 Old 06-10-2010, 07:32 AM   #1
Soriku1489's Avatar
Posts: 24   (View Stats)
Soriku1489 will become famous soon enoughSoriku1489 will become famous soon enough
Default White Smoke
I was wondering if anyone knew how to fix this problem? Also if anyone knows why this is happening? My car has 76000+ miles on it and I'm worried that something drastic might happen.
Soriku1489 is offline   Reply With Quote
 Old 06-10-2010, 07:45 AM   #2
Kdawg207's Avatar
Posts: 2,389   (View Stats)
I changed my oil to 5w40 and it stopped
~~~NJ Nator OG~~~Then AND Now, Just Better~~~
Kdawg207 is offline   Reply With Quote
 Old 06-10-2010, 07:58 AM   #3
BoostIsBetter's Avatar
Posts: 582   (View Stats)
BoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the world
Groaned at 31 Times in 18 Posts
white smoke? white smoke is bad... really bad...
BoostIsBetter is offline   Reply With Quote
 Old 06-10-2010, 08:10 AM   #4
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
depends if it dissipates or lingers. Dissipating white smoke=coolant.
lingering white smoke=oil.
swap to 5w40 oil, or 10w40 oil and see if that helps the problem. If not, you may have blown seals on yer snail. Dealer visit for you!
07 MS3
The original Genpoo Hater
 Old 06-10-2010, 09:08 AM   #5
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
how's your coolant level?
 Old 06-10-2010, 09:12 AM   #6
Soriku1489's Avatar
topped up on my coolant. the white smoke is light when idle and I don't believe i see it while i'm driving. I see puffs once in a while.
Will do a oil change to see if that stops the problem. Also, the smoke smells sort of sweet but bad. Thats why I believed it to be my coolant.
Last edited by Soriku1489; 06-10-2010 at 09:14 AM. Reason: Didn't explain the other part.
 Old 06-10-2010, 09:14 AM   #7
phillyb's Avatar
Groans: 1,940
oh yeah...you had to fill up some coolant?
watch that.
watch the coolant level. if it continues to go down and you have to continue to fill it up, could be something related to that.
 Old 07-02-2010, 10:19 AM   #8
Soriku1489's Avatar
Speaking of oil. Has anyone ever went from regular to synthetic. I'm trying to get some answer on the matter.
 Old 07-02-2010, 02:33 PM   #9
phillyb's Avatar
Groans: 1,940
i did about one oil change ago.
 Old 07-02-2010, 04:12 PM   #10
ckahler666's Avatar
Posts: 212   (View Stats)
ckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the world
I plan on running synthetic when I do my next oil change. On my previous cars I've found that the turbo motors like synthetic a little better because of the heat dissipation properties.
Eat glass nigga!!!!
ckahler666 is offline   Reply With Quote
 Old 07-02-2010, 07:05 PM   #11
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
does the exhaust smell sweet? then it is coolant
at 104000 2 bent rods
tuned by nishan
 Old 07-02-2010, 07:56 PM   #12
Soriku1489's Avatar
I've smelled the sweet smell with my old car but that was when my engine blew. I want to go synthetic but i'm worried about leaks. I'm not much of a car person so I'm trying to learn as I go and the last time I used Synthetic was on my 95 eclipse. It leaked oil like crazy but i wasn't sure if that happened before or after I did it. So long ago. My oil change is coming up so i'm going to do it.
 Old 07-02-2010, 08:22 PM   #13
almost all members on here are running synthetic oil. I think 95% are
 Old 07-02-2010, 08:44 PM   #14
Soriku1489's Avatar
ok. There's my answer then. Thanks everyone.
 Old 07-08-2010, 01:58 PM   #15
Soriku1489's Avatar
I think I found my problem. My coolant has not gone down much but my oil has gone down alot. I think I'm burning oil.
 Old 07-08-2010, 05:25 PM   #16
dizzin9's Avatar
Posts: 1,807   (View Stats)
Groans: 77
your k04 is dead
Excess White Smoke from Exhaust pstack1 2010 MS3 - Engine, Transmission & Driveline 48 07-25-2010 06:32 PM
white smoke on start up 2010 Seaton 2010 MS3 - Engine, Transmission & Driveline 1 04-02-2010 04:59 AM
White smoke? PLEASE HELP Fallenvoices MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 01-06-2010 03:39 PM
White Smoke from Exhaust (with Video) toprock MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 11-03-2009 10:14 AM
finally got the white smoke bombdotcom MazdaSpeed 3/6 - Turbo Induction 3 01-29-2009 04:53 PM
Page generated in 0.33399 seconds with 27 queries
