Go Back   Mazdaspeed Forums > MSF News And Event Info > Site News & Events > Computers & Technology News
 Old 12-05-2010, 05:58 PM   #1
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
Default Time for new ram
So now its time to get some new ram. After my build i re-used the ram i had from my old computer which i upgraded not to long before it died. On my old computer I was running 32bit XP Pro so it ran fine. But on the new system im running 64 XP Pro so it never ran properly. Can someone suggest which ram i should buy? Probably be getting like 4GB, unless i find a good deal on something else.
Here are my stats
Prestigio Case
Ati Radeon HD 4770 512 MB GDDR5
Asus M3A76-CM
Antec 500W
AMD Phenom II X3 Processor Black edition 2.8 Ghz, 7.5 MB Cache
Original HD 223 Gb
Kingston 2 Gb
Windows XP Pro 64-Bit
Motherboard stats
240-pin DDR2 DIMM Banking: 4 (2 banks of 2)
Chipset: AMD 760G
DDR2 SDRAM Frequencies: PC2-4200, PC2-5300, PC2-6400 and PC2-8500
Error Detection Support: ECC and non-ECC
Graphics Support: PCI Express x16
Max Component Density: 1024
Max Unbuffered DDR2 SDRAM: 8192MB
Module Types Supported: Unbuffered only
Supported DRAM Types: DDR2 SDRAM only
USB Support: 2.x Compliant
 Old 12-05-2010, 07:28 PM   #2
dscsk8er55's Avatar
Posts: 50   (View Stats)
dscsk8er55 is a jewel in the roughdscsk8er55 is a jewel in the roughdscsk8er55 is a jewel in the roughdscsk8er55 is a jewel in the rough
Here are my stats
Prestigio Case
Asus M3A76-CM
Antec 500W
Original HD 223 Gb
Kingston 2 Gb
Motherboard stats
Chipset: AMD 760G
This looks good
Newegg.com - Kingston HyperX T1 Series 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model KHX8500D2T1K2/4G
Also, I would recomend to ditch xp 64bit if you can. About 1.5 years ago my company switched all of our software guys to it and it has been a PAIN IN OUR ASS!!! I hate that software and have so many problems that just seem like weird things.
dscsk8er55 is offline   Reply With Quote
 Old 12-05-2010, 07:39 PM   #3
ahskeetz's Avatar
Posts: 431   (View Stats)
ahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the world
Groaned at 7 Times in 5 Posts
If you're still sticking with XP because Vista blows whale vagina, then I suggest you give Windows 7 a try, it actually is a pretty solid OS.
2010 Black Mica MS3 |CP-E Nano.TIP.TMIC.RMM|1G DSM BPV|UR DP.TP|H&R springs|eBay camber arms|ITV-22|Ford XT-M5-QS|Sure Shortcut|PG shift weight|JBR Bushings|Maisonvi Chode Knob|MD OCC|Cobb AP tuned by me
2013 Kawasaki Ninja 300|15T sprocket|Yoshimura R77 full system| Area-P Tune
ahskeetz is offline   Reply With Quote
 Old 12-05-2010, 08:28 PM   #4
Ur moms boyfriend
Groans: 70
not much pc2 8500 ram to choose from. my build is less than a year old. i guess i should have dished out a few more coins on the MB. Along with ram i am planning on getting a portable HD so i can backup my drive to save all my data and then install windows7
 Old 12-06-2010, 07:34 AM   #5
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
WIN 7 x64
WIN XP x64 is not so good.
Beanfab / Tuned by Nishan
 Old 12-06-2010, 12:02 PM   #6
Ur moms boyfriend
Groans: 70
yea im debating whether i should go with 32 or 64 when i get Win7. i had a few problems with compatibility issues like with itunes, HP printer driver, and a few others. not sure how it is with Win7 because ive never play with it let alone install software. mostly likely ill be getting 4GB of ram(cause this MB blows) but i was just wondering, can you use more on the 32. i heard rumors that they patched vista so you were able to use more than 4GB.
 Old 12-06-2010, 12:11 PM   #7
tbot's Avatar
Posts: 2,821   (View Stats)
Groans: 40
32 bit systems don't have the capability to allocate more than 4GB of RAM. They just flat out won't recognize it. I would go x64 Win7 if I were you and enjoy the improvements.
Here's an article that better explains it:
Clearing up the 32/64-bit memory limit confusion | ZDNet
and the patch you're talking about i think is so the win7 x86 recognizes 4gigs of RAM instead of 3.
 Old 12-06-2010, 07:38 PM   #8
Ur moms boyfriend
Groans: 70
honestly i dont think ill be needing more than 4gb
 Old 12-06-2010, 08:26 PM   #9
ahskeetz's Avatar
Windows 7 x64 has pretty good compatiblity with x86 (32-bit) programs. I'm not sure how it's set up technically, but Windows 7 actually has separate program folders: one for x64, and one for x86. I haven't had any compatibility issues and I've been using 7 x64 for 15 months.
 Old 12-06-2010, 08:29 PM   #10
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
wow..i honestly thought this niggah was shopping for a new dodge truck
 Old 12-06-2010, 08:33 PM   #11
Ur moms boyfriend
Groans: 70
lol not any time soon
NEED HELP BIG TIME tapoutjessse MazdaSpeed 3 - Engine, Transmission & Driveline 41 12-09-2009 07:51 PM
Nap Time to Lap Time: 74-year-old James Hylton to race at Daytona Haltech Automotive News 0 11-27-2008 04:40 PM
Page generated in 0.30406 seconds with 25 queries
