 Old 05-27-2018, 05:28 PM   #1
CJones1225's Avatar
Posts: 4   (View Stats)
CJones1225 has a little shameless behaviour in the past
Default Fuel Pressure Problems at Idle
I’ve got a problem and I need your guys’ help. I recently installed. Cobb TIP and SRI, along with those mods I installed new AT internals and after installing my car will idle for about 2 minutes and then die. After it dies, the fuel pressure will start to rise again slowly. I’ve had all the o-rings replaced and the entire pump cleaned. I’m driving on 07 Ms3.
CJones1225 is offline   Reply With Quote
 Old 05-28-2018, 07:18 AM   #2
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
What is the fuel pressure idling at while its running?
 Old 06-03-2018, 09:49 AM   #3
mikey27's Avatar
Posts: 87   (View Stats)
mikey27 is a name known to allmikey27 is a name known to allmikey27 is a name known to allmikey27 is a name known to allmikey27 is a name known to allmikey27 is a name known to all
Nothing?
Fuel pressure while running?
What it dropped to when it died?
Sent from my SM-G955W using Tapatalk
2007 ms6, BNR S3, JBR 3" silcone intake, streetunit tmic, ATP 3" dp, WW 3" dp back, Autotech hpfp, denso itv22 plugs, synapse synchronic bpv, Cobb ebcs, egr block off, cobb ap v3, Damond pmm, AWR tmm, jbr rmm, cpe rear diff mount, AEM trunk mount meth, 3bar map, cpe safeseals, SP63 4032 88mm pistons, Manley H beam rods, bsd w/baffle, mild head and im porting, vtcs delete, balanced bottom end, cm850 w/ steel fw, Innovate failsafe, guardian angel v3
mikey27 is offline   Reply With Quote
Low fuel pressure at idle racersir Mazdaspeed3/6 General Discussion 23 10-22-2019 10:55 AM
Low Idle & WOT Fuel Pressure Fix khopwood77 2010 MS3 - Troubleshoot/Diagnostics 3 06-18-2013 01:45 PM
Low fuel pressure at idle event MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 53 07-02-2012 01:03 AM
Please help!! Vacuum, idle, fuel pressure,... MPS Power MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 12-14-2011 09:25 AM
Fluctuating Fuel Pressure at Idle Campo MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 13 02-09-2010 07:03 PM
Page generated in 0.23212 seconds with 22 queries
