Go Back   Mazdaspeed Forums > MSF News And Event Info > Site News & Events > Computers & Technology News
 Old 04-20-2010, 02:53 PM   #1
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
Default A quick question about routers
Currently I am running a 100 ft. ethernet cable across the backyard from the main house to my back house. That cable is coming from the router inside the main house. As of now, I need to unplug the cable from the computer in order to play the PS3 online. I would like to be able to operate both the computer and PS3 without switching the cable manually.
So, can I run from one router to another router?
If so, will I still get a decent connection??
Here is a cheesy diagram of what I want to do so you can get a good idea.
this forum serves 2 purposes
 Old 04-20-2010, 03:14 PM   #2
wankular's Avatar
Posts: 4,343   (View Stats)
If you want to watch internet porn, just do it at the main house after everyone's asleep.
2009 MS3 sport MGM
The Following 2 Users Say Thank You to wankular For This Useful Post:
FreeFlyFreak (04-20-2010), nutsac76 (05-07-2010)
 Old 04-20-2010, 03:21 PM   #3
cosmicspd3's Avatar
Posts: 447   (View Stats)
cosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant future
Ok get a switch to replace the router in the backyard house OR log into it and turn off the router operations and make it a switch, like no dhcp, nat etc. Then it will work. You are having ip, routing and nat conflicts between the two.
2009 Cobalt SS
Originally Posted by northvibe
ABS is really for lazy americans
cosmicspd3 is offline   Reply With Quote
The Following User Says Thank You to cosmicspd3 For This Useful Post:
Dash08 (04-20-2010)
 Old 04-20-2010, 03:21 PM   #4
yearzero's Avatar
Posts: 439   (View Stats)
yearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the world
yeah you can use another router or switch liek you want. you could also go ad-hoc with the back house computer and use that internet connection. google is your friend.
yearzero is offline   Reply With Quote
 Old 04-20-2010, 03:32 PM   #5
I <3 your mom
Dash08's Avatar
Groans: 293
Sorry, I'm a noob to this. I don't have the second router yet, just the one ethernet cable from the main house. Basically, when i want to play PS3 online, I unplug the cable from the computer and plug it into the PS3. It works, but I'd prefer to not have to do it manually.
A switch sounds good. Something that directs the ethernet connection to either the computer or the PS3 by means of a switch. That would be cool.
Can you recommend anything??
Thanks for your help fellas.
 Old 04-20-2010, 05:54 PM   #6
Wardgillette's Avatar
Posts: 11   (View Stats)
Wardgillette will become famous soon enough
Yes, you can run one router from another. Plug the Ethernet into a wireless router in your place. Equip your computer and PS3 with wireless cards. You should be able to use them both...at once.
Wardgillette is offline   Reply With Quote
 Old 04-20-2010, 05:59 PM   #7
Shanems3's Avatar
Posts: 916   (View Stats)
Shanems3 is the leader of the worldShanems3 is the leader of the worldShanems3 is the leader of the worldShanems3 is the leader of the worldShanems3 is the leader of the worldShanems3 is the leader of the worldShanems3 is the leader of the worldShanems3 is the leader of the worldShanems3 is the leader of the worldShanems3 is the leader of the worldShanems3 is the leader of the world
IT right here.... get a Ethernet Switch.. Plug and play... a router u will have to change the Ip Address on it because it will most likely conflict with the other router.. cant have 2 192.168.1.xxx addreses on the same subnet trying to connect to each other..
Get a Ethernet switch an plug it in and go to town..
Shane
2011 Mustang GT Premium
Performance White
Sync | Shacker 500 | Rapid Spec 401A | Exterior Package 5 | California Special Valance | Boss 302 Splitter | Bama Tune | Bassani Axleback
Shanems3 is offline   Reply With Quote
The Following User Says Thank You to Shanems3 For This Useful Post:
Dash08 (04-20-2010)
 Old 04-20-2010, 10:31 PM   #8
I <3 your mom
Dash08's Avatar
Groans: 293
I got it all working. I picked up an ethernet hub and that did it. I can now run both the computer and PS3 simultaneously.
Thanks again for all your replies.
 Old 04-21-2010, 09:13 AM   #9
Shanems3's Avatar
np.. a hub is kinda like a switch, the only differance is a Hub, splits the connection in half if you use 2 ports, a 3rd for 3.. etc.. so u have a 100mbps connection, with 2 active ports, each will get 50mbps... with a switch, Every port gets 100mbps... u prolly wont notice a differance with 2 devices on it..
Shane
Performance White
Dash08 (04-21-2010)
 Old 04-21-2010, 11:18 AM   #10
I <3 your mom
Dash08's Avatar
Groans: 293
I haven't noticed a difference. Last night I played MW2 and was on the internet at the same time and nothing was slow.
 Old 04-21-2010, 11:44 AM   #11
m4tic's Avatar
Posts: 4,928   (View Stats)
this thread was kind of long just to tell dash to get a small switch...
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
Dash08 (04-23-2010)
 Old 04-21-2010, 12:20 PM   #12
cosmicspd3's Avatar
thats because anyone that has a computer is a IT person right?
2009 Cobalt SS
 Old 04-21-2010, 12:25 PM   #13
MS33SM's Avatar
Posts: 1,821   (View Stats)
MS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the world
Groans: 132
Groaned at 166 Times in 92 Posts
if your computer has 2 ethernet ports you can use the comp as a switch
MS33SM is offline   Reply With Quote
 Old 04-21-2010, 02:49 PM   #14
Evan9999's Avatar
Posts: 75   (View Stats)
Evan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud of
you can use 2 routers, just make sure you also setup their ip ranges...192.168.1.x for the first and 192.168.2.x for the second. That way you don't have any IP conflicts
Evan9999 is offline   Reply With Quote
 Old 04-21-2010, 04:00 PM   #15
m4tic's Avatar
yea.. properly configured linux box > linux firmware'd router > off the shelf router
2017 Daytona 392
2007 MS6 w/ Cheez
802MS3 (04-23-2010)
 Old 04-21-2010, 07:51 PM   #16
Shanems3's Avatar
haha yeah..... but i get paid for it.. and FUCK Mcafee....... they suck monkey balls.... they crippled millions on computers today...
Shane
Performance White
 Old 04-23-2010, 11:47 AM   #17
I <3 your mom
Dash08's Avatar
Groans: 293
Thanks for all the help boys. The hub is working beautifully. Although it is splitting the connection between the two components, there hasn't been any problems.
 Old 04-23-2010, 12:14 PM   #18
m4tic's Avatar
if you notice any issues or hiccups when using multiple devices that put a high bandwidth demand on the hub, you'll want to toss it for a switch...
2017 Daytona 392
2007 MS6 w/ Cheez
Dash08 (04-23-2010)
 Old 04-23-2010, 12:20 PM   #19
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
this is 2010. you should have got a switch instead of a hub. lol.
in reality though, if youre only using it for internet traffic, then it really doesn't matter.
'08 CWP MS3 w/ T3 3071r
 Old 04-23-2010, 12:39 PM   #20
cosmicspd3's Avatar
why on earth would you want to use a router behind a router? You'll be double NAT'ing...its beyond inefficient. All you need to do is turn off the routing protocols, like natting, dhcp etc. and turn it into a switch and it will work great.
2009 Cobalt SS
 Old 04-23-2010, 01:15 PM   #21
rabble rabble
802MS3's Avatar
Groans: 221
or just plug it into the internal switch (which 99% of home routers have...)
 Old 04-23-2010, 02:04 PM   #22
I <3 your mom
Dash08's Avatar
Groans: 293
I really don't think it'll be a problem. It's only for internet and online gaming. Plus, The hub was only $20 bucks. The switch was close to $40. That and two 3' ethernet cables from Radio Shit for $10 bucks each.
$40 to get it all working or $60 to use a switch instead of a hub. I took the cheaper route.
It doesn't seem to be straining the connection. Even when both components are running simultaneously, the lights on the hub don't blink, they stay constant. That usually means a good, solid connection.
Quick question feldm4n Mazdaspeed3/6 General Discussion 12 02-10-2010 10:12 PM
Quick AP question. Radspeed6
Cobb ATR Support
3 05-11-2009 09:29 AM
Quick question regarding AP Mazdasp33d
Cobb Access Port/Maps
3 03-02-2009 01:19 PM
Quick Question... Invictus Mazdaspeed3/6 General Discussion 10 11-26-2008 12:32 AM
Another quick cx7 question. SgtP Mazdaspeed3/6 General Discussion 16 07-08-2008 08:55 AM
Page generated in 0.39076 seconds with 30 queries
