 Old 01-07-2010, 06:36 PM   #1
gordita720's Avatar
Posts: 6   (View Stats)
gordita720 is an unknown quantity at this point
Default Tire Pressure Gauge
I just put some new rims/tires on my car and this gauge is staying on. How do you reset?
gordita720 is offline   Reply With Quote
 Old 01-07-2010, 06:54 PM   #2
gt5
gt5's Avatar
Posts: 273   (View Stats)
gt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the world
Did you have the sensors that go inside the tires put on as well when you put the new rims and tires on, cause if there is no sensors in the tires i don't think u can reset it because there is no reading of tire pressure to send to turn off the tire pressure light. I have the same light in my car and i also had it on my scion tc before when i changed the rims. If you still have the stock rims you may be able to take them off those wheels and put them on the new rims depending on the size of rim u have on now but they would have to take the tires off the new rims to put the sensors on. To be honest i wouldn't even worry about that.
gt5 is offline   Reply With Quote
 Old 01-07-2010, 06:59 PM   #3
gordita720's Avatar
are they a satellite sensor? because there was nothing attached to the inside of the tire that i could see.....
 Old 01-07-2010, 07:04 PM   #4
gt5
gt5's Avatar
I think the sensor should be attached to the rim it self, if you still have the stock rims look at the air pressure valve it should all be one piece.
 Old 01-07-2010, 07:24 PM   #5
PaPaSpeed's Avatar
Posts: 602   (View Stats)
PaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the world
Yeah, The TPMS are on the bottom of the stock valves. You gotta switch them to the new rims.
Here's the reset procedure from the manuel.
Without Using M-MDS
i. Turn the ignition switch to the ON position, then turn it off.
2. Leave the vehicle with the engine off for 15 min or more.
3. Drive the vehicle at a speed of 25 km/h {15.5 mph} or more for 10 min or more.
4. After driving for 10 min, verify that the TPMS warning light does not flash and is not illuminated.
CP-E Nano, CP-E Turbo inlet, CP-E TurboBack, CP-E Full Control, CP-E CDFP, CP-E Standback, Cobb RSB, ETS TMIC, SU Boost Tubes, SU MM, SU Shifter Bushings, Forge BPV, Eibach Pro Kit, Saikou Michi OCC, Denso ITV 22, Redline Hood Lifts, Redline (shift boot, armrest, e-brake cover), Amsoil 5w-30, Amsoil 75w-90, TWM A-6, Black badges, SU black side markers, 40% Tint, Rota Torques Gunmetalic.
PaPaSpeed is offline   Reply With Quote
 Old 01-16-2010, 12:15 AM   #6
jking65's Avatar
Posts: 4   (View Stats)
jking65 is an unknown quantity at this point
hey papaspeed thanks for your detailed instructions on how to reset without using m-mds.. i will bookmark this thread for my future references just in case ill encounter this kind of issue..
_____________
jimmyking65
mazda parts
jking65 is offline   Reply With Quote
 Old 01-18-2010, 07:50 AM   #7
mz32quick's Avatar
Posts: 192   (View Stats)
mz32quick has a reputation beyond reputemz32quick has a reputation beyond reputemz32quick has a reputation beyond reputemz32quick has a reputation beyond reputemz32quick has a reputation beyond reputemz32quick has a reputation beyond reputemz32quick has a reputation beyond reputemz32quick has a reputation beyond reputemz32quick has a reputation beyond reputemz32quick has a reputation beyond reputemz32quick has a reputation beyond repute
Groaned at 9 Times in 6 Posts
Without Using M-MDS
Didn't work for me, light stayed illuminated. Guess I will be making a trip to the dealership soon.
mz32quick is offline   Reply With Quote
 Old 01-18-2010, 09:59 AM   #8
KR....i haz it
Blackspeed's Avatar
Posts: 2,845   (View Stats)
Blackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the world
Groans: 166
sorry, but I didnt see a confirmation that you put sensors on these new wheels. Did you get new sensors , or have the stock ones transferred?
Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts |
CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp
While the other forum is GREAT for technical/mechanical information and how to, that place is filled with single-minded (if you aren't driving fast, you're doing it wrong), arrogant, and professional douchebags.
Blackspeed is offline   Reply With Quote
weird tire wear pattern. stock tires. stock rim. stock suspention. stock tire pressure what's up with this? labikesrcool MazdaSpeed 3/6 - Wheels & Tires 21 11-30-2015 03:32 PM
correct tire pressure?? wisniaPl MazdaSpeed 3/6 - Wheels & Tires 40 08-02-2012 04:17 AM
Tire Pressure Warning? Daddy 2010 MS3 - Wheels & Tires 11 01-09-2010 07:46 PM
GMC Sonoma Stalls, Sugar in the Gas Tank, Correct Tire Pressure, Ford Escape Tire Shimmy: Mike Allen's Weekly Online Aut Haltech Automotive News 0 07-25-2008 02:30 PM
Page generated in 0.28332 seconds with 25 queries
