![]() Join Date: Apr 2008 Location: Utah
Rep Power: 573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 120
(Thread Starter) | Not Ranked : 0 score Say i start the car. Everything is running dandy. I stop the engine by turning the key. turn key back on but dont start car yet (Everything has power, dashhawk is still running etc) My Fuel DI pressure will steadily rise from ~400 psi too like 1600 psi even though the engine is off. Has anyone else noticed this behavior? Next time you drive you could check and see on your DH or Cobb AP? If i turn the key when the car has been sitting the pressure sticks at 60 psi like it should. -Phil
__________________ 2006 Titanium Gray MS6 Mods: DCR - Built Longblock with Pauter Rods , Wiseco 8.9:1 Pistons, Stiffer Valvesprings, P&P Head Upgraded VVT Actuator Cobb AccessPort + 3 Bar Map Sensor CP-E TIP , RMM Aquamist HFS-4 WMI Injection System Bullseye - T3 .55AR S259 Turbo Synapse - BOV Custom - Ceramic Coated T3 Exhaust Manifold , 3" T3 Downpipe, 3"-2.5" Dual Catback Exhaust, 3" MAF SRI, FMIC PT-P CDFP + Walbro 255 Intank Pump + Fuelabs Adj. FPR + -6 AN Feed/Return Turbine Tech / Street Unit - Front & Rear Diff Mount eDesign Audio - NINe.2x 760W AMP , 2x 11Kv.2 10" Subwoofers Last edited by JumpingJackson; 01-06-2011 at 02:25 PM. |
Groans: 60
| Not Ranked : 0 score I've never seen anything like that.. I see my idle fp gradually fall until it settles around 60~70psi..
(Thread Starter) | Not Ranked : 0 score Speculation as to cause?
__________________ 2006 Titanium Gray MS6 Mods: DCR - Built Longblock with Pauter Rods , Wiseco 8.9:1 Pistons, Stiffer Valvesprings, P&P Head Upgraded VVT Actuator Cobb AccessPort + 3 Bar Map Sensor CP-E TIP , RMM Aquamist HFS-4 WMI Injection System Bullseye - T3 .55AR S259 Turbo Synapse - BOV Custom - Ceramic Coated T3 Exhaust Manifold , 3" T3 Downpipe, 3"-2.5" Dual Catback Exhaust, 3" MAF SRI, FMIC PT-P CDFP + Walbro 255 Intank Pump + Fuelabs Adj. FPR + -6 AN Feed/Return Turbine Tech / Street Unit - Front & Rear Diff Mount eDesign Audio - NINe.2x 760W AMP , 2x 11Kv.2 10" Subwoofers |
![]() Join Date: Mar 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 895
| Not Ranked : 0 score Ima try this...will let you know |
Groans: 60
| Not Ranked : 0 score I'd guess it's a can bus/DH issue not a sensor problem... Unless you start getting strange readings while the motor is running I wouldn't worry too much..
| Not Ranked : 0 score mine does the same thing....it climbs (slowly..in jumps of 2 or 3) all the way up to 1600 when the car is on but not running |
![]() Join Date: Dec 2008
Rep Power: 403 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,254
Groans: 109
| Not Ranked : 0 score Funny enough I was sitting in a parking lot tonight after running into the store. I turn the key on but didn't start the car but the ap showed 1200 psi pressure and was slowly climbing. I thought it was weird but car runs fine though. |
![]() Join Date: Feb 2012 Location: Hartford, Conn.
Rep Power: 0 ![]() Thanks: 2
| Not Ranked : 0 score Looking forward to meet some of you and learn the ways of the Speed6. I'll be gathering and posting my information and mods, and hopefully find solutions to some of the problems I have encountered. For now, I am a proude owner of a 2006 MazdaSpeed 6 Thank you, |
![]() Join Date: Nov 2012 Location: Leominster Mass
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,003
| Not Ranked : 0 score You're not off to the greatest start... Try making your own thread in the new member section and not posting in a thread with nothing in common from 2011. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f303/bad-fuel-pressure-sensor-68927/ | ||||
| VTRides :: View topic - I love www.mazdaspeedforum.org/forum | This thread | Refback | 03-27-2011 04:12 PM | |
| Fuel Rail High Pressure Sensor Upgrade | JumpingJackson | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 234 | 10-25-2014 01:54 AM |
| TIRE PRESSURE SENSOR... | redneckrecon | MazdaSpeed 3/6 - Wheels & Tires | 12 | 01-21-2011 07:23 PM |
| How to scale the HPFP pressure sensor | djuosnteisn | MazdaSpeed 3/6 - ECU Computer Tuning | 521 | 04-07-2010 08:39 AM |
| P0107 - Barometric pressure sensor low input | vbt101 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 2 | 09-14-2009 01:31 PM |
