  • 1 Post By 5doorsoffury
 Old 05-18-2019, 05:15 AM   #1
luisito320's Avatar
Posts: 9   (View Stats)
luisito320 will become famous soon enough
Default Fuel Problem
i been having fuel problem were my fuel pressure drop when the car is at idle for while. i have replaced the ITFP with DW300, IT fuel pressure regulator, HPFP switch from autotech to Corksport, also change the relief valve. all is done between 2 to 3 week apart.
i attached a log on idle, hope this help.
luisito320 is offline   Reply With Quote
 Old 05-18-2019, 08:51 AM   #2
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
What does it drop to 60psi? Have you checked your spill valve and HPFP internals? They could be sticking.
Edit just checked the log it looks like the internals are sticking. Pull the pump and clean it out and check it
luisito320 likes this.
MECP
2012 BM
Rfinkle tune in progress
luisito320 (05-24-2019)
 Old 05-18-2019, 09:16 AM   #3
luisito320's Avatar
the internals are brand new. and spill valve is clean.
 Old 05-18-2019, 12:03 PM   #4
luisito320's Avatar
I will be replacing the fuel pressure sensor. Cuz going to basics and use the relief valve diagnostic the fuel pressure doesn't go up again. And it should go up since the car is still hot and the relief valve is brand new.
 Old 05-22-2019, 02:20 PM   #5
luisito320's Avatar
So today I spend like 5 hours looking at wiring diagrams and doing diagnostics. I turn out that when the car gets to normal driving temperature the ECU cut the signal to the fuel pump relays.
Now I have to figure out if the ECU is bad or there is another sensor causing problems.
 Old 05-23-2019, 03:33 PM   #6
luisito320's Avatar
So ECU is good.
Cleaning mechanical pump again.
 Old 05-23-2019, 05:23 PM   #7
luisito320's Avatar
Fuel still drops and shut off. Even with the ITFP connected directly to the battery.
 Old 05-24-2019, 01:33 PM   #8
luisito320's Avatar
Found what was causing the fuel drop. Problem solve.
 Old 05-24-2019, 02:20 PM   #9
Jeff23spl's Avatar
Posts: 2,237   (View Stats)
what was it?
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Vansquish (05-24-2019)
 Old 05-25-2019, 12:10 AM   #10
luisito320's Avatar
ITFP was getting hot and is was losing pressure slowly.
 Old 05-25-2019, 04:08 PM   #11
MSMS3's Avatar
Posts: 2,827   (View Stats)
So you replaced it, or found out what was making it over heat and fixed that, or what?
 Old 05-25-2019, 08:27 PM   #12
luisito320's Avatar
I did replace it. Still dont know why it was overheating. I think the pump was bad, because I check all wires trying to figure out what was wrong with it and everything is good.
The Following User Says Thank You to luisito320 For This Useful Post:
MSMS3 (05-26-2019)
Fuel System Problem Speeden6 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 10-08-2017 07:26 PM
PI Fuel Pressure Problem nswartz19 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 04-26-2015 09:50 PM
Hey I have a fuel cut problem BigD99 2010 MS3 - Fuel, Nitrous & Water Injection 16 02-24-2014 06:40 AM
Problem after problem: Running rich & Fuel cuts wherewuat 2010 MS3 - Troubleshoot/Diagnostics 30 01-30-2014 02:13 PM
Fuel gauge problem... Speedaway Mazdaspeed3/6 General Discussion 14 01-17-2011 12:01 AM
Page generated in 0.30809 seconds with 24 queries
