MAZDASPEED Protegé
> MSP - Wheels, Tires, Brakes & Suspension
  • 1 Post By Brian MP5T
 Old 09-06-2011, 03:57 PM   #1
Brian MP5T's Avatar
Posts: 1,101   (View Stats)
Default Mazdaspeed Protege
I recently upgraded the suspension on my Protege5 from Tein-SS to K-Sport.
TEIN SS $1400.00
TEIN PRO
-Survived 160,00 KM without Issue
-Almost no signs of Rust
-Easy to Setup
TEIN CON
-Steel Construction means HEAVY AS FUCK
I seriously did not know how heavy they were until I took the K-Sport out of the box
-Only Adjustable for Spring Height and Rebound.
-NO CAMBER PLATE (Deal Breaker) had to reuse OEM Pillow Mount and Bearing.
-Good Solid but comfortable ride.
K-SPORT Dampener $900 - $1000
K-SPORT PRO
-Lightweight Aluminum Construction
-Camber Plate on 4 Corners Included
-Threaded Shock design means universal replacement is easy
-Separate Shock/Spring height maintains full travel when running a lowered car
-Fantastic Ride
K-SPORT CON
-More deliberate setup as there are more variables possible.
Use a Micrometer or count threads to verify that the Left and Right sides are IDENTICAL before they are installed.
-Difficult to use the End links without modification in the Rear.
faeker likes this.
 Old 09-06-2011, 04:11 PM   #2
Brian MP5T's Avatar
Part numbers for Reference..
 Old 09-06-2011, 04:44 PM   #3
morgans22's Avatar
Posts: 264   (View Stats)
morgans22 has a reputation beyond reputemorgans22 has a reputation beyond reputemorgans22 has a reputation beyond reputemorgans22 has a reputation beyond reputemorgans22 has a reputation beyond reputemorgans22 has a reputation beyond reputemorgans22 has a reputation beyond reputemorgans22 has a reputation beyond reputemorgans22 has a reputation beyond reputemorgans22 has a reputation beyond reputemorgans22 has a reputation beyond repute
pics of the car ?
morgans22 is offline   Reply With Quote
 Old 09-06-2011, 04:47 PM   #4
Wolfgang5884's Avatar
Posts: 236   (View Stats)
Wolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond repute
Originally Posted by morgans22 View Post
pics of the car ?
I second that!
Wolfgang5884 is offline   Reply With Quote
 Old 09-06-2011, 06:46 PM   #5
Brian MP5T's Avatar
pics of the car ?
Originally Posted by Wolfgang5884 View Post
I second that!
The Following User Says Thank You to Brian MP5T For This Useful Post:
tragik (09-06-2011)
 Old 09-06-2011, 09:08 PM   #6
I like 'em! just not a fan of the decal on the side of your ride. Other than that, looks nice man!
Looks like you are starting a little Mazda dealership!
 Old 09-06-2011, 09:40 PM   #7
Brian MP5T's Avatar
The Decals are from the 2001 SPORT-20
They are OEM JDM with the rear lights, front and Rear Bumpers.
Normally I would agree with you however, this was all planned and deliberate to mimic the JDM body style.
 Old 09-10-2011, 02:58 PM   #8
diabolichippo's Avatar
Posts: 2   (View Stats)
diabolichippo is an unknown quantity at this point
Were you able to use the stock endlinks or did you have to go with an adjustable endlink? I'm installing mines in a few days and would hate to run into any problems.
Thanks!
diabolichippo is offline   Reply With Quote
 Old 09-12-2011, 08:13 AM   #9
Brian MP5T's Avatar
I had the aftermarket ones, so I didn't try the OEM ones..
Worst case scenario, you "Could" drive with the bars disconnected until the order of the end links came in, but I have to tell you, the car is very dangerous without the bars in a corner..
Can you post up here to let us know if it is compatible.
 Old 02-16-2012, 09:28 AM   #10
^^^ Thanks! They ended up working with the stock endlinks! I'll swap them out for the AWR ones when they crap out. So far the only complaint i have about the k-sports are the adjustable sway bar endlink bracket. Mines got loose one day.
 Old 02-18-2012, 08:16 PM   #11
Brian MP5T's Avatar
There is an lock screw that is supposed to prevent that
Can you post up the results
I am interested in your impressions
Mazdaspeed Protege Brian MP5T MSP - Wheels, Tires, Brakes & Suspension 2 08-09-2013 02:15 PM
WTB Mazdaspeed 03 Protege Side Skirts joe6801 Mazdaspeed3/6 General Discussion 3 04-12-2011 04:50 PM
Replacing a Turbo in a Mazdaspeed Protege 03 question Devonic MazdaSpeed 3/6 - Turbo Induction 1 06-29-2009 02:44 PM
Page generated in 0.31101 seconds with 23 queries
