Like Tree7Likes
  • 1 Post By 5doorsoffury
  • 1 Post By Fstrnyou
  • 1 Post By WAMBUSHHHH!
  • 1 Post By MSMS3
  • 1 Post By JakeMS3
  • 1 Post By KiwiFlavor
 Old 01-02-2018, 08:49 PM   #1
paukacang's Avatar
Posts: 14   (View Stats)
paukacang has a spectacular aura aboutpaukacang has a spectacular aura aboutpaukacang has a spectacular aura about
Groaned at 3 Times in 1 Post
Default Do i need Upgrade HPFP
hello
today just log my car using foscan. here the result.
Logging using gear 3 WOT. from datalog my fuel pressure drop below 1600psi at rpm 2867~5128. but arise again above 1600psi on rpm 5220. do i need upgrade internal hpfp
My car info
Just remap & up boost to 1.3bar.
243hp to 267hp
torque : 41.63 to 46.83
paukacang is offline   Reply With Quote
The Following 3 Users Say NO Thank You to paukacang For This Un-useful Post:
g00s3y (01-03-2018), Thor Hammer (01-03-2018), Vansquish (01-03-2018)
 Old 01-02-2018, 09:39 PM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
It didn't blow up?
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 01-03-2018, 04:49 AM   #3
paukacang's Avatar
It didn't blow up?
not yet
 Old 01-03-2018, 06:06 AM   #4
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
Originally Posted by paukacang View Post
not YET
Kinda answered your own question.
sharksinspace likes this.
MECP
2012 BM
Rfinkle tune in progress
 Old 01-03-2018, 07:46 AM   #5
shamie's Avatar
Posts: 952   (View Stats)
Quite a lot of boost at low RPMs - be careful.
Per your question - yes you have a fuel pressure issue (most likely HPFP). Get that fixed before you ZZB.
 Old 01-03-2018, 08:02 AM   #6
paukacang's Avatar
Tq for advice.
 Old 01-03-2018, 08:18 AM   #7
Fstrnyou's Avatar
Not to thread jack, but my tire is flat. Do I need to fill it up?
danb likes this.
Other rides:
History:
The Following 3 Users Say Thank You to Fstrnyou For This Useful Post:
KiwiFlavor (01-05-2018), mcburtonsoft (01-05-2018), sharksinspace (01-05-2018)
 Old 01-03-2018, 08:35 AM   #8
WAMBUSHHHH!'s Avatar
Posts: 1,599   (View Stats)
Rule of thumb: if you're asking "Do I need HPFP?", you most likely do.
 Old 01-03-2018, 08:43 AM   #9
Fstrnyou's Avatar
Rule of thumb: if you're not stock and don't have HPFP upgrade, you already screwed up.
LenSpeed6 likes this.
Other rides:
History:
 Old 01-03-2018, 09:34 AM   #10
MSMS3's Avatar
Posts: 2,827   (View Stats)
Short answer - Yes.
Longer answer - since the log shows rail fuel pressure below 1600 @ what you describe as WOT, you must upgrade the pump. And stay out of boost until you get that done. Log does not show throttle position, so I assume you were WOT when pressure dropped.
I'll bet that a complete log would also show injector bandwidth longer to try to compensate for low pressure. Lucky it didn't blow.
dp3 likes this.
 Old 01-03-2018, 09:50 AM   #11
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
OP is the first fucking idiot of 2018...
Congratulations!
KiwiFlavor (01-05-2018), Thor Hammer (01-03-2018)
 Old 01-03-2018, 10:11 AM   #12
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
If I had a nickel for every “do I need fuel pump internals” threads started. I’m on board with @g00s3y; first fkn idiot of 2018! At least he provided some type of data log and not just a long list of mods he’s already added onto his car. Gotta give him props for that.
dp3 likes this.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
paukacang (01-04-2018)
 Old 01-03-2018, 10:32 AM   #13
spada's Avatar
Posts: 17   (View Stats)
spada is a jewel in the roughspada is a jewel in the roughspada is a jewel in the rough
wow, I'm surprised you didn't blow up.
I think you have other fuel issues, not just the HPFP internals. I wouldn't drive the car at all.
and shamie, those boost numbers for some reason are absolute pressure, not gauge pressure.
Ben Spada
2006 Mazdaspeed 6
1996 Ford Probe GT
spada is offline   Reply With Quote
 Old 01-03-2018, 11:13 AM   #14
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
How do you figure? He needs HPFP upgrade. Its as simple as that.
 Old 01-03-2018, 11:27 AM   #15
spada's Avatar
I figured because his fuel pressure was 700 psi at 3500rpm. Seems like too drastic of a drop.
Ben Spada
2006 Mazdaspeed 6
1996 Ford Probe GT
 Old 01-04-2018, 01:24 AM   #16
paukacang's Avatar
my mistake. sorry
Short answer - Yes.
will log again full detail. tq
Last edited by paukacang; 01-04-2018 at 01:24 AM. Reason: MSF Database - Automerged Doublepost
 Old 01-04-2018, 08:01 AM   #17
MSMS3's Avatar
Don't log again! Not until after upgrading the pump. We are trying to save your engine.
If those drops were at WOT, you are already in trouble.
If you have previous logs where injector bandwidth was logged under WOT, they would be worth looking at. Making a new log will only expose you to serious risk of zoom, zoom, boom.
What is it about "stay out of boost" you don't understand?
 Old 01-04-2018, 09:29 AM   #18
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
not yet
You were damn close to blowing up, that if the engine is not hurt already.. Stop going WOT with that tune. At 37080 you actually hit 20PSI of boost and the next lines show the smallest fuel rail pressure reading, below 800PSI.
1.3BAR of boost is 19PSI, you should not go more than 17.5-18 and load of 1.9 without aftermarket HPFP internals. Yes a stock HPFP will allow for almost load 2 without loosing pressure but probably when new and clean, and not for long anyway.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 01-04-2018, 08:21 PM   #19
paukacang's Avatar
that absolute magnifold pressure. logging using forscan dont have turbo boost PID. max boost is around 1.3~1.4 bar. now i drive like grandma. today waiting autotech hpfp arrive. will log after change it. tq for advice
tq for advice. now drive like grandma
Last edited by paukacang; 01-04-2018 at 08:21 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-04-2018, 11:50 PM   #20
mituc's Avatar
Groans: 111
Yes, that is MAP (manifold absolute pressure) in PSI.
If the MAP is 35PSI and barometric pressure is around 1BAR which is 14.6-14.8PSI depending on where you are... 35-14.7 =~ 20PSI.
Believe me, you were very lucky to have your motor survive at 20+PSI at <4000rpm and 750-800PSI FRP. I have not seen such crap occurring since 2011-ish when people became aware of the importance of the fuel pump internals. So you doing this in 2018... you were given a title in a few posts above and you well deserve it
MSMS3 (01-06-2018)
 Old 01-05-2018, 12:09 AM   #21
paukacang's Avatar
huhuhu lucky man. thanx
 Old 01-05-2018, 07:42 AM   #22
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
Hey man in case nobody told you yet,
You need to upgrade your HPFP internals ASAP.
2012 NASA Spaceship Gray MS3
Thor Hammer (01-05-2018)
 Old 01-07-2018, 09:15 PM   #23
paukacang's Avatar
Just change to autotech hpfp & very impresive. tq guys for the advice. here i attach log after change it
The Following 5 Users Say Thank You to paukacang For This Useful Post:
dp3 (01-26-2018), KiwiFlavor (01-08-2018), mituc (01-07-2018), MSMS3 (01-09-2018), WAMBUSHHHH! (01-09-2018)
 Old 01-25-2018, 02:55 PM   #24
motoman's Avatar
Posts: 118   (View Stats)
motoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond repute
Based on your log you're not getting over low 2k in RPM. What are you trying to log?
Black Mica 2010 Mazdaspeed 3
motoman is offline   Reply With Quote
 Old 01-25-2018, 05:21 PM   #25
Fstrnyou's Avatar
Not sure what you're reading, but he went to 6198.
Other rides:
History:
How to tell if uou already have a hpfp upgrade? FullTilt429 2010 MS3 - Engine, Transmission & Driveline 1 11-01-2013 11:25 PM
Page generated in 0.45080 seconds with 33 queries
