 CCM
P0122 TP sensor No.1 circuit low input ON 1 CCM
P0123 TP sensor No.1 circuit high input ON 1 CCM
P0125 Excessive time to enter closed loop fuel control ON 2 CCM
P0126 Coolant thermostat stuck open ON 2 Thermostat
P0128 Coolant thermostat stuck open ON 2 Thermostat
P0131 Front HO2S (stuck low) ON 2 CCM
P0132 Front HO2S (stuck high) ON 2 CCM
P0133 Front HO2S circuit malfunction ON 2 O2 sensor
P0134 Front HO2S circuit no activity detected ON 2 CCM
P0137 Rear HO2S circuit low input ON 2 CCM
P0138 Rear HO2S circuit high input ON 2 CCM
P0140 Rear HO2S circuit no activity detected ON 2 CCM
P0171 Fuel trim system too lean ON 2 Fuel
P0172 Fuel trim system too rich ON 2 Fuel
P0222 TP sensor No.2 circuit low input ON 1 CCM
P0223 TP sensor No.2 circuit high input ON 1 CCM
P0300 Random misfire detected Flash / ON 1 or 2 Misfire
P0301 Cylinder No.1 misfire detected Flash / ON 1 or 2 Misfire
P0302 Cylinder No.2 misfire detected Flash / ON 1 or 2 Misfire
P0303 Cylinder No.3 misfire detected Flash / ON 1 or 2 Misfire
P0304 Cylinder No.4 misfire detected Flash / ON 1 or 2 Misfire
P0327 Knock sensor circuit low input ON 1 CCM
P0328 Knock sensor circuit high input ON 1 CCM
P0335 CKP sensor circuit malfunction ON 1 CCM
P0340 CMP sensor circuit malfunction ON 1 CCM
P0401 EGR flow insufficient detected ON 2 EGR
P0402 EGR flow excessive detected ON 2 EGR
P0403 EGR valve (stepper motor) circuit malfunction ON 2 CCM
P0420 Catalyst system efficiency below threshold ON 2 Catalyst
P0441 Evaporative emission control system incorrect purge flow ON 2 Evaporative
P0442 Evaporative emission control system leak detected (small leak) ON 2 Evaporative
P0443 Evaporative emission system purge control valve circuit malfunction ON 2 CCM
P0446 Change over valve (COV) (EVAP system leak pump) stuck close ON 2 Evaporative
P0455 Evaporative emission system leak detected (gross leak) ON 2 Evaporative
P0456 Evaporative emission system leak detected (very small leak) ON 2 Evaporative
P0461 Fuel gauge sender unit circuit range/performance ON 2 CCM
P0462 Fuel gauge sender unit circuit low input ON 2 CCM
P0463 Fuel gauge sender unit circuit high input ON 2 CCM
P0480 Fan relay No.1 control circuit malfunction OFF 2 Other
P0481 Fan relay No.2 and No.3 control circuit malfunction OFF 2 Other
P0482 Fan relay No.4 control circuit malfunction OFF 2 Other
P0500 Vehicle speed sensor (VSS) circuit malfunction ON 2 CCM
P0505 Idle control system malfunction OFF
P0506 Idle control system RPM lower than expected ON 2 CCM
P0507 Idle control system RPM higher than expected ON 2 CCM
P0550 PSP switch circuit malfunction ON 2 CCM
P0564 Cruise control switch circuit malfunction OFF 1 Other
P0571 Brake switch circuit malfunction OFF 1 Other
P0601 Internal control module memory check sum error ON 1 CCM
P0602 PCM programming error ON 1 CCM
P0604 PCM RAM error ON 1 CCM
P0606 ECM/PCM processor ON 1 CCM
P0607 Control module performance ON 1 CCM
P0610 Control module vehicle options error ON 1 CCM
P0638 Throttle actuator control range/performance ON 1 CCM
P0661 Variable intake-air system control solenoid valve circuit low input OFF 2 Other
P0662 Variable intake-air system control solenoid valve circuit high input OFF 2 Other
P0703 Brake switch No.1 circuit malfunction ON 2 CCM
P0704 Clutch switch circuit malfunction ON 2 CCM
P0850 Neutral switch circuit malfunction ON 2 CCM
P1410 VAD control system circuit malfunction OFF 2 Other
P1562 PCM +BB voltage low ON 1 CCM
P2004 Variable tumble control system (VTCS) shutter valve stuck open ON 2 CCM
P2006 Variable tumble control system (VTCS) shutter valve stuck closed ON 2 CCM
P2009 Variable tumble control solenoid valve circuit low input ON 2 CCM
P2010 Variable tumble control solenoid valve circuit high input ON 2 CCM
P2088 CMP actuator circuit low ON 2 CCM
P2089 CMP actuator circuit high ON 2 CCM
P2097 Post Catalyst Fuel Trim System Too Rich
P2100 Throttle actuator circuit open ON 1 CCM
P2101 Throttle actuator circuit range/performance ON 1 CCM
P2102 Throttle actuator circuit low input ON 1 CCM
P2103 Throttle actuator control motor circuit high input ON 1 CCM
P2107 Throttle actuator control module processor ON 1 CCM
P2108 Throttle actuator control module performance ON 1 or 2 CCM
P2119 Throttle actuator control throttle body range/performance ON 2 CCM
P2122 Accelerator pedal position (APP) sensor No.1 circuit low input ON 1 CCM
P2123 Accelerator pedal position (APP) sensor No.1 circuit high input ON 1 CCM
P2127 Accelerator pedal position (APP) sensor No.2 circuit low input ON 1 CCM
P2128 Accelerator pedal position (APP) sensor No.2 circuit high input ON 1 CCM
P2135 Throttle position sensor No.1/No.2 voltage correlation ON 1 CCM
P2138 Accelerator pedal position (APP) sensor No.1/No.2 voltage correlation ON 1 CCM
P2177 System too lean at idle, bank 1
P2187 System too lean at idle, bank 2
P2228 BARO sensor circuit low input ON 1 CCM
P2229 BARO sensor circuit high input ON 1 CCM
P2401 Evaporative emission system leak detection pump control circuit low ON 2 Other
P2402 Evaporative emission system leak detection pump control circuit high ON 2 Other
P2404 Evaporative emission system leak detection pump sense circuit malfunction ON 2 Other
P2405 Evaporative emission system leak detection pump sense circuit low input ON 2 Other
P2406 Evaporative emission system leak detection pump sense circuit high input ON 2 Other
P2407 Evaporative emission system leak detection pump sense circuit intermittent ON - Other
P2502 Generator terminal B circuit open OFF 1 Other
P2503 Generator output voltage signal no electricity OFF 1 Other
P2504 Battery overcharge OFF 1 Other
Rhyno likes this.
gt5 is offline   Reply With Quote
The Following 40 Users Say Thank You to gt5 For This Useful Post:
2008speed3 (04-27-2013), akbrazil (04-01-2012), asall667 (04-28-2013), blicaspd3 (01-31-2015), BobbleHead (11-08-2011), chaser27 (12-08-2014), Code Monkey (04-28-2013), Dash08 (08-04-2013), dkapetansky (09-10-2011), dougefresh_ (04-27-2013), ELKhunter (03-16-2015), EwMPS (08-04-2013), Fail_6 (09-25-2011), Ferg (12-01-2011), Fiberguy (09-30-2019), FridayGt (04-26-2010), Hypnotized (03-04-2010), johnathan_723 (04-16-2016), kaprikorn (04-09-2012), Kellerspeed3 (01-05-2018), kgb (07-14-2013), kunfu (12-17-2010), lmnt (06-26-2013), mason (05-09-2012), Mchart (04-30-2013), mike8748 (03-06-2010), MZRSPEED (07-15-2013), onelove221 (10-15-2012), phate (02-26-2012), Post pwned (09-08-2011), R4LLY3 (09-07-2013), rx7mazda (01-25-2012), SarcasticOne (01-01-2013), soulitified (06-05-2017), SpeedNess (02-26-2010), Tedspeed6 (10-23-2013), twincitySPEED6 (09-10-2013), Worbit (07-16-2012), xPEPEx (06-18-2010), [Braxton] (05-28-2011)
 Old 04-27-2013, 05:24 PM   #2
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Very nice.
 Old 04-28-2013, 09:35 AM   #3
asall667's Avatar
Posts: 1,017   (View Stats)
asall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the world
Groans: 56
Groaned at 37 Times in 18 Posts
Lol made in 2010
2007 CBM MS3 GT 66K
Mods:
--Cobb SF SRI--Corksport TIP-- Speed Daddy FMIC Piping w/ TR8 Core--CPE 75A RMM--Test Pipe--Both res delete--TWM Short Shifter--Custom Fabric wrapped A pillars & Side Pillars--Gunmetal PC Genpu Wheels--Mazdaspeed Red Calipers (front & rear)--Laminx Fog Overlays--Foglight Mod--3M Gloss Black Roof--Custom Mudflaps--Evil Flying M--CPE Triple Gauge Pod--Propsort Boost-Oil Temp-Oil Pressure Gauges--Prosport Sammich Plate--SU Oil Spin On Conversion--Magnetic Drain Plug--Raceland Coilovers--SPC Rear Camber Arms--15MM H&R Spacers--Hawk HPS pads--Turbosmart Plumb Back BPV----
New VVT as of 50K miles Thanks Young Mazda
New K04 Turbo as of 57K miles Thanks Young Mazda
asall667 is offline   Reply With Quote
 Old 04-28-2013, 09:52 AM   #4
I was adding it as a sub and intentionally bumping it.
It's too bad it's not a sticky in the Diagnostic section.. not sure why it's in here.
The Following 2 Users Say Thank You to dougefresh_ For This Useful Post:
asall667 (04-28-2013), Flipboi89 (04-28-2013)
 Old 04-29-2013, 01:49 PM   #5
Jeremy's Avatar
Posts: 200   (View Stats)
Jeremy is the leader of the worldJeremy is the leader of the worldJeremy is the leader of the worldJeremy is the leader of the worldJeremy is the leader of the worldJeremy is the leader of the worldJeremy is the leader of the worldJeremy is the leader of the worldJeremy is the leader of the worldJeremy is the leader of the worldJeremy is the leader of the world
This should be stickied
NATOR-WA
2007 Black Mica MS3 Sold
Jeremy is offline   Reply With Quote
 Old 07-12-2013, 08:23 PM   #6
MS6219's Avatar
Posts: 144   (View Stats)
MS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond repute
I second that for stickie... We need one for our speed6's too though. :/
06 MS6 GT W/NAVI Freektuned 411AWHP 397AWTQ W/3 gal E85, 93oct: 351AWHP 365AWTQ BNRs3, magnaflow CBE, eBay catless down pipe, CX-racing FMIC, Autotech internals, turbosmart dual port bpv, sure Full3 Aeros, grimmspeed 3 port EBC, ITV22, JBR EGR delete, JBR 80 TMM, JBR 80 PMM, SURE RMM, SURE Dreadnaught, CS short shift plate, 3 bar MAP w/PNP harness, block8head vent pod w/depot boost gauge, AP, ZZB...
06 MS6 GT W/NAVI CS stage II sri, JBR RMM, turbosmart dual port bpv, ultimate racing tp
MS6219 is offline   Reply With Quote
 Old 08-04-2013, 12:43 PM   #7
rolanblack's Avatar
Posts: 2,110   (View Stats)
@Raider; make into sticky please. Don't know how this was overlooked
The Following User Says Thank You to rolanblack For This Useful Post:
jm211 (08-04-2013)
 Old 08-09-2013, 07:16 AM   #8
Bantug's Avatar
Posts: 2   (View Stats)
Bantug will become famous soon enoughBantug will become famous soon enough
Default Complete n00b question..
so the check engine light came on my '09 Speed3. I have scoured the sight to find out HOW to obtain codes and this is what I found...
don't listen to these goofs. hold down the trip meter reset button while turning the key to 'on'. you will see the flashing dashes. press it two more times and you'll then be in a diagnostic menu that will tell you the specific component that is failing. make sure you are in neutral, e-brake off, and not pressing any of the pedals (you may have to put a brick under a tire if you are on a grade). if you are pressing any of the pedals while doing this, they will fail the diagnostic check and youll have the CEL on for yet another reason. when i did this on mine, i even had the dome light on and the ECU flagged it. make sure everything is off!
If this is right, it went into a "Test" mode. went thru them all and didn't find a Pxxxx code. Closest thing I found was a 0043 with 22 underneath it. Someone school me...
brennaleigh likes this.
Bantug is offline   Reply With Quote
 Old 08-09-2013, 04:48 PM   #9
rolanblack's Avatar
If you don't have an AP, go to your local auto store to get the code pulled. I have not heard that before but I'm sure someone has
 Old 11-30-2014, 10:13 PM   #10
jrgbhn's Avatar
Posts: 1   (View Stats)
jrgbhn is an unknown quantity at this point
Default cutting out.
CorkSport short ram intake with turbo inlet hose, OBX catback exhaust, OBX downpipe ,front mount intercooler,blow off valve recirculating,access port v3, tuned to stage 3
ever since I put the OBX downpipe everytime I step on it it cuts out like its losing gas spark or air its also putting out that code p0137 which says Bank 1 sensor 2 circuit low and p0139and this one says the same thing pretty much except it says slow response
Can anyone help?
jrgbhn is offline   Reply With Quote
 Old 11-30-2014, 10:31 PM   #11
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
Make a new thread. Donate. Post a log.
 Old 12-01-2014, 06:58 AM   #12
chaser27's Avatar
Posts: 1,276   (View Stats)
Groans: 42
Can anyone help?
Make an intro thread, quit the "Stage 3" crap and get a real tune. That being said, you probably have an 02 extender and you don't want to use one. It will probably throw a different code when you take it out and you can just turn it off.
Coming at ya with all 297/359
ECU: self-tuned
RADAR: Passport Escort 9500ci
 Old 09-27-2015, 06:06 PM   #13
Mazda2012's Avatar
Posts: 52   (View Stats)
Mazda2012 has much to be proud ofMazda2012 has much to be proud ofMazda2012 has much to be proud ofMazda2012 has much to be proud ofMazda2012 has much to be proud ofMazda2012 has much to be proud ofMazda2012 has much to be proud ofMazda2012 has much to be proud ofMazda2012 has much to be proud of
Groaned at 56 Times in 8 Posts
What does "On 2 Fuel" mean? Refer to code P0171
Mazda2012 is offline   Reply With Quote
 Old 09-27-2015, 06:06 PM   #14
Nice, necro on a year old thread.
sent from my HTC One M9
 Old 06-25-2017, 03:08 AM   #15
dillstaaaa's Avatar
Posts: 11   (View Stats)
dillstaaaa has a little shameless behaviour in the past
I have a '12 speed3 and it threw a p0300 and the mechanic drove the car and said it had no loss of power and the cel went away. the cel came back on recently and went away again. has anyone else had this problem?
Sent from my SM-G935T using Tapatalk
dillstaaaa is offline   Reply With Quote
 Old 10-01-2019, 05:52 PM   #16
LivinlavidaSpeed3's Avatar
Posts: 5   (View Stats)
LivinlavidaSpeed3 is an unknown quantity at this point
Any one have a current list i have a p0579 and a p2006... obviously i can google them but i only find generic information
LivinlavidaSpeed3 is offline   Reply With Quote
 Old 10-01-2019, 07:03 PM   #17
Police - Grammarhead
Vansquish's Avatar
There's a thread with a fix for p2006/p2009 on this very forum. Use the search tool in my signature if you need help googling.
 Old 10-21-2019, 01:36 PM   #18
iplant5's Avatar
iplant5 has a little shameless behaviour in the past
Default CEL 2007 speed3
Should i be worried that my check engine light keeps coming on and shutting off for a few days. I recent did spark plugs, oil change, car has 140.000? should i get it in a shop and check head gaskets or anything serious? first speed3
iplant5 is offline   Reply With Quote
The Following User Says NO Thank You to iplant5 For This Un-useful Post:
Db09ms3 (10-21-2019)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f293/these-all-trouble-codes-mazdaspeed-3-check-49825/
Thee NYPOC Lounge - Page 207 - ProbeTalk.com Forums This thread Refback 07-07-2011 10:07 AM
Social Engine Neutral Light Template 3 17 ? 3 20 | Wordpress Templates Blogger | New Blogger Wordpress Template This thread Refback 06-04-2011 12:12 PM
mazdaspeed 3 purge valve - Zuula Search This thread Refback 04-12-2010 07:43 PM
Check Engine Light is on armarine04 MazdaSpeed 3 - Engine, Transmission & Driveline 9 09-21-2009 11:37 AM
Check Engine Light on '09 MS# FXT&MS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 05-17-2009 08:45 AM
Oh No Check Engine Light! thabigo MazdaSpeed 6 - Engine, Transmission & Driveline 8 04-04-2009 01:57 PM
PLEASE HELP! Trouble with engine light and check oil! spd6rcr08 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 10-01-2008 10:00 AM
Check engine light??? supergoose MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 07-20-2008 07:42 AM
Page generated in 0.40769 seconds with 35 queries
