| Car Detailing Wanna show off your hard work? Need help with swirl removal, scratches or general detailing questions? Come on in! |
![]() Join Date: Dec 2011 Location: Warwick, RI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,517
Groaned at 15 Times in 8 Posts
(Thread Starter) | Not Ranked : 0 score Just wondering if anyone else has tried any of the nanoskin stuff or any other "clay bar replacement" product. I'll be detailing a black hyundai sonata this weekend and will post my thoughts on the sponge afterwards. Nanoskin Autoscrub Speedy Prep Sponge
__________________ 2010 blue with tech, cobb sri+tip+dp+cbe, ets tmic, grimmspd ebcs, autotek hpfp, jbr boosttoobs+rmm+roundknob+bushings, turbosmart bpv, swift springs, APv3 FreekTuned retrofitted headlights: morimoto 5k HIDs with XB35 ballasts, in mini D2S projectors. VLED triton 5k switchback DRL/turn signals ♡°☆(ಠೆಒಠಿ)☆°♡ |
![]() Join Date: Oct 2013 Location: Raleigh, Charlotte NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 812
| Not Ranked : 0 score @Omega; has one. We used a combination of the mitt and regular clay bar when we detailed my car. The mitt is quite nice as you can cover much larger areas.
__________________ 2013 Liquid Silver Metallic MS3 GTX2867 ; Cobb AP v3 ; Cobb Turboback Exhaust ; Cobb EBCS ; Swift Springs ; Koni Yellows ; SPC Camber Arms ; Aquamist HFS-4 WMI ; Relentless Customs PNP IM ; ETS TMIC ; HTP Full 3.5" Intake ; HTP Battery Tray ; CS BPV ; CS Mid-Chassis Brace ; CS TMM Insert ; AT Internals ; JBR 88 Duro RMM ; DM PMM ; JBR OCC ; JBR IM & TB TIGs ; JBR EGR Blockoff Plate ; JBR 0.125 RSB & Tru-Torsion RSB Billet Brackets ; NGK Step Colder Plugs ; Bosch 3 Bar Map ; Block8head Dual Gauge Vent Pod ; Dual Aeroforce Interceptors ; Stoptech SS Brake Lines & Centric Blanks ; EBC Yellowstuff ; MOOG Endlinks TunedbyNishan Last edited by mize13; 07-21-2015 at 07:09 PM. |
![]() Join Date: Mar 2014 Location: Durham, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score It does an excellent job and seriously I would never use a regular clay bar anymore. There are a few downsides, it WILL marr soft paint so you need to follow up with paint correction on large areas (even the fine grade which is what I have) and you must keep the surface of the mitt clean if the car is really heavily contaminated. It's not really bad and can honestly be taken out with small amounts of compound by hand so it's easily correctable. This will save your hands hours of pain, I've used it about 5 times over the last 3 years and it's still holding up strong. TLDR - I love my mitt, I will never clay bar a car again -- enough said.
__________________ 2006 Super Clean BCM MS6 Corksport Intake/TIP - Test Pipe - CS FMIC - Freektune - Autotech HPFP - 18x8 Wheels with Nitto NT05's 235/40/18 - H&R Coilovers - SPC Balljoints - CS RMM - Magnaflow CBE - DM Power Steering Cooler - CAR LED Tails - EBC Yellowstuff w/ Centric Blanks - Xcarlink w/ Bluetooth Module Waiting to be installed: Diff Braces - TMM Insert |
Detail spray with mitt or soap water? From what they advertise the mitt as, they make it seem like its supposed to combine washing and claying into one step. on cars i do for extra $, I typically use an all in one polish/sealant that i apply with a foam polishing pad on my DA. Dealing with marred paint aunt scare me
__________________ 2010 blue with tech, cobb sri+tip+dp+cbe, ets tmic, grimmspd ebcs, autotek hpfp, jbr boosttoobs+rmm+roundknob+bushings, turbosmart bpv, swift springs, APv3 FreekTuned retrofitted headlights: morimoto 5k HIDs with XB35 ballasts, in mini D2S projectors. VLED triton 5k switchback DRL/turn signals ♡°☆(ಠೆಒಠಿ)☆°♡ | |
![]() Join Date: Apr 2013 Location: Chattanooga, TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,760
Groans: 42
| Not Ranked : 0 score I have the 6" nanoskin pad for use on an orbital buffer. As someone else has already mentioned, it can mar the paint even when lubricated. I use it for large sections like the hood, roof and doors, then a normal clay bar for any intricate area before buffing and polishing. If I'm just looking to clay before a wax job, I'll typically just clay it by hand.
__________________ Coming at ya with all 297/359 POWER: HTP 3" intake, Corksport BPV, Treadstone FMIC, Cobb EBCS, Autotech HPFP, CPE full catless DP ECU: self-tuned HANDLING: JBR RSB (Middle Setting) RICE: Stickers and stuff, mudflaps, floormats, Evil M, etc. RADAR: Passport Escort 9500ci |
I have used soapy water with it, I would ONLY do this for minor contamination as if contamination is heavy it won't provide the right lubrication. Also the car should be washed first any removable dirt/grime/contaminants really need to be removed before this step. Ideally you should probably use detail spray, soapy water doesn't really provide much lubrication in comparison. Marred paint is not bad you have to understand what it really entails, it's basically transferring some of the sticky goo to the surface sometimes but can certainly also introduce swirls if not careful, it doesn't typically do anything major and is pretty safe. Remember always wash/clay one direction, never circular and you should be fine, just pay attention and rinse the mitt often (to free debris). I honestly would never use this on a polisher as I feel it would be too harsh and can introduce swirls if something catches on the pad.
__________________ 2006 Super Clean BCM MS6 Corksport Intake/TIP - Test Pipe - CS FMIC - Freektune - Autotech HPFP - 18x8 Wheels with Nitto NT05's 235/40/18 - H&R Coilovers - SPC Balljoints - CS RMM - Magnaflow CBE - DM Power Steering Cooler - CAR LED Tails - EBC Yellowstuff w/ Centric Blanks - Xcarlink w/ Bluetooth Module Waiting to be installed: Diff Braces - TMM Insert | |
(Thread Starter) | Not Ranked : 0 score I got a chance to use the nanoskin sponge a few days ago and I have to say i like it. Cleans way faster then clay. I plan on buying the mitt next. The only gripe I have is that I can't see the crap that I get off the paint even when i wipe the nanonskin on a light colored towel.
| Inake Mani Foam/Sponge Insert | mazdaspeeding | MazdaSpeed 3/6 - Turbo Induction | 1 | 01-06-2015 08:58 PM |
| Report: Ex-Fisker chair blames Mitt Romney attacks for DOE loan hold-up | Haltech | Automotive News | 0 | 04-20-2012 05:00 PM |
| Report: This is Mitt Romney | Haltech | Automotive News | 0 | 03-25-2012 05:20 PM |
| Mitt Romney wins GOP primary in home state of Michigan | Haltech | Automotive News | 0 | 02-28-2012 09:30 PM |
| Quoth Mitt Romney in the NYT: "Let Detroit Go Bankrupt" | Haltech | Automotive News | 0 | 11-19-2008 05:50 PM |
