 Old 06-09-2010, 09:50 AM   #1
Default GM Recalls 1.5 Million Cars to Disable WindShield Washer Heaters.
General Motors - Autos - Automobile - Recreation - Hummer H2
More...
 Old 06-09-2010, 12:11 PM   #2
Heating the washer fluid makes a lot of sense. During especially cold days—as often seen in Detroit in January—even the alcohol-based washer fluid doesn’t cut through the grime. So GM offered a system that heated the fluid, and on the few cars we tried with the feature, the system worked brilliantly.
But, unfortunately, the system may also cause an engine fire. The first fix, in 2008, was to install a separate fuse in the system’s wiring—apparently that wasn’t enough. Now GM is recalling all 1.5 million vehicles with heated washer-fluid systems. Sadly, there is no fix this time around and the company that supplied the system is now out of business. The dealer will simply deactivate the system. To compensate owners, GM will hand over a $100 check, which means this episode will cost the general at least a staggering $150 million. Ouch.
__________________________________________________ ____________________
The government is writing the checks, might as well hand out more money! Thanks GM!
Windshield Washer Fluid List That Contains Methanol Haltech MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 15 06-20-2017 07:20 AM
GM recalls 1.5 million vehicles over heated windshield washer system Haltech Automotive News 0 06-08-2010 11:40 AM
Hot Cross Buns: Mazda recalls 2010 CX-9 due to seat (over)heaters Haltech Automotive News 0 03-03-2010 06:50 AM
Windshield washer bottle same in speed 3 and 6? Lex MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 4 01-29-2009 11:58 AM
GM drops HotShot windshield washer system after expensive recall Haltech Automotive News 0 10-08-2008 10:10 AM
Page generated in 0.24702 seconds with 21 queries
