![]() Join Date: Jan 2015 Location: Riverview, FL
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score I'm looking to upgrade my suspension on my mazdaspeed protege. I am looking for options and opinions. What's out there? Who runs what and how do you like it? Please post pics also.
__________________ DiLo Last edited by DiLoMSP; 02-04-2015 at 09:43 AM. |
| The Following 4 Users Say Thank You to Code Monkey For This Useful Post: |
![]() Join Date: Sep 2012 Location: London Ontario Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 338
| Not Ranked : 0 score Your going to go far....
__________________ 07 Speed 3 Handling: H&R Springs, Koni yellow shocks, JBR .250 Competition RSB, Whiteline poly control arm bushings, Custom 1/2" rod end RSB links, JBR 88D Trilogy, steel RMM bushings, Sparco Pro 2000 race seat (driver), Kirkey race seat (passenger), shift plate, 18X10.5 +15 RPF1, 275/35 18" Nitto NT01 Brakes: Wilwood 6 piston calipers, Cobalt Friction XR1 race pads Power: Custom 3.5" intake, Synapse Diverter valve, dual 3" Hood Exit, BNR S3, Treadstone 3126 core, 3 port EBCS, 3" custom cold pipe, 2.5" custom underroute hot pipe, Aquamist HSF4 |
(Thread Starter) | Not Ranked : 0 score Ok. I'm replacing bad struts not just upgrading. Figured i might as well upgrade while I'm doing it.
__________________ DiLo |
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP |
![]() Join Date: Feb 2014 Location: Delran, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 364
__________________ NJ NATOR |
| Banned ![]() Join Date: Jan 2015 Location: Space Mountain, Honey
Rep Power: 0 ![]() ![]() Thanks: 142
Groans: 30
Groaned at 132 Times in 57 Posts
| Not Ranked : 0 score What's an MSP? |
| The Following User Says Thank You to WetzMS3 For This Useful Post: | Raider (02-04-2015) |
Groans: 30
![]() Join Date: Aug 2013 Location: Beaumont
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28
| Not Ranked : 0 score Holy crap.....READ and use the google search bar. Sheesh.....
__________________ 06 MS6 GTX3076R, Xs power exhaust manifold(suxs), ebay dp(sux), 3" catless exhaust, 4" HTP TIP, Sure shortshift & counterbalance, COBB V3, Autotech HPFP internals, Grimmspeed EBCS, CP-e RMM, Perm PCV plate, JBR EGR delete, JBR BSD, JBR Oil pan baffle plate, Kozmic OCC, rebuilt fuel injectors, safeseal injector seals, Bosch 3 bar MAP, new gaskets(valve cover, throttle body, intake manifold, exhaust manifold, dp), cleaned valves and chambers, CP-E motor mount & rear-diff mount, ATP-INT-003 FMIC, Stratified Guardian Angel set to 24psi, Stoptech rotors, Hawk HPS pads, Forge BPV, home-made strut mounted tower bar, badgeless, special edition 19" anniversary rims. Battery finally relocated to trunk with custom box. New VVT stuff, BC coilovers, new OEM Clutch, fidenza lightweight flywheel, replaced driveshaft again, replaced power steering pump again, busted rear diff side bolts again....FML |
![]() Join Date: Nov 2010 Location: Phoenix, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,658
| Not Ranked : 0 score Holy crap....LOOK at the abundant amount of information available to the OP in this overflowing MSP Suspension section! MSP - Wheels, Tires, Brakes & Suspension - Mazdaspeed Forums
__________________ 2010 MS3 - Restockified (The former STX Battle Wagon) Progress RSB - Koni Sport - EBC Yellow - MD OCC - CS MonoCBE - Cobb SRI 2004 MSM TiGrey AEM SRI - Turbosmart MBC - FM TBI - eBay DP - Turbosmart BPV - Mishimoto FMIC - Denso 305cc Koni Sport - GC Coilover - Racing Beat 1.25" Front Sway Bar - SS Lines - 15x8 Flatout - 225/45 RS3 |
| The Following User Says Thank You to Crarrs For This Useful Post: | WetzMS3 (02-04-2015) |
| Not Ranked : 0 score Type in coilovers in the search bar.
| The Following User Says NO Thank You to Silverdecepticon For This Un-useful Post: | Crarrs (02-04-2015) |
| Not Ranked : 0 score I guess I forgot that MS3 suspension parts are easily adaptable to the Protege.
| The Following 2 Users Say Thank You to Crarrs For This Useful Post: | Dizzy Turbo (02-04-2015), Raider (02-04-2015) |
| Not Ranked : 0 score What a lot of shit above. OP, Tokiko Blues are what it came with. Koni yellows will suit nicely for a speed protege. |
| The Following 2 Users Say Thank You to Raider For This Useful Post: | DiLoMSP (02-09-2015), Nliiitend1 (02-04-2015) |
| What are my options? | shawn. | Mazdaspeed3/6 General Discussion | 17 | 04-04-2014 07:33 PM |
| Mazdaspeed 6 (Mazda 6 MPS) suspension options | robby85 | MazdaSpeed 3/6 - Suspension & Brakes | 13 | 12-18-2012 07:23 AM |
| k04 options | Boogie_69 | MazdaSpeed 3/6 - Turbo Induction | 39 | 04-08-2012 09:09 PM |
| BOV/BPV options | Derek88 | MazdaSpeed 3/6 - Turbo Induction | 12 | 04-18-2008 06:58 PM |
