| MazdaSpeed 3/6 - Troubleshoot/Diagnostics MazdaSpeed 3/6 - Troubleshoot/Diagnostics - Have a problem with the car? CEL Code? Want to discuss other issues? Come on in! |
![]() Join Date: Feb 2013 Location: New castle, DE
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 11
Groaned at 10 Times in 3 Posts
(Thread Starter) | Not Ranked : 0 score hey guys today i was driving and i was sitting at a red light when i noticed white smoke coming out of my passanger side exhaust tips, but not out of the drivers side. it stopped and then came back about 10 minutes later when i was stopped again. i currently have a corksport CBE, ATP catless dp, HPFP internals, corksport SRI and TIP. after it did it the second time i havnt had it happen since. anything that could cause this? thanks for the help. |
![]() ![]() ![]() Join Date: Nov 2012 Location: Temecula, CA
Rep Power: 2724 ![]() Thanks: 3,896
| White smoke at idle and typically after decel is usually signs that oil is starting to blow by the seals in the turbo. Potentially start planning to either go BT or get your turbo warrantied
__________________ 2018.... Doing even more freeky things! 10.36@148 Fastest Gen 2 |
| The Following User Says Thank You to LumberJack For This Useful Post: | [R]usty (11-11-2013) |
(Thread Starter) | Not Ranked : 0 score is that a major problem? |
| Seriously? Yes, that should be a major concern of yours. The longer it continues and the worse it gets, you run the risk of destroying the turbo completely to where you may not even be able to drive your car. Now that's the extreme end of the scenario, but how about you donate to the forum and start reading SNF searching for some of these answers as well Sent from my LG-LS970 using Tapatalk
| The Following User Says Thank You to LumberJack For This Useful Post: | 6Y MAZDA (11-11-2013) |
(Thread Starter) | Not Ranked : 0 score should my turbo still be coverd by the warenty even after i have the dp and the intake? |
Get real familiar with stocking out and hope your dealer isn't douchey Sent from my LG-LS970 using Tapatalk
__________________ 2018.... Doing even more freeky things! 10.36@148 Fastest Gen 2 | |
![]() Join Date: Jan 2009 Location: Andover, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,936
Groans: 192
| Not Ranked : 0 score No. You really need to search. Hell you dont even need to search for that answer. Just think about that one. You modified the car using other than stock parts but you want them to warranty the risk you openly ignored.
__________________ precision gen2 5862 coming soon [SIZE="1"]07 MS3 GT.. Engine:Cobb V3,GTX3076r EWG,Wiseco Pistons/Manley Rods, L19's,JMF, Bosch 3.5bar MAP,CS cat-back,M2 DP, full race manifold,FP internals,FREEK 4",CP-E flange HKS,DO Stage II ss lines,Cobb piping,TR8L,MD RMM&TMM,JBR RSB & FSB,JBR SST,JBR knob,ACT 6puck,JBR EGR delete,CPE Seals,Grimmspeed EBC,JBR BSD,MD Catch Can.Looks:yellow lamin-x fogs,chrome turn signals,side moldings removed,20% tint,CS wheelSuspension/Wheels:Enkei RPF1 17x9,Eibach 5mm spaces H&R springs,koni yellows. GTX3076r --- 479/412 S4-460/400 Highest HP BNR S3 BNR-S3 424/397 |
| The Following User Says Thank You to taf0422 For This Useful Post: | mxlplx71 (11-11-2013) |
![]() Join Date: Feb 2013 Location: Montgomery, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 204
Groaned at 49 Times in 12 Posts
| Not Ranked : 0 score Is someone seriously asking "what does white smoke coming out of my exhaust mean"? And they have a dp?
__________________ 2007 Mazdaspeed 6 - Black Mica - ZZB RIP 2016! BNR S3, JBR 3" wp intake, JBR rmm, JBR heavy shift knob, JBR shifter bushings, JBR SSP, South Bend Stage 3 Endurance clutch, Juggernaught/Dreadnaught, Autotech HPFP, 3 bar map sensor, Stratified Boost Dial, Streetunit TMIC, Forge V2 BPV, ebay DP/TP, 3 inch custom single exit cat-back, magnaflow muffler, H&R springs, Cobb AP, JL Audio 12" W3 w/ 500w Alpine amp, 6000k HIDs, LED fogs, dipped and tinted - Stratified 369awhp/383awtq vdyno on 4 gallons of corn |
(Thread Starter) | Not Ranked : 0 score Yes that was a serious question. I don't know much about our cars yet but I'm still trying to learn. If I knew you guys would get all butt hurt over a question then shit what happened to nator? I expected serious answers not dick responses. |
![]() Join Date: Feb 2012 Location: Anaheim, Orange County
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,921
sent from my peepee
__________________ 2007 Mazdaspeed 3 GT 18x8.75 XXR 527 225/40/18r COBB AP// Finkles hypnotic sexyness 50/50 e85// HTP 3.5 Whale Penis// HTP 51R battery box// JBR Adjustable SSP//JBR 88 RMM// Grimspeed 3 port EBCS// CX Racing FMIC// CNT Racing catless DP// AT internals// Lamin-x Fog light inserts// Stiffy Ingals Mtourque Mount// Asian tower brace(lol)// CNT Racing Catback// Turbo XS RFL BOV VTA FTMFW!!// Upgrated clutch// Drilled and sloted rotors (font and back)// UNDER THE KNIFE New fucken miata build: 1993 Red Na6 Some suspension modz yo 1994 Caste White MX5 Miata - sold 1991 Smurf Blue miata - sooooooold Coilovers// Other shit | |
Groans: 192
| Not Ranked : 0 score Have you even been around long enough to know what nator even is? Nobody is getting butt hurt but you. Especially when asking questions that are so easily found just by simply search and a DP question which is just common knowledge.
![]() Join Date: Feb 2012 Location: Alexandria, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 862
| Not Ranked : 0 score Lol Brownie lecturing about Nator
__________________ 1996 Miata SOLD 2006 Black Cherry Mica MS6 Grand Touring #00584CP-E 3" Straight Pipe Exhaust. CP-E TMIC. StreetUnit TP. Street Unit RMM. HTP 3" TIP. Custom 3.5" MAF SRI. PTP HPFP Internals. Cobb AP. RichTuned. Denso ITV22. Forge V1 BPV. Blox Shift Knob. VEI Boost Gauge. 18x8.75 +33 XXR 530. Nitto Motivo 225/40/18. Megan Racing Springs. SOLD: 2009 Mazda 6i GT. 6-Speed MT. [SIGPIC][/SIGPIC] ![]() |
![]() Join Date: Nov 2010 Location: Jacksonville, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,647
| Not Ranked : 0 score We don't like brownies who fail to search. If you would have searched this problem, you would have found your answer within five minutes. It is annoying to have people ask the same question(s) over and over again. Do you understand? It is not personal, people just don't want to repeat themselves every time someone buys a speed3 and has similar questions or issues. Just search diligently first next time and if you still cannot come up with an answer, then post your question. But your question(s) have been covered so much that it is like nails on a chalk board to hear someone ask about it.
__________________ 2004 Dodge Dakota- SLT 4.7L V8- Burgundy 2013 Kawasaki Ninja 636 (Zx6r)- Green/ Black 2014 Honda Grom-Red 2014 Yamaha Grizzly 350- Blue 2007 Yamaha Raptor 700 GYTR- White- [SIGPIC][/SIGPIC] |
![]() Join Date: Nov 2012 Location: Leominster Mass
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,003
| Not Ranked : 0 score Modding your car isn't the smartest thing if you know nothing about it. |
| Not Ranked : 0 score Dude if you're going to mod your car, at least spend a few hours reading up on what you plan to do. It seems like a dick response to you because the information is sitting there readily available. If you search "mazdaspeed downpipe" on Google the first result is this thread, where it explains that you may get the smoking turbo problem after upgrading the downpipe: http://www.mazdaspeedforum.org/forum/foru...-thread-99627/ It's literally the second paragraph of this site's main downpipe thread. If you did 20 minutes of research on upgrading the downpipe you would have to find that thread. And then once you did, let's just say you wanted to follow up on the smoking turbo issue, so you google "mazdaspeed smoking turbo" - the first result is that same downpipe thread and then links to a bunch of other threads on this site discussing it. You joined at pretty much the same time I did, you've been on here long enough to know about the smoking turbo. I'm sorry this comes across as a "dick response" to you, but you're being lazy and asking for people to spoon feed you answers you can find on Google in 5 minutes.
| The Following User Says Thank You to biggman026 For This Useful Post: | 6Y MAZDA (11-11-2013) |
![]() Join Date: Jan 2013 Location: california
Rep Power: 0 ![]() Thanks: 2
Groaned at 22 Times in 7 Posts
| Not Ranked : 0 score my drivers side window and rear right window wont go down or up i hear the motor working but nothing happens what do you think it is anyone let me know 07 mazdaspeed 3. i think the is the motor done |
| Not Ranked : 0 score I hope this is sarcasm. If not, did you learn nothing from the OP's mistake?
![]() | | #19 | ![]() |
__________________ 1996 Miata SOLD 2006 Black Cherry Mica MS6 Grand Touring #00584CP-E 3" Straight Pipe Exhaust. CP-E TMIC. StreetUnit TP. Street Unit RMM. HTP 3" TIP. Custom 3.5" MAF SRI. PTP HPFP Internals. Cobb AP. RichTuned. Denso ITV22. Forge V1 BPV. Blox Shift Knob. VEI Boost Gauge. 18x8.75 +33 XXR 530. Nitto Motivo 225/40/18. Megan Racing Springs. SOLD: 2009 Mazda 6i GT. 6-Speed MT. [SIGPIC][/SIGPIC] ![]() | |
![]() | | #20 | ![]() |
![]() Join Date: Apr 2013 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 96
| Not Ranked : 0 score ...Brownies! MMMM MMM GOOD Holy shit guys, quit being cheap asses and donate. It is worth EVERY FUCKING PENNY. Unless you sawed your own legs off and can't work you have no right to ask a question unless you donate. Think servers magically host themselves? Think you can go ask any stranger how to mod your car? Think 20 guys are going to show up and fix your shit for free? Pay your money, donate, and don't look back. For less than 100 bucks you get people who give a shit, people who will trade beer for work, and connections to get help even when your SOL. Jesus fucking god damn monkey balls tap dancing Christ. |
| White smoke | aldekei | 2010 MS3 - Troubleshoot/Diagnostics | 7 | 07-22-2013 12:26 PM |
| White smoke campaign | kneedraggin101 | Mazdaspeed3/6 General Discussion | 4 | 04-06-2013 09:29 PM |
| Need help, white smoke and cooland gone AGAIN!~ | speed31982 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 1 | 02-03-2012 10:56 PM |
| White Smoke | Soriku1489 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 15 | 07-08-2010 05:25 PM |
| White smoke? PLEASE HELP | Fallenvoices | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 13 | 01-06-2010 03:39 PM |
