 Old 09-18-2012, 05:20 PM   #1
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Default Converting Injector Flow Rates
I made this sheet a while back for some friends who did not understand the difference between mass flow rates and volume flow rates. I understand that the ms3/ms6 does not currently have an upgraded injector option, this can still be useful for anyone adding additional injectors to meet fuel demands. Or for anyone with other vehicles and need to understand the differences. Typically injectors are rated in either lbm/hr (pound mass per hour) or cc/min (cubic centimeter per minute).
These flow rates are rated at a given fuel pressure that they are tested at. Most people just use a conversion of ~10.5. That is fine. This is just to show the derivation and provide an understanding. I may have made it a little more complicated by switching from metric to USCS but the concept remains the same.
Converting lbm/hr to cc/min
www.tunedbynishan.com
7mileshome (09-18-2012), rfinkle2 (09-18-2012), Tokay444 (09-18-2012)
 Old 09-18-2012, 07:44 PM   #2
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
Pound is not a unit of mass dammit very nice write up though
 Old 09-18-2012, 07:47 PM   #3
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Sure it is.
Pound (mass) - Wikipedia, the free encyclopedia
P.S. Why didn't you just put the formula into Excel OP? Way fucking easier.
Last edited by silvapain; 09-18-2012 at 07:47 PM. Reason: MSF Database - Automerged Doublepost
ms3blackmica (09-18-2012), TWOptSL0W (09-19-2012)
 Old 09-18-2012, 07:48 PM   #4
Nishan
it should of been lbm (pound mass).
oops!
Sure it is.
wanted to show the derivation on how its calculated.
Last edited by ms3blackmica; 09-18-2012 at 07:48 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-18-2012, 07:48 PM   #5
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
that brings me back to fluid dynamics....good times.
Blue Pu.
The Following 2 Users Say Thank You to anavrinIV For This Useful Post:
 Old 09-18-2012, 07:51 PM   #6
TWOptSL0W's Avatar
Groans: 125
Nope sorry it's fucking wrong. A pound is a unit of force actually. It is the gravitational force on an object due to its mass. More mass, more force (weight). Your mass is how much matter you have, i.e. how much "stuff" there actually is. If you go to the moon, you will have the same mass because you are still the same amount of person, but you will weigh less in pounds because the gravitational force is less on the moon, therefore, less force pulling your mass down.
Weight=mass*coefficient of gravity (on earth, it is 9.8 m/s^2) and your mass would be in kg which would give your weight in newtons actually.
Edit: ok now that we're talking about lbm it's all good carry on
The Following User Says Thank You to TWOptSL0W For This Useful Post:
 Old 09-18-2012, 07:57 PM   #7
silvapain's Avatar
Groans: 136
When injectors are rated in mass flow, the 'lb/hr' rating is actually 'lbm/hr'.
 Old 09-18-2012, 10:17 PM   #8
Nishan
mike you are absolutely correct. when i made this little sheet, it was for my "not so knowledgable" friends lol if i would of started explained lbm and lbf they would of been mind blown
yes this is correct.
GDI Injector Flow Testing/Cleaning superskaterxes MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 177 08-18-2014 03:21 PM
Ms6 does anyone know stock spring rates and aftermarket rates? darkcherry MazdaSpeed 3/6 - Suspension & Brakes 7 12-16-2011 03:31 PM
Converting NA StandBack to MS6 RichieRichness Custom Performance Engineering (cp-e.com) 0 06-02-2010 02:13 PM
Gutted cat flow ~= SLP Loudmouth Resonator? Flow cant be hurt I dont think.. 08Anamoly MazdaSpeed 3 - Engine, Transmission & Driveline 6 03-04-2010 01:07 PM
Page generated in 0.31624 seconds with 23 queries
