 Old 02-27-2020, 07:04 PM   #1
grammates's Avatar
Posts: 19   (View Stats)
grammates is an unknown quantity at this point
Default Weird engine noise/metallic noise
Hello all I appreciate any guidance anyone has!
Backstory here is I had a buddy replace the VVT chain tensioner and actuator! As well as all the corresponding bolts and washers! At first I didn’t think it was timed right because it would idle weird and just overall didn’t feel right. At the time of that I also changed my oil over from PP to the rotella 5w-40.
I then took it to a reputable shop in my area that works on mazda and fords and have done numerous repairs. I had him check everything out and he had found out that my spark plug in cylinder 3 was cracked and also damaged the boot of the coil pack so that was replaced. Also cleaned off the Timing cover because it was leaking oil. Replaced bolts, seals on timing cover and valve cover as well as the spark plugs! It runs perfectly fine but the noise that I heard AFTER the oil switch paired with the chain fixing is still there. It was never there before am I being paranoid or is it something wrong, any insight would be greatly appreciated.
Link to the video!
https://vimeo.com/394337393/recommended
grammates is offline   Reply With Quote
 Old Today, 05:04 PM   #2
MSMS3's Avatar
Posts: 2,829   (View Stats)
Video/sound clip is too short. Maybe at least 30 sec to a full minute just idling, please.
Also check your dipstick on level ground and make sure the oil fill level is correct.
 Old Today, 05:08 PM   #3
grammates's Avatar
Okay can do that tomorrow do you want it to be warmed up or not?
Metallic Noise sandersjosh12 Gen2 MS3 General Discussion 10 04-23-2019 11:57 AM
Weird engine noise Raso12 MazdaSpeed 3 - How-To's 3 01-26-2018 08:30 AM
Throttle noise/ engine noise under28world 2010 MS3 - Engine, Transmission & Driveline 9 05-04-2015 06:25 PM
Weird noise from engine when lightly revving. csmaan12 2010 MS3 - Engine, Transmission & Driveline 0 03-07-2015 12:02 PM
Weird noise acarmona24 MazdaSpeed 3/6 - Turbo Induction 8 11-09-2014 10:04 PM
Page generated in 0.23302 seconds with 21 queries
