 Old 01-07-2014, 06:40 AM   #1
Default BMW calls in 50,000 motorbikes over fuel pump leak
Filed under: Recalls, Safety, BMW, Motorcycle
If you don't often see motorbikes being recalled, it's probably because there's less to go wrong on a motorcycle. But a problem with the fuel pump on a wide array of BMW Motorrad products has prompted the National Highway Traffic Safety Administration to issue a recall for over 50,000 of the Bavarian two-wheelers across America.
The issue revolves around the fuel pump flange on R-model, K-model, S 1000 and HP2 motorcycles built as far back, in some cases, to 2005 and as recent as 2012, depending on the model. The flange was found to be prone to crack and leak fuel, which NHTSA evaluated as a fire risk. As a result, precisely 50,184 such motorbikes are being recalled to have their flanges reinforced or, where necessary, to replace the entire fuel pump. If you're the owner of such a Bimmer bike, expect a call from your dealer sometime next month, but you can read the full notice below.Continue reading BMW calls in 50,000 motorbikes over fuel pump leak
BMW calls in 50,000 motorbikes over fuel pump leak originally appeared on Autoblog on Tue, 07 Jan 2014 08:15:00 EST. Please see our terms for use of feeds.
More...
Possible leak under PS pump? DSIT995 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 18 01-25-2013 09:02 PM
Issues with fuel pump pressures, aftermarket pump... ptperformance MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 10-04-2009 06:17 PM
Maintenance on a 1973 I.H. Scout, Dangerous Car Has Exhaust Leak, Fuel Injector Cleaner, Ethanol and Fuel Grade, Is The Haltech Automotive News 0 07-10-2008 11:10 AM
Maintenance on a 1973 I.H. Scout, Dangerous Car Has Exhaust Leak, Fuel Injector Cleaner, Ethanol and Fuel Grade, Is The Haltech Automotive News 0 06-10-2008 02:12 AM
Page generated in 0.22451 seconds with 20 queries
