> Car Detailing
Like Tree3Likes
  • 2 Post By Orangatang
  • 1 Post By makjur
 Old 06-08-2015, 05:46 PM   #1
pastry00's Avatar
Posts: 154   (View Stats)
pastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud of
Groaned at 5 Times in 1 Post
Default Chip in Paint
Has anyone tried to fix any small rock ships in the paint? What is the best method and where did u purchase paint? I have the crystal white pearl tricoat paint on my speed.
pastry00 is offline   Reply With Quote
 Old 06-08-2015, 05:57 PM   #2
xtasy's Avatar
Posts: 685   (View Stats)
xtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the world
Groaned at 6 Times in 4 Posts
Get the paint from Mazda. Touch it up until the whole chip is filled and the paint protrude out a little bit more than the surface.
Use 2000 grit and sand it flat. Then use compound/polish to restore the shine. White car is harder, so good luck.
Mazdaspeed3 E85 ~ Sold 333/383
Mazdaspeed6 #10018 TiGrey
Forged Internals, PTE5858.
2015' Freektuned on 93Octane 322/337 (stock top mount and BPV)
2016' Freektuned on e85/93 480/444 (maxed out 3bar map sensor)
2017' Freektuned on e85/93 525/497 (maxed out pte5858 @ 35/36psi & fueling)
Mazda CX-5 AWD Daily
xtasy is offline   Reply With Quote
 Old 06-08-2015, 06:07 PM   #3
Orangatang's Avatar
Posts: 466   (View Stats)
Orangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the world
I used Dr. ColorChip and my friends though I had my hood repainted. They use a different method from most to apply the paint. At certain angles, light, and really close up I can tell where I have filled in the paint but not much. The kit is sold on autogeek but the paint comes from the dealer so you need to know your paint code which can be found on the inside of the driver door, where the vin on that sticker is if you did not know that.
pastry00 and MortalMechanica like this.
Corksport stage 2 sri/tip, Autotech Internals, RSB,
CBE, Forge bpv, Koni FSD, Mazda Sport Springs,
ITV22, JBR PMM, JBR TMM, JBR RMM, Damond SSP
JBR SSB, CX piping with TR6, DM OCC
Dizzy Tuned
" I just don't need a stage 6, 16 puck, teflon diamond plated clutch that can snap a femur downshifting." -Raider
Orangatang is offline   Reply With Quote
 Old 06-10-2015, 10:35 PM   #4
Orangatang's Avatar
@Xtasty; way can be better over all, to over fill it then level out the paint. It would take to much of my time do do it that way, but I can see a more level look as if the chip was never there. Not just trying to hide or disguise it. But if you sand over it to much I can see someone destroying there paint, If they sand to far.
Dizzy Tuned
 Old 07-21-2015, 06:45 PM   #5
makjur's Avatar
Posts: 1,313   (View Stats)
makjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the world
Groaned at 15 Times in 8 Posts
+1 for Dr. Colorchip
I used it on my CBM with great results... just be patient and follow the instructions properly. I needed to apply it a few times before I considered the chips good enough
Orangatang likes this.
2010 blue with tech, cobb sri+tip+dp+cbe, ets tmic, grimmspd ebcs, autotek hpfp, jbr boosttoobs+rmm+roundknob+bushings, turbosmart bpv, swift springs, APv3 FreekTuned
retrofitted headlights: morimoto 5k HIDs with XB35 ballasts, in mini D2S projectors. VLED triton 5k switchback DRL/turn signals
°(ಠೆಒಠಿ)°
makjur is offline   Reply With Quote
Paint used to Paint Chrome Pieces HawkeyeGeoff Gen2 MS3 General Discussion 6 01-14-2013 05:03 PM
chip techyman MazdaSpeed 3/6 - ECU Computer Tuning 24 01-19-2012 11:02 AM
Front Grill paint/rear bumper paint src1988 Exterior 3 10-10-2011 08:04 PM
For the Uni-Chip haters, pbuol@msn.com MazdaSpeed 6 - Engine, Transmission & Driveline 17 09-09-2011 12:56 PM
Paint Chip on Hood From a Rock BoostIsBetter MazdaSpeed 3/6 - Appearance 13 03-19-2009 01:14 PM
Page generated in 0.25820 seconds with 23 queries
