| Car Detailing Wanna show off your hard work? Need help with swirl removal, scratches or general detailing questions? Come on in! |
![]() Join Date: Jul 2010
Rep Power: 0 ![]() ![]() ![]() Thanks: 1
__________________ Owner of Mirror Image Auto Detail |
| The Following User Says Thank You to Labster For This Useful Post: | SIC (12-22-2010) |
![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
| Not Ranked : 0 score
I tried some Mothers plastic polish with little results. Thanks.
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() | |
| KR....i haz it ![]() Join Date: Apr 2009 Location: Philadelphia, PA
Rep Power: 1381 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,652
Groans: 166
| Not Ranked : 0 score you need to sand them before polishing if the scratches dont come out
__________________ Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts | CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp ![]() |
| The Following User Says Thank You to Blackspeed For This Useful Post: | Alpha (07-27-2010) |
(Thread Starter) | Not Ranked : 0 score If they're lightly scratched you might have to do a bit of wetsanding. I would go with like 2500 or 3000 grit wet sand paper to level them off and then polish them out with Meguiars 105 or something similar. Should make your lenses crystal clear
| The Runner ![]() Join Date: Feb 2010 Location: Santa Ana, CA
Rep Power: 140 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 353
| Not Ranked : 0 score What is the nicest non carnauba wax that you have used or just know of from experience?
__________________ '09 Black Mica [MURDERED] MS3- HyperTech Tuned, CPE rear and side motor mounts, COBB TIP, JBarone Short Shifter Plate and Heavy Shift knob, SU Shifter Bushings, CPE Nano SRI, AWR End Links. WANTED- Radar Detector, Down Pipe, DashHawk, Forge BPV. |
![]() Join Date: Jun 2014
Groaned at 6 Times in 3 Posts
| Not Ranked : 0 score use toothpaste
__________________ https://www.youtube.com/watch?v=cST7atvUrrw 08 MPS3 GenOne |
| The Following 3 Users Say NO Thank You to Icemn For This Un-useful Post: |
![]() Join Date: Nov 2010 Location: Manchester, England
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,709
| Not Ranked : 0 score Sealant then wax, or wax then sealant? EDIT: Fuck you @Icemn; for making me post on a 4 year old thread.....ballbag!!!
__________________ Tuned with by ![]() K1 Rods//Wiseco Pistons//CX Racing FMIC//JBR Widepath Intake//Custom 3" TBE//Grimmspeed EBCS//Forge BPV//JBR SSP//JBR RSB//JBR Side Mounts//ISC-N! coilovers//JBR BSD and Baffle//Sure TIG Set//Sure R3 RMM//KMD Internals//XS Power Exhaust Manifold//P&P Intake Manifold//Fidanza Flywheel//EM Organic Compound Clutch//GTX3071//DVC30 Meth Kit//3 Gauge Pod.....415WHP....so far!! |
__________________ https://www.youtube.com/watch?v=cST7atvUrrw 08 MPS3 GenOne | |
| The Following 2 Users Say NO Thank You to Icemn For This Un-useful Post: | gigliotti175 (06-23-2014), skiptowncat (06-23-2014) |
![]() Join Date: Sep 2012 Location: Columbus, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 939
Groaned at 25 Times in 15 Posts
| The Following User Says Thank You to gigliotti175 For This Useful Post: | predapio (07-05-2014) |
| Not Ranked : 0 score Thank you "mc grammer"
__________________ https://www.youtube.com/watch?v=cST7atvUrrw 08 MPS3 GenOne Last edited by Icemn; 06-23-2014 at 12:03 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to Icemn For This Useful Post: | calizoomzoom (07-05-2014) |
| The Following User Says NO Thank You to Icemn For This Un-useful Post: | skiptowncat (06-23-2014) |
![]() Join Date: Jan 2011 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 311
| Not Ranked : 0 score Used my highspeed orbital to lay a coat of wax on this weekend, car doesn't need a cut as of right meow. And of course I wake up to find that it rained lastnight
__________________ 08 MazdaSpeed3 | Cobb AP | MS Intake | CS TIP | CP-E FMIC | CNT Catless TBE | ITV22 | | AutoTech Internals | TurboSmart BOV | BC Racing Coilovers | CS RMM | CS TMM | | Black Powdercoated Stockers | Built Motor | | Mahle 88mm Pistons | Manley H-Beam Rods | |
![]() Join Date: Jun 2014 Location: Santa Clara, CA
Rep Power: 0 ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score What would the best method of removing the swirls out of the paint |
| Not Ranked : 0 score I'm assuming @Labster; is no longer here. That sucks, because I was going to ask some questions as well until I realized this thread is 4 years old. Lol.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() |
Hi, i used mcquires ultimate compound Wash ur car Clay ur car Ultimate compound Polish Wax Done! Not Sent from my iPhone and Definitely Not using Tapatalk
| The Following 2 Users Say Thank You to Icemn For This Useful Post: | MBalik (02-26-2015), _speeddemon_ (07-05-2014) |
![]() Join Date: Feb 2011 Location: Waterford,CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,169
Groans: 423
| Not Ranked : 0 score Maybe @SpecialK; can keep this thread going?
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts |
![]() ![]() Join Date: Jul 2008 Location: Old Bridge NJ
Rep Power: 22834 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,276
Groans: 309
| Not Ranked : 0 score Or maybe you guys can let Lazarus and this 4yr old thread, just die in peace.
__________________ Dash08: I don't see the whole pedophile thing, But Predapio is a dirty old bastard. So, I wouldn't rule it out entirely. That's also why he fits in here. We're all a bunch of filthy, perverted, arrogant, pessimistic, self-righteous assholes who find entertainment at other peoples expense. What a lovable bunch we are!! |
| The Following 3 Users Say Thank You to predapio For This Useful Post: |
![]() Join Date: Feb 2012 Location: San Bernardino, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,954
| Not Ranked : 0 score I could have sworn there was one that was more current...
__________________ 2010 velocity red mica ms3 AP/AT internals JBR 3.5" whale peen (non rubber for more feeling) JBR SSP/bushings JBR RMM JBR tigs/ egr delete/ coolant bypass JBR stage 2 OCC CS test pipe Turbosmart BPV (stocker currently on) SS lines/super blue/stoptech pads |
![]() | | #19 | ![]() |
![]() Join Date: Nov 2013 Location: Odenton, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 169
__________________ 2006 Mazdaspeed 6 Zoom Zoom Boom Feb/2014 - fixed 3/30/2014 Motor: 2012 Block / V2 AP / Autotech HPFP / HTP 3" intake / AEM dryflow filter / Fidanza Flywheel / NGK 6510 Step Colder Plugs / TurboSmart BPV / Catless M2 DP / JBR SSP / CPE RMM Suspension: Poly SwayBar Bushings / CP-e Rear Diff Mount / BC Coilovers / 245/40/18 on 18x8" RX8 Wheels Visual: 25% Tint On All Windows / 25% Tint Side Markers / Front Grill Plasti-Dipped Black / Stockers Plasti-Dipped Black / Black Mad M on Trunk / De-Badged / Heavy Shift Knob Fluids: Motocraft gold in gearbox / Redline in TC and diff / Oil - Rotella T6 / | |
| The Following User Says Thank You to SpecialK For This Useful Post: | smoogs12 (07-05-2014) |
![]() | | #20 | ![]() |
Groans: 309
Start another one, have @Raider; make it a sticky and have at it.
__________________ Dash08: I don't see the whole pedophile thing, But Predapio is a dirty old bastard. So, I wouldn't rule it out entirely. That's also why he fits in here. We're all a bunch of filthy, perverted, arrogant, pessimistic, self-righteous assholes who find entertainment at other peoples expense. What a lovable bunch we are!! | |
![]() | | #21 | ![]() |
![]() Join Date: Nov 2010 Location: Reading, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,158
Groans: 731
__________________ Mods: stock Eventually I'll pay for how I am....but it won't be by the hand of any of you faggot fucks here. |
| The Following User Says Thank You to faeker For This Useful Post: | sidekick (07-05-2014) |
![]() | | #22 | ![]() |
![]() | | #23 | ![]() |
Groans: 731
| Not Ranked : 0 score You don't read so well do you.
![]() | | #24 | ![]() |
![]() | | #25 | ![]() |
![]() Join Date: Jan 2015 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28
Groaned at 26 Times in 14 Posts
| Not Ranked : 0 score I bought a mazdaspeed 3 a few months back when my mz3 was totalled while sitting at a red light =/. Ive gotten most of the interior/exterior like new, but the engine bay is disgusting. It looks like water spots on the head valvecover and intake manifold, although I know its oxidation. Whats the best way to get it all looking like it just rolled off the assembly line? The rest of the engine bay is pretty rough too. Im also interested what works best for wash and wax for the paint (true red), shine for the plastic (like.rear.bumper section, tmic and fuse/battery cover), and cleaning products for the wheels, tires and calipers. I appreciate all the info you can spare! Im also going to either plastidip or powder coat the oem wheels, so any advice on cleaning those types of.finishes as well. I really appreciate this thread man! Thanks a million |
| Ask the Detailer | Labster | Exterior | 142 | 04-25-2018 11:19 PM |
| Quik Detailer vs. Ultimate version | HLR Element | Car Detailing | 3 | 07-15-2010 09:48 PM |
| Any good car detailer in Socal | Chinsel | Car Detailing | 10 | 03-26-2010 11:14 PM |
| need reco's for a good car wash, wax, and quick detailer | 94jedi | Car Detailing | 6 | 05-18-2009 11:16 AM |
