| Not Ranked : 0 score The 2030 psi # is probably speculation, dunno where it was chosen from. My guess is it'll read closer to 2100+. Someone could simply put 5 volts on the sensor line and see what # they get on a DH for fuel pressure, and call that the stock sensor limit. Here's some data points i took a while back:
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
| The Following User Says Thank You to djuosnteisn For This Useful Post: | socks (12-22-2010) |
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 45885 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,982
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f303/fuel-rail-high-pressure-sensor-upgrade-67643/ | ||||
| 0265005303 - Virgilio Ricerca Web | This thread | Refback | 10-18-2011 07:58 AM | |
| High Pressure Relief Valve Option | SilverDemon | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 161 | 04-29-2011 08:10 PM |
| Opinion On High RPM High Pressure Fuel Pump Spring | ms3brendan | MazdaSpeed 3 - Engine, Transmission & Driveline | 1 | 07-13-2010 01:04 PM |
| Removing Fuel Rail...and where is the DI psi sensor located? | AFcadet | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 3 | 11-18-2009 04:48 PM |
