 Old 04-21-2018, 12:54 PM   #1
SlowMotion's Avatar
Posts: 34   (View Stats)
SlowMotion will become famous soon enough
Default 6th port issues, rich at idle.
Quick backstory, went bt with a 5862. started tuning and ran out of fuel super early in the process. picked up a 6th port kit from speedpeformance, install went fine. now the car is running extremely rich. i checked the two new injectors and neither are bad or stuck open and they are not plugged in. i ran a leak test with a smoke machine and came up empty. with just the key on my fuel pressure is in the 400s then at idle its 1100-1200. My afr is between 9 and 10 at idle, and leans out if i blip the throttle. im running out of ideas, any help would be awesome.
2006 ms6 5862 build in progress.
SlowMotion is offline   Reply With Quote
Car rich at idle willbeblack MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 11-06-2017 11:05 AM
Rich at idle mystery CW42 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 11 07-28-2014 08:55 AM
P2188 Rich at Idle Biggs MazdaSpeed 3/6 - Troubleshoot/Diagnostics 22 03-05-2014 09:26 AM
Rich idle, Rich on throttle tip in MSP6 MazdaSpeed 6 - Engine, Transmission & Driveline 39 02-17-2013 06:49 PM
p2188 - too rich at idle yearzero MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 05-15-2010 09:53 PM
Page generated in 0.21945 seconds with 20 queries
