> Car Detailing
Like Tree5Likes
 Old 01-22-2014, 06:56 PM   #41
snailD's Avatar
Posts: 3,039   (View Stats)
I would spray this over underbody surface rust to prevent any more spread. If you sandblast the underbody and paint it you will likely get more rust in the end since the coverage is never ideal unless done by a professional with the right tools.
Remove dirt, leave the paint that remains and just apply this.
i'm not sure I 100% follow your logic. you are saying on the re-paint you worry about coverage correct?
 Old 01-22-2014, 07:20 PM   #42
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
Well sandblast will remove all the rust....and id have it professionally painted/powdercoated then spray that stuff u have on it
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
 Old 01-22-2014, 07:26 PM   #43
That will work.
I just saw some bad undercoating jobs done with a brush on the floor under the car and it didn't turn out well.
The only way to get proper coverage with paint is to remove the parts, blast, prep, paint. Sounds like you're doing it right.
mazdafreak likes this.
mazdafreak (01-22-2014), snailD (01-22-2014)
 Old 01-22-2014, 07:30 PM   #44
snailD's Avatar
That will work.
yes this is the plan
The Following User Says Thank You to snailD For This Useful Post:
 Old 01-23-2014, 08:18 AM   #45
BAT-man's Avatar
Posts: 719   (View Stats)
BAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the world
Groaned at 29 Times in 14 Posts
I would consider rust converters prior to coating, if sandblasting is not an option (it isn't for most of us). So -
1) Prep, clean (power wash/wash/sandblast), & dry 2) Apply rust converter to current surface rust / anywhere you think it may form 3) Apply grease/underbody coat of choice.
I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems.
"... if u can't find' em - grind 'em"
- old Chinese proverb
http://www.mazdamotorsports.com/
BAT-man is offline   Reply With Quote
 Old 01-23-2014, 09:30 AM   #46
CosmicArkie's Avatar
Posts: 1,332   (View Stats)
^^THIS^^
Rust-mort or something similar
Item Detail
 Old 01-23-2014, 11:15 AM   #47
Elwood617's Avatar
Posts: 541   (View Stats)
Elwood617 is the leader of the worldElwood617 is the leader of the worldElwood617 is the leader of the worldElwood617 is the leader of the worldElwood617 is the leader of the worldElwood617 is the leader of the worldElwood617 is the leader of the worldElwood617 is the leader of the worldElwood617 is the leader of the worldElwood617 is the leader of the worldElwood617 is the leader of the world
Good info, thanks for sharing
It's all about the PMA
Elwood617 is offline   Reply With Quote
 Old 03-07-2014, 11:51 PM   #48
mazdafreak's Avatar
Groans: 124
Rear end is out. Dropping off monday for sandblasting and powdercoating.
Will post before and after pics next week..... subframe will be dropped next for same thing.
713whp/569wtq!
The Following User Says Thank You to mazdafreak For This Useful Post:
snailD (03-07-2014)
 Old 03-10-2014, 10:08 AM   #49
mazdafreak's Avatar
Groans: 124
What would you guys recommend doing for this rust? Since I can't remove it and have sandblasted/coated.
Just grind down and paint myself?
713whp/569wtq!
Last edited by mazdafreak; 03-10-2014 at 10:23 AM. Reason: MSF Database - Automerged Doublepost
 Old 03-10-2014, 11:14 AM   #50
alphasaur's Avatar
Posts: 2,847   (View Stats)
Groans: 235
wirebrush & rust converter
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/lol nator.
The Following User Says Thank You to alphasaur For This Useful Post:
mazdafreak (03-10-2014)
 Old 03-10-2014, 02:58 PM   #51
Winner!
 Old 03-11-2014, 01:24 PM   #52
mariomspeed's Avatar
Posts: 26   (View Stats)
mariomspeed is a jewel in the roughmariomspeed is a jewel in the roughmariomspeed is a jewel in the rough
@mazdafreak; shawn im sick of seeing your car in the garage more than on the street.
jk, wish I didn't have to daily mine.
mariomspeed is offline   Reply With Quote
The Following User Says Thank You to mariomspeed For This Useful Post:
mazdafreak (03-11-2014)
 Old 03-11-2014, 01:41 PM   #53
mazdafreak's Avatar
Groans: 124
Hahaha. I kno. Its no funn. It'll be out this spring for sure. Just a few more things I need.
713whp/569wtq!
 Old 03-11-2014, 01:46 PM   #54
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
There's no powder coating that will prevent rust. Over time the pain will crack, exfoliate, or be penetrated by the particles of sand thrown at very high speeds.
The best that you can do for your car is to spray some anti-rust wax once in a while (ideally before every winter) and that will hold better than power coating IMHO. These waxes will also cover the small chips and holes in the pain, eventually bond with the already existing rust and create an hermetic layer what will be thicker and more elastic than whatever you get on those parts by power coating them.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
The Following 3 Users Say Thank You to mituc For This Useful Post:
helmetface (07-16-2014), Lex (03-20-2014), lnumbp (12-22-2014)
 Old 03-11-2014, 02:09 PM   #55
@mazdafreak; ya well see
Just zoom zoomin around town, wheel spinnin and what not.
Lex/stratified tuned on 93 and 93/E85 310whp 360wtq, cobb intake,PG inlet, PTP hpfp internals, AWR rmm, cat delete(poor man test pipe), forge v1 bpv, JBR rear sway bar
 Old 03-11-2014, 04:55 PM   #56
mazdafreak's Avatar
Groans: 124
If u seen the rust on under my car, it needs sandblasting and coating. Then I'm spraying it with anti-rust shit to help prevent it. Car doesn't see winter. I bought it used tho with 18, xxx on car in chicago. So car wasn't clean.
713whp/569wtq!
 Old 03-11-2014, 06:11 PM   #57
aviator79's Avatar
Posts: 3,934   (View Stats)
I made a right angle end for my pressure washer (very small gas PW) to clean the house AC and worked great, now realize this will help to clean my car as it has gone thru the worst winter ever as I never used to drive it. My engine bay is white. Definitely going to try to clean it up this summer as plan to drive it into the ground and dont want rust being the end of the car.
For those without a lift can make one of these. Just prepare to get soaked, were eye protection and use a plastic creaper or the sears one made of particle board will fall apart like mine already has. And use something like 2000psi or less PW.
Right angle thing I made from parts at HD:
 Old 03-19-2014, 03:51 PM   #58
mazdafreak's Avatar
Groans: 124
Before:
AFTER:
713whp/569wtq!
The Following 2 Users Say Thank You to mazdafreak For This Useful Post:
jm211 (05-09-2014), Mazdazilla6 (03-20-2014)
 Old 03-20-2014, 08:49 PM   #59
BAT-man's Avatar
That is some good pressure washing right there, looks like new
Seriously, did you sandblast and then paint?
 Old 03-20-2014, 09:00 PM   #60
mazdafreak's Avatar
Groans: 124
Im very good with my powerwasher!
Had my guy sandblast and powdercoat it with a clearcoat. No more rust! and will not have any rust!
All new rear end bolts going in too. Only like $140 for bolts only $260 for whole rear end + 2 brake brackets and compressor housing blasted and coated.
713whp/569wtq!
 Old 03-20-2014, 09:40 PM   #61
Looks very good. Apply the waxy spray before you assemble and every winter as well to prevent rust from starting when any chips form.
The rust protection from the factory on this car is really poor.
mazdafreak (03-20-2014)
 Old 03-20-2014, 09:47 PM   #62
mazdafreak's Avatar
Groans: 124
Will do! Car wont be seeing any rain or water after all this. But its still gonna get as much protection as i can do to it.
Next will be dropping the subframe!
713whp/569wtq!
 Old 05-06-2014, 04:43 PM   #63
Atomic41's Avatar
Posts: 1,174   (View Stats)
With a 20 oz bottle of LPS ... can I do all under the car ?
With your 2 cans - 11oz spray can @Lex; you can do all the underneath ?
2008 MAZDASPEED3 Black
Stratified Tuned / Stage 2
Atomic41 is online now   Reply With Quote
 Old 05-08-2014, 10:39 AM   #64
I use about 2 cans for one application.
 Old 05-08-2014, 11:22 AM   #65
Atomic41's Avatar
You apply before the winter ... or anytime and it stay there ?
The Following User Says Thank You to Atomic41 For This Useful Post:
jm211 (05-09-2014)
 Old 05-21-2014, 06:35 PM   #66
Semp's Avatar
Posts: 18   (View Stats)
Semp will become famous soon enoughSemp will become famous soon enough
I think I will be applying this to the underside of my 6 before next winter hits. Some of the suspension components are already quite rusty looking. Will a wire brush really take all of the rust off?...
2006 Speed6 GT - Mazdaspeed CAI, Magnaflow catback, TWM short throw, 3M'd hood and fenders, 20% tint all around
2012 F-150 FX4 Supercrew - Winter Ride
Semp is offline   Reply With Quote
 Old 05-26-2014, 11:18 PM   #67
mazdafreak's Avatar
Groans: 124
All done. Looks so good.
713whp/569wtq!
The Following 3 Users Say Thank You to mazdafreak For This Useful Post:
802MS3 (05-28-2014), Elwood617 (05-28-2014), rymanmazda (05-27-2014)
 Old 07-15-2014, 06:38 AM   #68
aviator79's Avatar
Anyone want to go in on a case or 12 of LPS-3? Would be $11.59 a can rather than $40 for 2 cans. Obviously have to be sort of local to CT...
 Old 07-15-2014, 08:21 PM   #69
mazdafreak's Avatar
Groans: 124
Amazon.com: Lps Laboratories 00316 LPS 3 Heavy-Duty Rust Inhibitor: AutomotiveAmazon.com: Lps Laboratories 00316 LPS 3 Heavy-Duty Rust Inhibitor: Automotive
One can did my whole rearend. amazon lil cheaper. ~$14 a can
713whp/569wtq!
 Old 07-16-2014, 04:57 AM   #70
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
A few questions to follow-up:
Are you concerned about moisture getting trapped between the wax and the frame? Obviously this would create a prime environment for some fast acting rust.
With this method, are you still washing the underside of your body a few times a year? Or just keep spraying on the wax?
 Old 07-16-2014, 10:24 AM   #71
mituc's Avatar
Groans: 111
No. That wax would merge with water and oxydes (rust) and once done it will become quite hard to penetrate.
From time to time I wash the belly of the car. It doesn't get too dirty apart from the wheel wells and everything in the front: steering knuckles, front tampers, axles, and so on, you know what area I'm referring to...
However, even if you use a turbojet to wash those areas you waxed the wax itself isn't affected. As far as I know it is affected by vibrations, temperature extremes and sanding. So that's the reason you have to renew that layer of underside wax, not because you wash the car with high pressure water.
 Old 07-16-2014, 04:32 PM   #72
aviator79's Avatar
Well its $19 a can with ship thats why was going to get a 12 pack then would be $11.59/can. Probably find enough locals to make it work just wanted to post here.
On a side note the sheet on this says its good for 2 years inside. How well will this really hold up? I assume may need to respray every year or so here and there?
 Old 07-16-2014, 08:33 PM   #73
mazdafreak's Avatar
Groans: 124
Ohh I was amazon prime member so it's like all free shipping.
713whp/569wtq!
 Old 08-15-2014, 11:35 AM   #74
mrQQ's Avatar
Posts: 1,164   (View Stats)
mrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the world
That's what I wanted to ask - your cars all look very clean. Over hear, with snow, mud, rain, dust and dirt the under is covered in dirt. Spraying on top if it wouldnt make any sense, so how do you clean it off before?
also, how do you save wheel arches?
mrQQ is offline   Reply With Quote
 Old 09-23-2014, 02:42 PM   #75
Tyhackman15's Avatar
Posts: 1,742   (View Stats)
Tyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the world
Bump, because it's that time of the year again. Just bought 2 20oz spray bottles of this stuff for my current DD. It's from NM so 100% rust free, WI will be a great test for how well LPS-3 holds up. I'll be sure to post results, etc...
SOLD 2008 MS3 17x8 Evo 9's, 235 v12
1995 Miata 1.8L w/ FMII GT2560R @11psi, FM stage 2 clutch/flywheel, FM Frame rail braces, FM high capacity radiator/fans, RB Sway bars, Racing beat exhaust, Fat cat Coilovers, Jongbloed 15x9, Wilwood 4 wheel BBK, Rollbar, Hardtop, TDR Racing seat
2001 Saab 9-3 Viggen 2.3T Stage 3+ bro, SRI, 3" DP, ETS FMIC, 17x8 BBS RK2's, Full chassis bracing / sway bars, Forge BPV, Winter/DD
Tyhackman15 is offline   Reply With Quote
The Following 3 Users Say Thank You to Tyhackman15 For This Useful Post:
aviator79 (09-24-2014), Dimenus (09-23-2014), mazdafreak (09-24-2014)
 Old 10-05-2014, 07:10 PM   #76
makjur's Avatar
Posts: 1,313   (View Stats)
makjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the world
Groaned at 15 Times in 8 Posts
I'm gearing up to do some rust removal/prevention myself.
My dad recently did his 99 ford ranger's rear frame with POR15... he had the bed removed, gas tank off, break lines etc... shit is better then new at this point
He has some left over and I'll be using a small pneumatic hand grinder to remove any corrosion and painting over with this stuff. I'll also scuff up the in tact existing paint and coat over it with the POR15.
Its basically an acrylic coating, shit is nasty to work with and smells like death though
Amazon.com: POR-15 45009 Gloss Black Super Starter Kit - 20 fl. oz.: AutomotiveAmazon.com: POR-15 45009 Gloss Black Super Starter Kit - 20 fl. oz.: Automotive
2010 blue with tech, cobb sri+tip+dp+cbe, ets tmic, grimmspd ebcs, autotek hpfp, jbr boosttoobs+rmm+roundknob+bushings, turbosmart bpv, swift springs, APv3 FreekTuned
retrofitted headlights: morimoto 5k HIDs with XB35 ballasts, in mini D2S projectors. VLED triton 5k switchback DRL/turn signals
°(ಠೆಒಠಿ)°
makjur is offline   Reply With Quote
 Old 12-21-2014, 05:26 PM   #77
BAT-man's Avatar
Winter is coming, so a little resurrect to get more info on the topic in here -
Been searching around for a bit, both for this platform and another '90s vehicle that I'll be doing some under-body restoration on...
After hitting a surface rust spot with the wire wheel, what do you folks prefer for rust conversion/primer, before you hit it with some 3M rubberized undercoat?
I've seen good things about Ospho
(http://www.amazon.com/Ospho-Skyco-Su...+Surface+Prep])
which is chemically a great way to convert iron to phosphate.
I've also heard good things about Evaporust
(Evapo-Rust? Rust Remover - 1 Gallon)
which is a little cheaper but I'm not sure if provides the same level of conversion/protection before undercoating...
Both are probably less for the subframe and more for the actual shell/sheetmetal itself, although the wirebrushing+Ospho I probably would use as an alternative to sandblasting/powdercoating, prior to shooting it with some undercoating.
Any input?
 Old 12-21-2014, 08:46 PM   #78
Best bet is a pressure washer. The stuff will be fine sprayed over some dirt though, just don't spray it when the car is wet or salty.
I put a coat of it on my arches. I don't care if some shows, it's winter my car is usually filthy anyway.
 Old 12-22-2014, 09:36 AM   #79
aviator79's Avatar
Any input?
Nope.
Im just going to pressure wash and spray with LPS3.
 Old 01-26-2015, 10:04 AM   #80
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
Can anyone comment on how the LPS3 holds up to a touchless car wash that has a high pressure undercarriage spray?
'08 CWP MS3 w/ T3 3071r
Artist uses rust as brush to paint cars Haltech Automotive News 0 01-27-2012 06:40 AM
Preventing fraud is key concern as cash-for-guzzlers takes shape Haltech Automotive News 0 06-22-2009 03:40 PM
Page generated in 0.65760 seconds with 37 queries
