| Car Detailing Wanna show off your hard work? Need help with swirl removal, scratches or general detailing questions? Come on in! |
(Thread Starter) | Not Ranked : 0 score I've found a spray that I am very happy with: https://www.facebook.com/media/set/?...8435977&type=1 As a bonus, taking off any bolts is a pleasure! Do you guys undercoat?
| The Following 24 Users Say Thank You to Lex For This Useful Post: | 802MS3 (11-23-2013), Agent_Orange (11-19-2013), Arnie1229 (03-19-2015), Benis (11-20-2013), bioevolve (11-19-2013), Boosted Beluga (11-28-2013), cnote308 (11-22-2013), CosmicArkie (11-22-2013), CWP_MS3 (11-22-2013), Domino81 (12-12-2013), Fail_6 (11-28-2013), Hammology (03-20-2014), jharris243 (11-22-2013), JMEngineer (11-28-2013), jomatthe (11-07-2015), jseams (11-19-2013), MATT DAMOND (09-23-2014), nybe0010 (11-28-2013), obijack (03-10-2014), SLOWHATCH (01-22-2014), snailD (01-22-2014), Tacheny (11-25-2013), trancehead (11-22-2013), YABBAMZR (11-23-2013) |
![]() Join Date: Aug 2011 Location: Poughkeepsie, NY.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,050
Groans: 235
| Neutral : +1 score I've been researching what to spray my 6 with, thank you sir
__________________ ![]() /91 miata with basic suspension bits /Turbo ep3 BWAAAAA PSH /speed 3- bye /possessed speed 6- dead ((((((/lol nator. |
(Thread Starter) | Not Ranked : 0 score I've tried several and got this online based on its effectiveness. I was impressed in that it did not drip like the other ones I have tried. It is also used for off shore oil rigs and an industrial product so I think it will be quite effective.
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
| Not Ranked : 0 score On a new vehicle I would coat it with Monstaliner's Chassis Saver. I've been extremely happy with their prodicts.
__________________ |
![]() Join Date: Sep 2011 Location: Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 213
| Not Ranked : 0 score I got the permanent rubberized undercoating on my car when I bought it new. For touch ups or new parts or whatever though I use fluid film. Costs about $10 a can, lasts quite a while, doesn't drip or make too big of a mess and can be sprayed literally anywhere without worrying (safe on rubber, paint, etc).
__________________ - 2010 Mazdaspeed 3 Black Mica - - Cobb AP - Self Tuned - cpe HPFP - cpe DP - CS 3" SRI - cpe TMIC - Forge BPV v2 - Grimmspeed EBCS - Denso ITV22 - - SouthBend Stage 3 Daily Clutch - cpe RMM - CS TMM Insert - TWM SB - CS SSP & SW - CS RSB & Mid Chassis Brace - - CS Brake Pads - Michelin Pilot Super Sport - CS Boost Tubes - CS Fog, DRL and Interior LEDs - Horns - Grounds - 20% Tint - |
| Not Ranked : 0 score This is what I do for rust prevention. So far it has worked really well.
| The Following User Says Thank You to dale_gribble For This Useful Post: | 2012FailWheelDrive (11-19-2013) |
![]() Join Date: Sep 2012 Location: Elizabeth, NJ
Rep Power: 3180 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,265
Groans: 665
| Not Ranked : 0 score I'm a big proponent on corrosion inhibitors. I used to be an off-road junkie, where rust/corrosion is a huge problem, especially in areas where the water can become trapped and sit for long periods. The two products I always had recommended to me were LPS 3 and Boeshield T-9. I've had great success with both of them, however I believe some of the cheaper products will work just as well. |
![]() Join Date: Sep 2011 Location: Newington, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
| Not Ranked : 0 score I need to do some rust repair this spring. I may try this stuff out when I get rid of it all.
__________________ Mods: JBR 3" WP, Cobb AP, JBR SSP, JBR 88d RMM, JBR Rear Sway, JBR Camber Arms, Autotech's, UR DP/TP, CS OCC, DO STG1 soon... |
![]() Join Date: Aug 2013 Location: Santa Fe, New Mexico
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 274
| Not Ranked : 0 score Thanks for this useful recommendation, I have been looking for a decent rust prevention spray for my car's underside since in New Mexico, they tend to salt the road a lot!
__________________ 2008.5 Mazdaspeed3 GT MODS: ETS TMIC - Forge BPV - JBR Tru 3in Intake - JBR Boost/Bypass Hoses - Koni Yellows - Corksport CBE/Corksport Racepipe - Front Corksport FSB (Thanks Previous Owner) - JBR RSB - JBR STS/Heavy Weight Knob - Corksport Aluminum Skid Plate - JBR 88a RMM - Corksport LED Light Kit - Goodridge Braided SS Brake Lines - COBB AP - Corksport HPFP Running on Freektune OTS+ Map Possibly the first deaf MS3 owner here? hmmm... ![]() |
![]() Join Date: Nov 2010 Location: South Haven, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,824
Groans: 75
| Not Ranked : 0 score We use LPS all the time at my work. its good shit and works really well.
__________________ Franken Turbo, built motor, meth. DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more. "Your signature should just say, I'm the shit." -LynzeC |
| The Following User Says Thank You to maisonvi For This Useful Post: | Nliiitend1 (11-23-2013) |
![]() ![]() ![]() Join Date: Nov 2012 Location: Temecula, CA
Rep Power: 2724 ![]() Thanks: 3,896
| Awesome find lex, should be a nice touch for anyone on the east coast of that has to deal with any possible rust issues.
__________________ 2018.... Doing even more freeky things! 10.36@148 Fastest Gen 2 |
![]() Join Date: Mar 2011 Location: State College, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 78
| Not Ranked : 0 score Man, I really wish I would have thought of this when my car was new. I have a 2009, so I'm on my 5th winter in central PA. Do you think it's worth starting this now, or has the damage been done? I suppose it can't hurt to start now; the cars underside isn't horribly rusty or anything. Thanks for the info @Lex; |
![]() Join Date: Jun 2013 Location: London, ON
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 71
Groaned at 6 Times in 2 Posts
| Not Ranked : 0 score My lower control arms are quite rusty as is the rear sway bar area. Where do you get this in Canada? Canadian tire doesn't have this brand but they have some other rust inhibitors.
__________________ JBR SRI+TIP, Autotech internals, Stratified stage 2 flash tune, Corksport BPV, UR test pipe, Damond Motorsports RMM |
![]() Join Date: Jun 2013 Location: Meriden, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 298
| Not Ranked : 0 score Perfect timing, I just ordered 2 cans from Amazon to try out, prepping for the first winter with the Pu. Better than nothing considering the nasty chemical shit they are using on the roads here now...apparently CT is too cheap to pay the extra 40 cents a gallon for the 'corrosion inhibitor' additive other states use in their mix.
__________________ 2012 CWP MS3: Corksport SRI/TIP | MD RMM, OCC | AT Internals | Cobb AP v3 | JBR 70d side mounts, SSP, shifter bushings | CP-E FMIC | CNT catted DP | UR Resonated CBE | Tints 20% and 5% |
![]() Join Date: Jun 2012 Location: Vancouver, BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 155
| Not Ranked : 0 score I have a 2009 and there is some surface rust on the edges underneath my car, is it too late to do this now?
__________________ 2009 CWP MS3 | JBR short shift plate, JBR shifter bushings, CP-e stage 2 RMM, JBR RSB, JBR Wide-Path, CS downpipe, UR catted test pipe, Cobb cat-back, Forge BPV V1, Swift Spec R springs, Bilstein B8, Whiteline KCA428 ALK, Whiteline Bumpsteer Correction, Corksport injector seals, Weds Sports SA55M 18x8 +48, Bridgestone S-04 245/40/18, BLOX Limited 490g shiftknob Dyno'ed at 277whp/290lb-ft on 91 piss |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 56
| Not Ranked : 0 score My google ninja skills tell me that Acklunds carries it in Canada. I might go check next week sometime. |
(Thread Starter) | Not Ranked : 0 score It's never too late to start. However don't use it on areas that you plan on painting if you plan on doing any sort of rust repair. I used the Canadian Tire brands before and this is quite a bit better. One of the big advantages is that it doesn't drip off the chassis making a mess. I bought it from Amazon.
![]() Join Date: Aug 2013 Location: Baltimore, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
| Not Ranked : 0 score This stuff was recommend to me by people in the aviation industry when I was looking for something to protect my motorcycle. I covered my entire motorcycle with it, fairings, wiring and all. Rode through salty Maryland roads all winter. Nothing sticks to this stuff. I would rinse off the bike afterwards and it looked brand new. 2 full years of riding and it worked great. I'm gonna try it on my speed this year. |
| The Following User Says Thank You to bladerunner10121 For This Useful Post: | Agent_Orange (11-23-2013) |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score Is that in a spray can?
![]() | | #20 | ![]() |
![]() Join Date: Apr 2012 Location: Rhode Island
Rep Power: 133 ![]() Thanks: 154
| Not Ranked : 0 score thanks for this! I've been researching some undercoat choices and this looks like a great choice. How many cans did you use for 1 application?
__________________ -ETS tmic -Autotech HPFP internals -SURE sri -SURE tip -Forge V1 bpv -Ultimate Racing downpipe -Corksport racepipe -Ultimate Racing cat-back exhaust -Corksport exhaust hangars -Corksport short shift plate -Corksport race RMM -Corksport OCC -Denso ITV22 spark plugs -10mm spacers-Continental DW 235/40-Eibach Pro-kit springs -Akebono Euro ceramic brake pads -OEM mazda window visors -Rally Armor mud flaps -20% tint TUNED BY: ![]() |
![]() | | #21 | ![]() |
(Thread Starter) | Not Ranked : 0 score I used 2 cans. If you get overspray on the exhaust it will smell a bit the first couple of drives - not a problem at all though.
| The Following User Says Thank You to Lex For This Useful Post: | joseph.p05 (11-23-2013) |
![]() | | #22 | ![]() |
| Not Ranked : 0 score You can get them in Spray cans. They also sell them in 4liter and up canisters. I got a 32oz bottle that came with a hand pump spray bottle that worked very well. You can use the big hand pump, garden type sprayers for larger applications. Which is what I plan on using to coat the car. I Plan to coat the entire underbody and engine bay. Here is the link to where I got it from. ACF-50 ANTI-CORROSION BLOCK COMPOUND from Aircraft Spruce |
| The Following User Says Thank You to bladerunner10121 For This Useful Post: | nybe0010 (11-28-2013) |
![]() | | #23 | ![]() |
![]() Join Date: Nov 2010 Location: Lido Beach,NY
Rep Power: 8624 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,845
Groans: 95
| Not Ranked : 0 score I believe some of the Cannukas run something similar to this>RustStop® RS-5 « RustStop®
__________________ Nator is what it does. |
![]() | | #24 | ![]() |
| Not Ranked : 0 score This appears to be the same stuff from amazon but different type of can LPS 3® PREMIER RUST INHIBITOR from Aircraft Spruce Canada |
| The Following User Says Thank You to CaptainCode For This Useful Post: | jomatthe (11-07-2015) |
![]() | | #25 | ![]() |
![]() Join Date: Jun 2008 Location: Moncton, NB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 93
| Not Ranked : 0 score Ill will be doing this when i get my new speed. i will do a bit of research, but what should i not spray? im guessing i need to put two coats on my rotors
__________________ : )-~ CS 3inch intake, CS FP internals, CS Test pipe, Forge V2, AP v3, JBR 88a RMM and mud flops Last edited by Gr33ntumb; 11-27-2013 at 05:54 AM. |
| The Following User Says Thank You to Gr33ntumb For This Useful Post: | SLOWHATCH (01-22-2014) |
![]() | | #26 | ![]() |
![]() Join Date: Mar 2013 Location: Akron, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
| Not Ranked : 0 score looks like some good products to try
__________________ *2013 Mazdaspeed3 Black Mica* Autotech internals, JBR 3.5" intake, Cobb catted DP, AP v3, JBR ssp/shifter bushings |
![]() | | #27 | ![]() |
![]() Join Date: Apr 2009 Location: Cincinnati
Rep Power: 2046 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,096
| Not Ranked : 0 score The speed 3 I just bought has a little rust on the bottom so I've been researching this kind of stuff online. My plan was to clean as much off as I can, then paint with something like the Eastwood rust encapsulator paint followed by a rubberized undercoating and top it all off with something like the LPS 3
__________________ 2006 MS6 GT - Built engine, twin scroll GT3076R, dual MV-S wastegates dumped to atmosphere, TR1035 FMIC, too many parts to list... ![]() 2009 MS3 GT - Built engine, JBR intake/TIP and short shifter, all engine mounts, Autotech HPFP internals, ETS TMIC, Custom AP tune, Pauter rods, CP pistons, and 6-puck ACT clutch -GTX2867R Coming Soon |
![]() | | #28 | ![]() |
| Not Ranked : 0 score Sounds like a bit of work, but certainly would be worth it
![]() | | #29 | ![]() |
![]() | | #30 | ![]() |
![]() Join Date: Nov 2012 Location: North East
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 261
Groaned at 29 Times in 14 Posts
| Not Ranked : 0 score Not to resurrect, but make sure you take off things that may be in the way of a good spray (like side skirts), and pressure wash the underbody if you can, or just spray wash the underbody and let it dry for a day (best done over the weekend). rust-proof any specific areas and then spray with an underbody coating of your choice. 3M makes good stuff. Hasn't dripped on me and seems pretty bullet proof, 2 salty winters under its belt now.
__________________ I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems. "... if u can't find' em - grind 'em" - old Chinese proverb ![]() ![]() http://www.mazdamotorsports.com/ |
![]() | | #31 | ![]() |
![]() Join Date: Jul 2011 Location: Elk Grove Village, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,411
Groans: 124
| Not Ranked : 0 score Idk if its been mentioned, but i hear por15 is rly good....Buddy just sanded under car and painted this on there. Guess can be put over rust. Plan to do this to my undercarriage when it gets warmer. Stop Rust with POR-15® - We Know What Permanent Means!
__________________ DBB Gen2 Pte6266, kozmic pte top mount manifold kit, Kozmic 4'' Intake, kozmic hood exit Dp+Dump, 11:1 Custom Wiesco Pistons + Monlar rods, Freek PnP head w/Supertech springs&retainers, L19 Head Studs, JMF PI Intake Manifold W/ custom single Walbro 450+ Fuelab Inline Pump, HKS BOV, Cp-e Stage2 RMM, Trz Tranny Mount, MD PMM, JBR Egr Block Off Plate, Cp-e Fuel Pump, Sheepey Built Fmic Core, 3.5 Bar Map Sensor, Precision Wastegate, TWM Shifter bushings, Freak Tuned! 713whp/569wtq! FIRST MS3 IN 10s! 10.963 @ 136.79 (8/12/2015) 10.72 @ 139.44! (10/1/2015) 10.43 @ 140.95! 10/9/2015 10.35 @ 140.86 (10/30/2015) New Time! Fastest Ms3 to date 10.27 @ 141.55 (5/22/2016) |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score After trying both I prefer a grease type spray versus paint on stuff. The painted stuff like Por15 are very messy and require a very clean surface and proper adhesion. They also can hide rust forming and create moisture packets. The grease is easy to apply, cheap, not terribly messy, and keeps bolts easy to remove as well.
![]() | | #33 | ![]() |
![]() Join Date: Feb 2010 Location: SLC, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,720
| Not Ranked : 0 score idk why i havent thought of this but i havent. my car goes thru the ringer in winter and has started rusting up pretty decent. I'm gonna have this thing on jack stands for a week this spring removing and blasting all the rusty parts and repainting all of it. I shoudl definitely give her a coat of this stuff while i'm at it. Thanks for the heads up
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 |
![]() | | #34 | ![]() |
Groans: 124
| Not Ranked : 0 score Yeah true......Will the spray work good with like slight surface rust? I planned on at least sanding/light sanding most of it down and painting or doing something. Just want a very clean undericarrage
![]() | | #35 | ![]() |
| Not Ranked : 0 score i wire brushed my underbody this year and repainted it. The key is getting ALL the rust off tho so it wont keep spreading. I wasn't able to get rid of all of it thats why i'll be removing and blasting this spring. Wire brush is much easier than sanding
| The Following User Says Thank You to snailD For This Useful Post: | mazdafreak (01-22-2014) |
![]() | | #36 | ![]() |
Groans: 124
Ahh yeah, thatd be a lot better using wire brush....Probably would have thought about that after i did all the sanding hahaha. Are you removing parts or having a place sandblast all underneath and paint it? Cause i have a buddy that can sandblast for me for next to nothing and i could paint or have a place paint/powdercoat parts......Like all rear end needs a lil loving. only seen one winter with me, last 3 yrs been in garage.....ANd subframe just needs a wire brush and paint which is nothing
__________________ DBB Gen2 Pte6266, kozmic pte top mount manifold kit, Kozmic 4'' Intake, kozmic hood exit Dp+Dump, 11:1 Custom Wiesco Pistons + Monlar rods, Freek PnP head w/Supertech springs&retainers, L19 Head Studs, JMF PI Intake Manifold W/ custom single Walbro 450+ Fuelab Inline Pump, HKS BOV, Cp-e Stage2 RMM, Trz Tranny Mount, MD PMM, JBR Egr Block Off Plate, Cp-e Fuel Pump, Sheepey Built Fmic Core, 3.5 Bar Map Sensor, Precision Wastegate, TWM Shifter bushings, Freak Tuned! 713whp/569wtq! FIRST MS3 IN 10s! 10.963 @ 136.79 (8/12/2015) 10.72 @ 139.44! (10/1/2015) 10.43 @ 140.95! 10/9/2015 10.35 @ 140.86 (10/30/2015) New Time! Fastest Ms3 to date 10.27 @ 141.55 (5/22/2016) | |
![]() | | #37 | ![]() |
| Not Ranked : 0 score taking it off. my buddy does powdercoating and told me i can just bring over and use the blaster whenever
![]() | | #38 | ![]() |
Groans: 124
| Not Ranked : 0 score Basically what my buddy said, but id have to go to a powdercoater. What parts u removing? Im gonna remove basically the whole rear end....Maybe some front suspension stuff....Im not removing subframe
![]() | | #39 | ![]() |
| Not Ranked : 0 score not 100% sure. gonna have to look after this winter as i'm sure i'll get some more rust. I drive up to go snowboarding 4 days a week.
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score I would spray this over underbody surface rust to prevent any more spread. If you sandblast the underbody and paint it you will likely get more rust in the end since the coverage is never ideal unless done by a professional with the right tools. Remove dirt, leave the paint that remains and just apply this.
| Artist uses rust as brush to paint cars | Haltech | Automotive News | 0 | 01-27-2012 06:40 AM |
| Preventing fraud is key concern as cash-for-guzzlers takes shape | Haltech | Automotive News | 0 | 06-22-2009 03:40 PM |
