![]() Join Date: May 2019
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score Sent from my iPhone using Tapatalk |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,505
| Not Ranked : 0 score In a word - no.
| The Following User Says Thank You to MSMS3 For This Useful Post: | luckycharms628 (05-12-2019) |
![]() Join Date: May 2016 Location: Sarastoa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 114
| Not Ranked : 0 score Only once was 87 in my car. When it was new, I loaned it to my dad and he filled it up for me. Shortly after getting it back, I could tell he did it. Ran like crap. If you stay out of the boost completely, it won't break anything, so in a crunch, sure. Otherwise, don't do it.
__________________ 2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub Other Mods: FIAMM 72112 Low Note Horn alongside stock Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 550
| Not Ranked : 0 score Yeesh, I think it tells you on the fuel door about only using premium. This car is finicky. FWIW, I had a GT Cruiser prior to my speed and I could use 87 but the ECU adjusted. I only lost power/boost.
__________________ Stockish |
In many NA engines, tuning from 87 to 93 provides negligible gains, so why bother. In a boosted application, it's totally different. Look at the new 2.5T from Mazda. It is designed to run on either, so I assume it has a sensor to check the fuel before it goes into the engine, similar to how a flex fuel vehicle can check the Ethanol content. The DISI 2.3 does not do this, it can only react to lower quality fuel by pulling timing or cutting boost. That's why it doesn't run well with lower octane fuel, it's tuned for 91 from the factory. If you want to tune for 87 oct, contact a tuner and pay for a tune so you can save $.50/gallon and loose 20% of your power output. It's your car.
__________________ 2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub Other Mods: FIAMM 72112 Low Note Horn alongside stock Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks Last edited by Carskick; 05-21-2019 at 09:31 AM. | |
__________________ Stockish | |
| MS3 2010 stock, Cobb AP, stock fuel pump OK? | MammaFreed3 | 2010 MS3 - ECU Computer Tuning | 21 | 11-15-2011 02:31 PM |
| NEEDED - Stock CDFP & Stock OEM In Tank Fuel Pump | Haltech | Mazdaspeed3/6 General Discussion | 4 | 10-02-2011 04:24 PM |
