![]() Join Date: Jul 2017
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score anyone have ideas, links where i can get the entire assembly (right rear) specifically for the MSP. Thanks, |
![]() Join Date: May 2013 Location: Santa Cruz, Ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 311
| Not Ranked : 0 score Springs sag, but don't blow out. It's probably your strut that's blown. How many miles are on the car? A set of Tokico Blue strutss are what your MSP came from the factory on. I'd replace the struts with those. Any coilover you find for a Protege these days is gonna be universal type crap that's not tuned to our cars, so your ride and handling will suffer. A 30 dollar Harbor Freight spring compressor is easy to use and will save you a few bucks, too. https://www.harborfreight.com/automo...set-63262.html
__________________ '93 RX-7: 100% CARB approved. Just some wheels and stuff. ![]() '03.5 Mazdaspeed Protege: Custom clunk and turkey call. '12 4Runner Limited: Hollister Hills pinstripes, dog hair, beach sand, melted surf wax, a few french fries under the seat... |
(Thread Starter) | Not Ranked : 0 score Thanks, I finally took out the strut today after a 3 hr tug of war, and having to dremel off the rusted sway bar link. this is NOT a fun job!. In the process, the ratcheting mechanism of the seat belt (removed the bolt on top holding the seatbelt to the frame) seems to have sucked in all of the seatbelt and now it wont unravel (yet another problem!!) . But anyways,. i just want to buy a cheap strut and bearing strut mount. What are my options? Not really interested in ride and handling cause its old and rusty so its a beater. the coil does look rusty and its no longer seated properly in the rubber holders at the top and bottom (they are pretty much torn or missing pieces). Is it worth replacing the spring as well. this way, i can just buy a strut and new spring and top mount and not have to remove the old spring. I am a bit nervous using the spring compressor so would prefer to just have to do this once on the new setup and just trow away the old strut and coil. thanks |
| Not Ranked : 0 score Springs: Suspension Spring Sets - Mazda Protege Performance Parts You'll need the bump stops too since you're in a Mazdaspeed Protege which is a little lower than a lesser model. Struts: https://www.streetunit.com/Tokico_Bl...ge_p/hb222.htm This, along with the racing beat swaybars are what the MSP came on from the dealership and will take you another 100k miles easily.
| Access Tuner Assistance Needed!! | kkostec | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 5 | 06-14-2018 06:56 PM |
| Initial Map setup (Assistance Needed) | mmanda2290 | MazdaSpeed 3/6 - ECU Computer Tuning | 8 | 02-10-2013 07:38 PM |
| MAF cal log assistance needed | bfak66 | MazdaSpeed 3/6 - ECU Computer Tuning | 8 | 10-17-2012 08:36 PM |
| Assistance needed! | MSpeed34 | Mazdaspeed3/6 General Discussion | 4 | 02-02-2012 11:01 PM |
